[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Die FE hat das bessere PCB mit entsprechenden Bauteilen .Die Karte passt mit Luftkühler in mehr Gehäuse .
Die TUF hat den besseren Luftkühler und ist auch recht einfach auf Wasser umzubauen .
Asus bietet drei Jahre Garantie auf die Karte .
Aber nur über Händler und daher habe ich bewusst im Asus Shop geschaut .
Umbau auf Wasser kein Problem angeblich , wenn man wieder vernünftig zurück baut, wenn ein Garantie Fall Eintritt .Ein Garantie Siegel konnte ich aber auf einer Schraube entdecken .
Garantiesiegel spielen auf die 2 Jährige Gewährleistung keine Rolle. Problematisch ist es nur bei Händlern die auf die Beweislastumkehr nach 6 Monaten pochen, Mindfactory ist da zum Beispiel so ein Fall, die gerne mit sowas argumentieren.
Auch bei der freiwilligen Garantie des Herstellers kann dieser aber ein Grund sein diese zu verweigern, muss aber nicht und wenn Asus schreibt, man müsse den Kühler nur zurück bauen, dann sollte es in der Regel kein Problem das Siegel zu brechen. Anders geht es ja nicht.
An die RTX 4090 Besitzer:
Besorgt euch ein "Infrarot Thermometer" und lasst den neben der Grafikkarte immer griffbereit liegen, zum Überprüfen der Temperatur des genialen "12VHPWR" Stecker's.
Noch besser - eine Wärmebild-Cam. Die zeigt zu heiße Stellen sofort an. Bei IR muss man erst danach suchen ;)
Siegel mit Wasserdampf einnebeln und mit Pinzette abziehen
Achnl gottchen ist dieser jay auf das Thema aufgesprungen der hat sowieso keine Ahnung und von diesem anderem zoid Typen hatte ich mehr erwartet, es gibt Bilder von dem abgerauchten Stecker aber keiner der beiden hat näher nachgeforscht, nachgefragt einfach mal ordentlichen journalismus betrieben ob da vieleicht noch was anderes dahinter steckt...
Möglich das der Stecker problematisch ist aber sich auf Bilder zu beziehen und nichts weiter ist wahrlich die klickbyte Mutter und schnell verdientes Youtube geld
Edit
Es gibt andere News Seiten die gehen gesitteter damit um und nicht gleich mit Mistgabeln und haben sogar Kontakt zu den entsprechenden Benutzer aufgenommen
Naja wie auch immer wer zuerst das Video bringt hat die Klicks das 20te Filmchen dazu wird nicht mehr geschaut
Wenn es natürlich Probleme gibt dann muss das komplett geklärt werden
Ist zwar echt nervig mit dem ständigen hochdrehen der Lüfter aus dem Zero-Fan Modus, aber lieber auf ein Bios-Update warten, als mit Afterburner mehr Probleme haben.
(Nutze das Silent-Bios.)
Hast Du mal das OC Bios getestet und neuste Version AB ist installiert? Ich habe keine Probleme die Fans auf einen Fixwert oder eigene Kurve zu stellen im OC Bios mit AB (auch Gaming OC).
Edith: 40% sind zu wenig. 50% funktioniert 1a
Gibt es mittlerweile in Ger / EU die Möglichkeit ein 90° gewinkeltes 12VHPWR Kabel / Adapter von Cable mod oder einem anderen Anbieter zu bestellen?
Das biegen des Adapters kann dazu führen dass die Pins sich etwas herausziehen und dadurch weniger Kontaktfläche haben und somit (U=R*I) die entstehende Hitze zum schmelzen des Kunststoffes führen kann!
Jetzt postet der nächste den Bild-Hansel. Warum posten so viele irgendwas bevor Sie die letzten Seiten wenigstens überfliegen.
Bisher nur angekündigt, kannst dich aber bei Cablemod per Email informieren lassen, sobald der Adapter verfügbar ist. Kommt in 5 Tagen und 18 Stunden.
Klick mich
Weil ich nicht 24/7 hier reinschaue und dachte die Sicherheit überwiegt den Lesefluss. Ich denke dabei auch an andere die nur ab und zu hier reinschauen. Redundanz im Bezug auf Sicherheitsfragen sehe ich nicht als unnötig oder sogar als Ärgerniss an. Und jemanden dafür zu kritisieren halte ich sogar für weitaus schädlicher. Solche Hansel nerven in jedem Forum einfach nur ab. Das ist ein thread und kein fucking Lexikon.
Welches Case passt denn am besten für die 4090 ohne Kabelknickbull.hit und Riserkabel?
Spiele mit dem Gedanken auf die WaKü zu verzichten und den 12700K wieder mit Luftkühler zu betreiben.
nett, gestern abend 17.25 bei alternate bestellt, jetzt steht schon versendet... mal sehen wann das ankommt
Aloha. Hab da mal eine Frage. Bei mir werkelt eine 4090 zusammen mit einem 5800x. Spiele auf 1440p. Nun hab ich spaßeshalber mal in Cyberpunk alles auf Maximum gejagt und hatte so um die 70-80 FPS. Dann aktivierte ich DLSS in verschiedensten Konfigurationen, aber irgendwie bringt das nicht besonders viel. Eventuell einen Unterschied von 5-8 FPS. Woran kann das liegen?
Cpu
Das derzeit beste Case für Luftkühlung ist mMn das Fractal Torrent.
Nzxt h7 flow hat 185mm cpu Kühler höhe. Das ist brauchbar
Phanteks p500a. Da passt sogar ne WaKü rein.
Es bietet 190mm Platz für den CPU Kühler und du kannst sowohl in der Front, als auch oben einen 360er Radi verbauen.
Das Kabel meiner 4090 TUF sollte etwas mehr Platz als die vorgegebenen 3,5cm haben. Jedenfalls wird hier nichts von der Seitenwand abgedrückt :)
Alle die ein neues BT brauchen. Ich kann das Thermaltake Thoughpower TF3 1650w oder 1350w empfehlen - beide voll ATX 3.0
Ja sehe ich auch so. Ist auch für WaKü super, weil Du vorne einen Dual 180mm Radi rein bekommst und einen 280mm am Boden
Guten Morgen zusammen,
ist das normal, dass die Lieferung bei CableMod so lange dauert?
England?
Zoll nicht vergessen :fresse2:
Ähnliche Themen
