[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wie Custom-Wakü Leute habs da gut, können gleich ne Mini Sprinkleranlage miteinbauen oben im Deckel :fresse:
Besser was mit Stickstoff. :) Wasser ist schlecht wenn Strom dabei ist....
Eigentlich wollte ich heute vernünftig dokumentieren was passiert ist und wie der Händler reagiert hat, damit andere auch etwas davon haben.
Aber nach den Kommentaren habe ich keine Bock mehr mich zusätzlich zu dem Ärger und dem Schaden auch noch zu rechtfertigen.
Also bockiges Kind und jetzt gar nichts liefern? Finde ich mehr als nur schade, da das Thema gerade auch in der öffentlichen Wahrnehmung groß diskutiert wird und es durchaus gut zu wissen (oder sehen) wäre, wie genau das bei den Leuten aussah und wie es weitergeht.
Und weckt natürlich mehr Zweifel, dass da doch nichts war, wenn du dich jetzt so verhalten tust.
Wen interessiert die Karte, verrate lieber wie du Warzone 2 gespielt hast!
Natürlich nicht ernst gemeint... Falls du wirklich betroffen bist freuen sich sicher alle über mehr Informationen :)
@reggie gakil
Was sagst du zum Video von JayzTwoCents?
Wäre wirklich gut zu wissen wie deine Karte ausschaut. Anhand des Schadens kann man eventuell Rückschlüsse ziehen wo es angefangen hat.
Was ich erstaunlich finde ist dass die Karte überlebt hat.
Meine?
@reggie gakil
Seine Vermutung das ich das Kabel zuvor sehr stark gebogen habe ist falsch
Danke für dein Feedback reggie gakil. Scheint ja echt so, dass das Kabel u.U. sehr fragil und empfindlich sein kann. Meiner Meinung nach ist dieser 12VHPWR Kram eine Fehlplanung.
Hoffen wir mal, dass es kein Massenphänomen ist und du vielleicht einfach ein schlechtes Kabel erwischt hast. Die Zeit wird es zeigen.
Bei der Art wie reggie gakil die Karte verbaut hat, muss er nix manuell biegen.
Das passiert quasi alleine bzw die Peitsche spreizt sich. Es ist schwierig.....
Hm, meint ihr echt nvidia würde die Steckverbindung nicht testen bzw den Stecker auf das was es machen soll auslegen
Aktuell wurde ich mal davon ausgehen der Stecker ist fein wie er ist wie wäre die Theorie das die Steckverbindung bei dem neuartigen Stecker von einigen unseren einfach nicht richtig gesteckt wird?
Vieleicht ist der männliche weibliche Seite so strack beim stecken das viele meinen er ist schon sauber drinne aber dennoch immer der Rest fehlt, die ursprünglichen Stecker bei 3090/2080ti partnerkarten mit 6+2 Pins hatten ein hacken der einrastet..... So mal als Grundgedanke man meint er steckt voll drinne und es fehlen doch 2-3mm.... Macht viel aus
Wenn wir ehrlich sind sind die Kabel nur an den Stellen geschmort wo es die Verbindung gibt nich 5mm oder weiter hinten am Kabel wo man potenziell knickt
Wäre doch einfach von inflluenzern das Kabel ziehen nicht ganz stecken und sehen was passiert, denn die sau vom Kabel biegen sei schlecht wird arg strapaziert
Wenn sagen wir mal bei einem cm hinter dem Stecker man anfängt es zu biegen bzw zu verlegen ohne zu zerren is das doch normal und kein problem
Einfach mal paar litzen in die hand nehmen mit zwei Finger halten und wenn die zwischen den Finger austreten stampft zu biegen anfangen, ich fuhl da kein Zug auf irgendwas
Helft mir mal lieber bei meinem problem.
Ich brauche eine Entscheidung...
Option A:
ASUS TUF OC
Pro:
VRAM OC bis +1500
Core +220
BIS 600 Watt
Super verarbeitet und top Kühler
2x HDMI 2.1
Gute Spannungsversorgung
Contra
Nerviges spulenrasseln
Preis 2299 euro
Option B
Gainward Phantom GS
Pro:
Günstig 2000 Euro
Kühlleistung gut
Kein spulenrasseln
Core +220 MHz
Contra:
Ein Lüfter mit Lager Geräuschen, egal bei welcher drehzahl
Für 2000 Euro zu viel plastik
Nur 1x HDMI 2.1
schlechtere spannungsversorgung
VRAM nur bis +1250 mhz
Powerlimit 500 Watt
Für welche würdet ihr euch entscheiden?
First World problems....
Eben, enau dass seh ich auch so. Die einzelnen sind super flexibel aber sobald man alle 4 in der habe hat sind die störrig
Fakt ist sowas darf nicht passieren vorallem nicht dann wenn keine Anleitung oder Ähnliches beiliegt
Seh ich auch so.
MSI hat bei dem Adapter auch nur aufgedruckt wie man ihn am Netzteil anschließen soll, aber nicht welche Biegeradien kurz hinter dem Stecker zu unterlassen sind..
Thja ist deine Entscheidung. Müssen wir so akzeptieren. Schade eigentlich weil die Leute die dich versucht haben zu diskreditieren, damit jetzt Erfolg hatten und sich auf die Schulter klopfen. Sieht man ja man schon wieder am User @reggie gakil der wird so lange malträtiert bis er Beweise abliefert dass er auch tatsächlich der echte ist.
Du bist scheinbar noch nicht so lange hier aber so ging es schon immer hier zu, gerade bei so heiklen Themen. Ohne Proof = Troll.
Ich erinnere mich noch sehr gut an die umgedrehten Speicher Kondensatoren die abgefackelt sind beim Asus Z690 Hero (link) vor zwei Jahren. Da haben hier gewisse Leute bis zum bitteren Ende, als es schon offensichtlich wurde dass es vermutlich an den umgedrehten Caps lag, felsenfest ihre Meinung vertreten, dass der User sein Mainboard ohne Abstandshalter angeschraubt hat. Die glauben das bestimmt noch bis heute. :lol:
Bei mir stand es auf 90%, aber auf Anschlag, ich konnte also nicht auf 100% gehen.
Habe jetzte das Original Strix Bios Update von Asus gemacht und jetzt hab ich 100%, aber eben auch auf Anschlag und nicht wie du mit Platz nach rechts um es zu erhöhen.
Die Benchmarks sind auch wieder gleich schlechter als sie mit meinem PC sein sollten.Die
Wurde doch seitens Nvidia bereits so kommuniziert
Wurde das wirklich so geschriebene oder ist das aus dem Kontext gerissen oder fake, kann das nicht glauben.... Dann wären alle anderen Kabel raus sowie neue netzteile mit passendem Kabel wenn man nur den original Stecker nehmen würde bzw sollte.... Halte das auch für eine Ente
Bin ich ja Mal gespannt
Endlich ist meine Suprime bei mir eingetrofen.
Ist nicht so einfach gewesen das Kabel so spannungsfrei wie möglich zu verlegen . Grade auch mit der Steckerprolematik...
.aber mit Geduld und etwas Zeit.
Zum Spulenfiepen kann ich sagen , ja klar hat sie auch. Ist aber sehr, sehr leise. Habe einen sehr leisen Rechner und da hört man jedes laute geräusch.
Bin also auch damit zufrieden. Bin froh das ich wohl Glück mit dem Model hatte.
Nochmal eine Frage an alle: Hattet ihr nicht auch das Gefühl, dass man ungewöhnlich viel Kraft benötigt, um sicher zu gehen, dass das Kabel zu 100% in der GPU steckt, ohne das dabei noch irgendeine Lücke zu sehen ist?
Laut Cablemod werden deren Adapter für Asus und Seasonic unter einer Bestellnummer zusammengefasst, damit sollte das Seasonic auch an ein Asus NT passen oder hab ich da gerade einen Denkfehler? Asus NT müßten demnach Seasonic NT sein.
ASUS lässt seine Netzteile bei Seasonic bauen. Das passt also.
Jepp. Liegt aber denke ich an dem Steckerdesign ansich - zumindest habe ich es in dem Moment darauf geschoben...(BeQuiet)
Da sich auch bei mir der Radius nicht Ideal verhält mal ein Foto davon - bisher merke ich dort aber keine Probleme.
Ach was, normaler biegeradius kein Knick hier zusätzlich zum Stecker mit Pins halt der Schrumpfschlauch die Pins fest im Stecker, wenn dein Stecker ordentlich drinne ist wird wohl alles io sein
Wenn so viel Panik verbreitet wird ich hoffe keiner ladet seine Akkus über Nacht und ohne Aufsicht
Ja. Ich habe (hier einzige?) ATX 3.0 Netzteil von TT 1350. So zusagen O. Kabel. Und der geht sehr schwer in GK rein.
Ähnliche Themen
