• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
was für Taktraten hast du im Speedway?
Alles mit Gehäuseläufter auf Standard.. System leise.
FE in STOCK .. fängt bei 2700 Mhz an bis zur hälfte und geht auf 2685 runter
FE mit +200 Core und PT133% ohne Speicher OC bisher... fängt bei 2895 Mhz und geht runter auf 2880 Mhz
FE mit +100% Voltage, 133%PT, +250 Core ohne Speicher OC bisher... fängt bei 3015 Mhz an und geht runter auf 3000 Mhz
Ohne Voltage, stürzt die Karte bei +250 Core ab in speziellen Regionen bei Cyberpunk. Weiter hab ich noch nicht geschaut.. aber werd das auch nicht weiter Forcieren.. mein bequiet Dark Pro 10 750Watt quäle ich so schon. :d
Speicher hab ich noch gar nicht geschaut, aber ich werd da wenig rumprobieren.
Sollte ich tatsächlich das SF750 holen (was sehr wahrscheinlich ist), hoffe ich mal das Kabel kann man etwas mehr biegen als den Nvidia Adapter, ansonsten hab ich potenziell ein Problem:fire: haha
Sollte eigentlich biegbar sein wie jeder normale 8-Pin, da es "fast" ein 12-Pin zu 12-Pin ist. Aber Vorsicht ist besser als Nachsicht :d
Nutzt ihr eigentlich den Adapter der den Karten beiliegt oder eher zb das ne quiet Kabel? 12VHPWR , viele Grüße
viele nutzen den adapter weil sie kein be quiet netzteil haben :fresse2:
soweit ich das überblicke ist be quiet am schnellsten gewesen mit dem passenden kabel.
corsair und seasonic sind wohl noch nicht so weit.
Ich sag doch, das ist das Anti-Sag Feature...oder der Postbote saß auf dem Paket...
Ist halt echt traurig für den Preis, der aufgerufen wird.. deswegen ging meine Bananenkarte ja zurück an MF.. die können ja auch nix für, aber was Palit da für eine Endabnahme hat, ist mir Schleierhaft. Vllt sagen sie auch, ist nur der Kühler.. und macht nix aus.. Keine Ahnung. :)
Ich erwarte mein neues Gehäuse und auch diesesmal wieder ohne Seitenteil, wenn ich fein sauber verlege habe ich wenn ich richtig verstanden habe keinen Nachteil dadurch ausser aus ästhetischer Sicht , richtig?
ja, so würde ich das sagen.
Dann ist dein Silicon sogar ein bissjen besser als meins. 2700 ist bei mir auch Standard, aber die 3000Mhz stürzen bei mir mit 1.1V und offenem PL nach ca. 30 Sek im Benchmark ab. Und für die 2700 brauch ich leider 950mV. Hab ja von einigen Karten gelesen, die die 2700 noch mit 0,9 stable hatten.
ja, habe gelesen, dass es vereinzelt welche gab.
Ich kann dir nur dazu raten das Vorhaben bleiben zu lassen. Das O11XL ist sehr restriktiv bei Einbau von drei Radiatoren. Es macht keinen Spaß.
Was ist ein ABP Block?
Active Backplate… habe schon einige Systeme gebaut mit 4 GPUs aber eher funktional im zB. 1000D oder Server Rack und auf Xeon. Habe aber noch ein O11D XL hier stehen und finde den Matrix7 Ansatz mit den standardisierten Abständen und Distros eigentlich ganz charmant. Hier ein Beispiel mit drei Radiatoren - bei mir nur eben mit zwei GPUs.
Zur Not mit zwei Radiatoren (+Mora) aber auf Wasser muss ich die Karten bringen, sonst bekomme ich beide Karten logischerweise nicht rein. Später soll die 3090 einer zweiten TUF mit gleichem Block weichen.
Da sagst du was, habe schon überlegt ne Halterung auf der GPU Seite nur für das Kabel zu erstellen, und dann im 3D Drucker auszudrucken😂 Sieht auf jeden Fall recht stabil aus, etwas das man über den Nvidia Adapter nicht unbedingt sagen kann:d
Aber gut, vorher muss ich sowieso erstmal an ne FE kommen, was sehr wahrscheinlich der Endgegner sein wird:ROFLMAO: Das hat schon mit der 3000er Serie nie geklappt...
Vielleicht kannst du sie ja vertikal einbauen, dann sieht man es nicht. Wakü ist für die Lautstärke bei dem Trümmer echt nicht nötig, aber gibt ja noch einige andere Gründe das Teil unter Wasser zu setzten.
Ich kann es jetzt auch nicht sehen.
Das ist der Winkel, aus welchem ich auf den Rechner schaue:
Wäre wahrscheinlich niemandem aufgefallen, wenn ich es so kommentarlos hier reingepostet hätte.
.Anhang anzeigen 807078
Wow... die passt ja echt grade so rein, mm arbeit könnte man sagen😅
Aber sieht so echt nicht schlecht aus, sofern du da sonst keine bedenken hast würde ich sie behalten wenn ich du wäre.
Ja, mich kotzt der Kabelsalat unten auch an. Ist nur provisorisch, bis der 90° Adapter da ist.
Die Karte ist flüsterleise und läuft wie ne 1. Ich tendiere gerade wirklich stark dazu, die einfach drin zu lassen.
So siehts aus, grade das sie flüsterleise ist, ist ja bei vielen anderen Karten nicht unbedingt gegeben:d
Gigabyte 4090 gaming OC
Die Grafikkarte ist selbst im Desktop Betrieb auf einmal komisch am laufen. Sie blinkt die ganze Zeit und wenn die Lüfter angehen sind es nur die ersten beiden oder hinten der dritte. Dabei macht sie auch komische Geräusche. Als ob es so Schaltgeräusche sind kurz bevor die Lüfter angehen und ganz kurz noch am Anfang beim andrehen. Unter last ingame gehen auch alle Lüfter an und Sie verhält sich normal. Trat erst grade eben nach einem Spiel auf. Metro Exodus wurde gespielt. Karte hat sich da gelangweilt keine Ahnung was auf einmal los ist.
Der Link zeigt es
Danke euch
Ich hab auch die Gaming OC und HATTE die Geräusche auch am Anfang beim Benchen.
Wurden aber stetig leiser.
Hab es dann mal ohne Beleuchtung und ohne Afterburner probiert.
Beleuchtung hat keinen Unterschied gemacht, ABER ohne Afterburner (und einen Neustart) sind die Lüfter jetzt komplett ruhig.
Es laufen auch alle 3. Sobald ich Afterburner starte, höre ich direkt wieder leise das Geräusch und meist drehen nur die 2 Lüfter überm PCB.
Fix auf 40% Lüfterdrehzahl einstellen geht auch nicht, da laufen die Lüfter immer wieder an und stoppen.
Ist zwar echt nervig mit dem ständigen hochdrehen der Lüfter aus dem Zero-Fan Modus, aber lieber auf ein Bios-Update warten, als mit Afterburner mehr Probleme haben.
(Nutze das Silent-Bios.)
Weiß jetzt nicht, ob das was mit der GPU direkt zu tun hat, aber crasht bei euch auch A Plagues Tale Reqiuem jedes Mal wenn der Name des Studios im Intro erscheint?
(Und bitte keine krummen Bananen-Witze dazu!^^)
Halb ja auch die Game Rock und bei mir macht die keinerlei Probleme bei dem Game.
Wie ist deine sonst so? Hat sie das Lüfter Surren?
Das könnte eine riesen Scheiße werden.
Gibt es eigentlich hier viele Idioten wie mich, die sich eine verflucht teure Grafikkarte besorgen, nur um endlich vernünftig Cyberpunk 2077 spielen zu können aber am Ende Spiele spielen, bei denen eine 1070 in 4k gereicht hätte???
Liegt nur daran dass der Cyberpunk DLSS 3 Patch noch nicht da ist :shot:
Bei normaler Nutzung würde sowas niemals passieren und das Kabel überlebt dich mehrmals 😆
Ähnliche Themen
