[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So nochmal zum FE Drop von heute. Das Ding ging ne halbe Stunde später in den Versand. Auffällig zu meinem Versuch am 12.10.22, dass die Artikelnummer (A 996979) eine andere (A 997429) ist. Könnte sich also sehr wohl um einen Rückläufer handeln zumal sonst keiner irgendwas gesehen bzw. gehört hat.
Wisst ihr ob die FE versiegelt ist? Ich meine gelesen zu haben, dass dem nicht so ist, was natürlich doof wäre um einen Rückläufer zu entlarven.
RE: Boost-Kurven... Ich habe hier vor einigen Tagen meine ganz guten Werte gepostet:
Nach einer Neu-Installation von Windows habe ich "nur" noch 2820/2895. Was da los? :oops::unsure:
Der Karton ist an den Seiten zugeklebt :d
Ich bin ja mal gespannt wie ein Flitzebogen wie sich der 5800X3D im Vergleich zum 5900X schlägt. Bei 5120x1440 hänge ich bei so vielen Spielen im CPU Limit, hätte ich nicht gedacht. Freitag soll das Teil kommen.
Habe heute den Wechsel gemacht, bei mir läuft 7680x1440, auch oft im CPU Limit mit dem 5900x, hab vor dem Umbau mal den SOTR Benchmark laufen lassen in niedriger Auflösung.
Das sieht doch schon ganz gut aus, bei meinen Simracing Game waren es auch 25 FPS mehr in niedriger Auflösung, sollte sich dann ja auf die Hohe Auflösung übertragen.
für nen knappen taui ist das echt ok wenn man mit 120hz und 42" aufm schreibtisch klar kommt
Am 24.10. bei Alternate bestellt und am 26.10. wurde sie schon geliefert. Und das zur UVP. Zum Glück auch kein Rückläufer. Alles frisch versiegelt und eingeschweißt.
Aber alleine die Größe im Vergleich zu einer Kreditkarte ist schon beachtlich.
In 3 Wochen kann ich sie dann endlich testen. 😂
in 3 wochen? wenn die karte fiept wie der geier sind die 2 wochen rum. viel glück :d
Mein PC ist leider gerade 800km entfernt von mir. Hoffe das grob alles mit den Lüftern passt. Fiepen scheint ja eher ein Problem von den Karten zu sein, die mehr Phasen haben.
Und dann mal testen ob ich den 12600K noch durch den 13700k ersetzen muss.
Wird aber vermutlich keinen großen Unterschied machen bei min. 3840x1600.
Bei Alternate hast du 30 Tage Rückgaberecht.
Dann kann er die Karte aber vorher nicht Probehören, denn die 30 Tage gibt's nur bei unbenutzten Artikeln. ;)
Ansonsten hat er zum testen nur die regulären 14 Tage Zeit.
Nein. ***** hat schon recht damit. Beispiel:
Die TUF non OC die ich aktuell da habe, hat ein Stock Boost wie oben bereits geschrieben von 2775Mhz.
Wohingegen ich eine TUF OC da hatte, die bei mittleren 2600Mhz blieb.
Die Chipgüte entscheidet. OC Karten sind Verarschung pur, solange der Hersteller die Chips dafür nicht selektieren würde (was sie nicht machen).
Das war überhaupt nicht meine Frage, dein Beispiel bezieht sich auf zwei unterschiedliche Karten.
Die eigentlich Frage war ob die gleiche Karte mit OC Bios um +45Mhz höher boostet. Wenn es nicht so wäre, dann wäre das ein astreiner Scam.
Boostet sie jedoch um +45Mhz dann ist die OC Version legit, denn garantiert werden dir ohnehin nur 2520 bzw 2565 (OC) MHz, was da oben noch rauf kommt, ist quasi ein Geschenk des Lootgottes und das ist natürlich abhängig von der Chipgüte.
Aus den Alternate-AGBs.
5. Freiwilliges Rückgaberecht
Der Verkäufer, bietet dem Kunden, der Verbraucher ist, unbeschadet der dem Verbraucher gesetzlich zustehenden Rechte das nachstehende freiwillige Rückgaberecht an: Sämtliche Produkte können Sie innerhalb von 30 Tagen ab Erhalt der Ware an den Verkäufer ohne Angaben von Gründen zurücksenden. Die Rückgabefrist beträgt 30 Tage ab dem Tag, an dem der Verbraucher oder ein von Ihnen benannter Dritter, der nicht der Beförderer ist, die Waren in Besitz genommen haben bzw. hat.
Weil UW und ein 38 Zoller einfach die perfekte Größe und das 24:10 das bessere Format ist. 42 Zoll 16:9 ist für PC, auch Anwendungen, nicht optimal. Zumindest nicht, wenn man mit M+T direkt davor sitzt. Habe selber den Vergleich zwischen 38 Zoller und 65 Zoll OLED von LG. OLED hat seine Vorteile. Hätte an deiner Stelle dann aber auf die neueren großen UW OLEDs gewartet.
Also ich hatte davor einen 35 Zoll 16,9 und war irgendwie glücklicher. Vielleicht ist das aber auch einfach nur Gewöhnung.
Und warum zitierst du den Rest nicht? Da steht noch mehr. ;)
Das freiwillige Rückgaberecht gilt für Waren die unbenutzt, unbeschädigt und vollständig in Originalverpackung sind. Das Freiwillige Rückgaberecht gilt nicht für:
  • Bild-, Ton- und Datenträger, CDs, DVDs, Software, soweit deren Versiegelung bzw. Verpackung geöffnet oder sie online heruntergeladen wurden;
  • Sonderbestellungen des Kunden, wie z. B. für den Kunden bestellte Ersatzteile etc.;
  • Waren, die nach Kundenspezifikationen angefertigt werden oder eindeutig auf die persönlichen Bedürfnisse des Kunden zugeschnitten sind;
  • Waren, die nach Kundenspezifikationen aus Standardkomponenten konfiguriert werden, wie z. B. individuell konfigurierte Computer, Hardware mit/ohne Softwareinstallationen,
  • von Kunden aufgebaute Bausätze und solche Teile, die vom Kunden bereits eingebaut werden;
  • Batterien, Akkus, Kabel, Leuchtmittel, Hygieneartikel oder ähnliche Artikel, soweit deren Versiegelung oder Verpackung geöffnet wurde;
  • Meterware, Verbrauchsmaterialien;
Ähnliche Themen
Antworten
6K
Aufrufe
392K
