[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Danke, erstmal.
Ja Karte Lüft mit PCIE4 16 , RBar ist Aktiviert , Windows und auch Nvidia Energie Pläne sind alle auf Ultra bzw Hoch , und ja die Kiste läuft auf nem Z690MB, anders Bios kann ich nicht nehmen weil sonst kein Raptor Lake Support, Intels ME ist auch Aktuell.
Danke, erstmal.
https://www.hardwareluxx.de/index.p...3900k-und-core-i5-13600k-im-test.html?start=1
hier wird das mit den Leistung auf Z690 (betrifft auch nicht alle Boards :d) auch noch erwähnt, aber wenn es bei dir nur in einem Benchmark so ist, wirds wohl kein generelles Problem sein.
@Brainscan1979
So dann versuch ichs auch noch mal hier. Ich habe gestern meinen 13900K bekommen, ding rennt wie sau nur hab ich ein Problem , den Score im Fire Strike ( nicht ultra oder extrem , der normale ).
Habe am Dienstag noch fix nen Run mit meinem 12900KF und meiner Suprim X gemacht und rausgekommen sind 55k Pkt, CPU am Mittwoch gewechselt, ausgelotet 5,8 auf allen P-Kernen und 4.5 auf E-Core und Ring. So direkt mal paar benches gefahren und siehe da in fire Strike nur noch 45K punkte. Um die Geschichte kurzt zu machen egal welcher Bench egal was ich machen, in den Ratings von 3dMark bin ich immer +-Gut dabei NUR der Firestrike da bin ich absolut letzter. Getestet, etc gemacht , sogar mal Windows neu aufgesetzt nix, 45k.
Jetzt meine Bitte an euch, könnt ihr die eine 4090er und einen 13900K haben den Firestrike mal durchlaufen lassen und mir die Ergebnisse schicken ?
und vorallem Suprim X besitzer mit einem 13900K. Ich danke euch.
13900K 5.5 allcore + 4090 FE
Sorry aber dieser Typ hat wirklich nicht viel Ahnung. Stellt als Test Games zur Verfügung welche oberhalb des Gsync Bereichs laufen und tearen!!!
Wie soll man da was testen ob es gut ist? Werde dazu heute ein Video machen wie man es richtig einstellt und man dann sieht das Dlss3 und FG ein echter Gamechanger in einigen Szenarien ist.
Mit diesem Kabel:
Bräuchte man ja noch ein dual female adapter.. aber soviele Übergänge und lange Kabel...
Da warte ich lieber auf den 90 Grad cablemod.
Wenn man die Karte < 300 Watt fährt (ob per pt oder uv egal) ist man damit erstmal Safe? Woher "weiss" ich denn dass die Last über alle 6 Pins geht und nicht ungleichmäßig?
Wenn die Karte nur bis 300 Watt anfordert, dann ist die Chance geringer das bei 2 Ader ausfällen die 2 funktionierenden Adern (welche für 300 Watt ausgelegt sind) kollabieren.
Oder wenn noch alle Adern einigermaßen funktionieren diese geringe Last besser verteilt ist, da weniger Hitze und Widerstand.
Zudem sind bei UV auch die Spikes also Lastspitzen geringer.
Also Fazit , das System der Steckverbindung ist problemlos (viele haben den kleinen Stecker verteufelt ) nur die Verarbeitung war schlampig
So wie es von dem selben Stecker einen teuren und billigen geben kann von aussen sehen beide gleich aus aber im inneren wird gespart
Nachricht gelöscht
Naja du kannst davon ausgehen, das alle beigelegten Adapter Stecker vom selben Hersteller stammen, welche eben Pfusch sind.
Ich bezweifle es das es eine Serienstrueung gibt, und selbst wenn ist das sehr schwer nachzuverfolgen. --> deswegen werden vermutlich alle Adapter bis dato einkassiert werden.
Bei den Steckern der Netzteilherstellern/Cablemod gibt es wohl keine Probleme.
Vlt. hättest du das Video etwas länger schauen sollen, denn er erwähnt später, dass er in Plague Tale immer unterhalb der 144Hz des Monitors bleibt... also egal ob mit oder ohne DLSS.
Ich finde ihn bei genauer Betrachtung arrogant und schnöselig
Und sein Charakter hat genau was mit seiner Kompetenz zutun?
Du kannst von ihm halten was du willst, aber der Typ hat nachweislich mehr Know how als du und @***** zusammen und genießt nicht ohne Grund so ein hohes Ansehen bei seinen Kollegen (Jay, Gamers Nexus, LTT,...)
Nachricht gelöscht
Naja am Anfang sagt er etwas anders. Zudem könnte er einen Framelimiter nutzen oder Vsync im NVCP einschalten. Habe alles getestet. Funktioniert wunderbar. Mehr dazu in meinem kommenden Video. Kannst den Kanal schon mal abonnieren damit du es mitbekommst. Dirk Pajonk bei Youtube
Puh, das hätte ich nicht gedacht, dass da ein so eklatanter Konstruktionsfehler hintersteckt.
Igor schreibt ja auch, dass er davon ausgeht, dass nVidias Ingenieure den konkreten Aufbau des Stecker-Adapters nicht kannten. Ob jetzt ein Zulieferer gegen Spezifikationen verstoßen hat, nVidia nicht genug getestet oder genau genug spezifiziert hat – das weiß man natürlich nicht.
Der Schaden ist angerichtet, hoffentlich geht er auch schnell aus der Welt. An und für sich denke ich schon, dass eine Produktion neuer Adapterkabel innerhalb einiger Wochen durch sein sollte.
Aber direkter Austausch durch die Boardpartner oder Händler ist dann das Mindeste!
Gibt es eigentlich neben dem Lovelace-Verfügbarkeits-Bot jetzt auch einen nVidia-Ersatz-Kabelpeitschen-Verfügbarkeits-Bot?
Im Büro, der Chef hört Schläge auf eine Tastatur und macht sich auf den Weg, den Unruhestifter zur Rechenschaft zu ziehen. Er kommt zu einem Mitarbeiter mit arbeitsfremdem Inhalt auf dem Bildschirm.
Chef: "Machen Sie etwa Online-Shopping während der Arbeit?"
unangenehmes Schweigen
Chef: "Was gibt es denn für ein schönes Schnäppchen?"
Mitarbeiter: (zitternd, mit aufgerissenen, geröteten Augen – wie ein Junkie auf Entzug) "Schnäppchen?! Ich BRAUCHE diesen Kabel-Adapter für 200€ damit mir die verdammte Bude nicht abfackelt!"
Der Chef geht möglichst unauffällig weg und macht den Rest des Tages einen Bogen um den Mitarbeiter.
Mitarbeiter: (kopfschüttelnd) "Schnäppchen..." Der Mitarbeiter hämmert weiter auf F5.
Ich mag den Roman,hat Ahnung von der Materie und verdient gutes Geld.
Denke das bei einigen hier der pure Neidfaktor ne große Rolle spielt,wird z.B. halt nicht jeder zu OC Events von Intel und AMD eingeladen.
Falls es neue Adapter gibt sollte es bei dem aufgerufenen Preis auch möglich sein 2 Stück pro Box beizulegen oder wenn man bereits eine 4090 hat diese nachträglich kostenlos zu bekommen.
1x grade, 1x 90° Winkel. Das würde zwar Cablemod nicht gefallen, aber vermutlich allen anderen.
Ich hatte mir ja die Inno3D X3 OC und iChill bei Coolblue gekauft - ich bin echt begeistert von den Karten und das für den Preis (jeweils 1.999 Euro):
Die X3 OC liegt bei Default 2580 MHz - bei 1.1 Volt bei 2850 MHz (ohne OC)
Die iChill liegt auch bei Default 2580 MHz - bei 1.1 Volt bei 2910 MHz (ohne OC)
Bei der X3 OC konnte ich +150 / +1400 OC machen - Speedway 10528 Punkte
Bei der iChill konnte ich +195/ +1400 OC machen - Speedway 10609 Punkte
... und das jeweils mit knapp 450 Watt (mehr geht bei den Karten leider nicht)
Weiteres Feintuning habe ich noch nicht gemacht - aber bei der iChill gehen schon einmal 3100 MHz :-)
Jup sieht gut aus :)
Wärst du mal bitte so freundlich nen 3DMark PCI Test laufen zu lassen? Ich hab meine 4090 im Riser und mich würde mal der Vergleich zu non Riser interessieren.
Die haben jetzt aber euch die Preise angehoben :-)
Wer hatte noch getönt, die Situation sei nicht mit dem Release der 3090er vergleichbar, es seien genügend Karten an die Händler ausgeliefert worden bzw auf dem Weg?
Es ist auch nicht annähernd mit dem 30er Release vergleichbar.
Bei 4090 gabs jetzt teilweise Zeitfenster von über 30-60mins wo man eine Karte kaufen konnte. Da war bei Ampere nicht ansatzweise dran zu denken.
Wer hier etwas aufmerksam die Verfügbarkeitsmeldungen von ralles Bot verfolgt hat, war locker in der Lage eine Graka zu bekommen.
Man muss evtl auch den 30er Release in 3090 und Rest aufteilen. Damals eine 3090 zu bekommen war meiner Meinung ähnlich einfach, wie jetzt eine 4090. Nur die günstigen waren schwierig.
Ähnliche Themen
