[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hat schon jemand ein Frostbite unboxing gesichtet ? :)
Gerade das Video von PCGH gesehen. Schöne FE Karte. Und mich wundert das sie gar nicht so viel schwerer geworden ist. Die braucht mehr Strom als eine 3090 da dachte ich schon das der Kühler deutlich zulegt und sie damit auch deutlich schwerer wird.
Finde es ja blöd, dass man heute immer noch keine ATX 3.0 PSUs in Deutschland kaufen kann. Erst hieß es die Thermaltakes erscheinen Anfang dieser Woche laut NBB. Bei proshop steht in 25 Tagen oder so.
Versteh nicht was ihr für ein Problem habt ? Mit dem 3 mal 8 kannst auch die 600 Watt ziehen , wenn deine NT es mit macht wenn du nicht genug hast auf der 12v Schiene Netzteil seitiges wird es abschalten . Ob 3 oder 4 juckt doch nicht der Querschnitt vom ja Kabel wird bei 3 schon reichen.
Der Querschnitt wird das mitmachen. Bei manch ausgenudelter Stecker-Hülse (GPU- oder NT-seitig) wäre ich mir da nicht so sicher
was soll den noch passieren ?
Also Gamestar schreibt Test kommt asm 12.10 also werden ALLE anderen Seiten auch keine Test eher raushauen dürfen.
@SH hat heute morgen was geschrieben
Hatte geschrieben, dass heute was kommt und es wahrscheinlich Reviews sein könnten. Aber durch die Aussage von Igor gestern war klar, dass es nur Unboxingbilder sind.
Immerhin bekommen wir mehr Infos heute :)
Aber ich finde trotzdem, dass die Leaks aus der ersten Seite reichen um die Performance einschätzen zu können.
Am meisten Angst hab ich im moment was die größe der Karte angeht. Wenn ich mir die Vergleichsbilder auf CB anschaue dann bin ich nicht sicher ob die Karten in mein O11 Dynamic (xl) passen. Breite spielt keine rolle aber die höhe bzw. tiefe (also zur scheibe) da hab ich jetzt bei der 3090 (gaming trio X) schon nur noch 1-2 cm platz.
STRIX Unboxing :)
"This is easily the best-looking ASUS graphics card we've seen. A matte alloy makes up most of the cooler shroud, with chrome or diamond-cut edges. The chrome accents combine with the metallic blue and red ones; and the card's RGB lighting, to give the card a very cyberpunk look, as we mentioned."
Willst dir wirklich ein Thermaltake mit einer 4090 kaufen? Würd ich mir ja 3x überlegen.
STRIX Unboxing :)
Frage mich überhaupt ob die Graka Stütze überhaupt lang genug ist, weil bei mir sind schon paar mehr slots die es abwärts gehen .
Da hat NV anscheinend noch mal Hirnschmalz aufgebracht um sie nur Geringfügig schwer gemacht!
Raf erwähnt das ja das weitere Optimierungen eingeflossen sind!
Wow die Colorful hat es auch in sich mit nur 33cm 2,45KG fast soviel wie die Strixx mit 2,5KG aber bei 35,5cm könnte @ Air sehr interessant sein da gibt es ja einige die es Gerade so auf 2KG bringen!
Falls jemand so verrückt sein sollte...
Darf ich deine Liste bitte in den Starpost übernehmen? :)
Sehr gerne, ich persönlich habe keinen Einwand, aber es ist genaugenommen nicht meine Liste, Google hat lediglich für mich diesen Reddit Post gefunden und dort war sie drin :)
Ich war der Meinung, ein paar Seiten weiter vorne hat jemand irgendwo eine Liste der unterschiedlichen Grössen aufgelistet. Leider finde ich diese nicht mehr, hat die noch jemand zur Hand?
Meinest Du diese hier?
Falls ja, diese habe ich in diesem Reddit Post gefunden.
  • Danke
Reaktionen: SH
Also so ein derber Größenunterschied war mir bis jetzt nicht bewusst, irgendwie GEIL! :> 13 heatpipes auch
War im Vorfeld schon zu vermuten. Wirkt aber im Vergleich krass. Gigabyte schießt mit der Aorus echt den Vogel ab.
In welches Gehäuse baut man diese denn ein? o_O Selbst ein nicht zugebautes Corsair 900D oder vergleichbar könnte da eng werden
Da war doch was... :ROFLMAO:
Ich kann mir nicht vorstellen, dass die Karte schlecht kühlt. Wirklich verlockend, so eine große Karte mal im Rechner zu haben.
Das find ich ein gutes Vid vom der 8auer
Ähnliche Themen
