[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So viele Unboxing wie es gibt müssen die Karten aber echt gut Verfügbar sein.
Ich denke bei den Customs könnte jeder was bekommen. FE und Strix könnte schwierig werden.
Die Gigabyte Master hat was aber iwie ist Gigabyte stehen geblieben. Die Headpipes Kupferfarben. Plastikbomber Abdeckung und das auch noch matt. Verpackung auch wie gewohnt.
Das glaubst ja wohl auch bloss du. Die verfügbaren Karten haben eben die Reviewer :shot:
bei den preisen kann es sicher keine verfuegbarkeitsprobleme geben.
sicher ne? sicher? sicher ne?
Siehe Foto unten 😉
Ich versteh noch immer nicht warum Corsair hier nur zwei Anschlüsse braucht, während die beiliegenden Adapter immer 4x 8Pin PCIe Anschlüsse hat? Kann mir das Jemand bitte erklären!?
Weil das Netzteil anders angesteuert wird. Das Kabel ist in der Lage zu sagen, dass es 300W pro Stecker haben will, anstatt 150W. So habe ich das verstanden :) vielleicht ist ja jemand schlauer.
Na wenn panic geschürt wird, wie du vermutest, dann sind wir eben doch wieder bei knapper Verfügbarkeit und hohen Pricen. ;)
Nein, dann sind wir bei Leuten die vor lauter Angst, sie könnten beim Release leer ausgehen und dann Monate warten müssen, jedes Wort überinterpretieren und in den Panikmodus gehen. Das ist nicht notwendigerweise die Realität, es gehören immer zwei dazu, jemand der einem was erzählt und jemand der es sofort blind glaubt auch wenn es keinen Sinn macht, nur weil es seine Ängste bestätigt.
Man hört was man hören will. Hier klingt es immer so als kloppen sich am 12.10. um 15 Uhr 10.000 Leute um 5 Karten. Und da kann ich nur den Kopf schütteln.
Ich glaube nicht, dass genug Stückzahlen rumliegen werden. Dank Weihnachten wirds auch nicht einfacher. Die Preise werden eher stabil bleiben.
Und ich glaube das es genug Karten geben wird, wenn man nicht auf ein ganz bestimmtes Modell fixiert ist und nicht unbedingt in der Releasewoche schon eine zu Hause haben muss. Ich bin immer noch davon überzeugt das spätestens im November jeder Interessent irgendeine 4090 bekommen kann.
Ich versteh noch immer nicht warum Corsair hier nur zwei Anschlüsse braucht, während die beiliegenden Adapter nahezu 4x 8Pin PCIe Anschlüsse haben? Kann mir das Jemand bitte erklären!?
Weil die Terminals im Netzteil problemlos 300W pro 8-pin liefern können wenn sie hochwertig genug sind. Die 150W pro Stecker beziehen sich nur auf die PCIe Spezifikation der 8-pins der Grafikkarten, die sollten eigentlich so ausgelegt sein, daß sie nicht mehr als 150W ziehen, weil der Hersteller ja nicht weiss welches Netzteil der User hat. Der Netzteilhersteller weiss aber selber am besten welche Leistung seine Terminals wirklich ausgeben können. Über die Sense-Pins wird der Karte dann mitgeteilt, das sie 600W abrufen darf und das Netzteil liefert. Corsair sagt ihre Terminals schaffen problemlos 300W for 8-pin Terminal also lösen sie das wohl mit zwei Steckern.
Die "female" Seite am Netzteil konnte immer schon 300 Watt. Darum hat z.B. mein Seasonic 3x dieses Y-Kabel wo am anderen Ende 2x8pin (á 150 W) in eine GPU geht.
Das ist sooo bekloppt... :fresse: Aber geil :d
ASUS TUF 4090 vs TUF 3090. Ein teurer Spaß, wenn neben der schon sehr teuren 4090 und NT noch ein neues Case her muss (und die Arbeit damit :rolleyes2:)
Bei der kleinen 3090 TUF waren sogar noch heiße Chips auf der Rückseite. Die 4090 wird nach dem Bericht von Igor heute einfach nur ein überdimensioniertes Kühlungsmonster sein.
Jucken mich alle nicht...
Wenn der Trümmer zerlegt wurde, wiegt der "nutzbare" Teil nur paar hundert Gramm, die mit viel Kupfer gepaart werden
Zusammen gebaut wird das Ganze wohl weniger wiegen, als die Stock-Strix/-TUF :d
@Dwayne_Johnson Geht mir doch ganz ähnlich. Eigentlich brauche ich nur das PCB und dann kommt eh der Wasserblock drauf.
Meine guten Vorsätze für diese Generation waren aber erst gar nicht so ein Luftkühl-Monster zu kaufen. Nicht mal vorrangig wegen dem Preis, es wäre hier einfach Verschwendung die ich gern vermeiden würde. Mal sehen ob nächste Woche Plan A mit der Inno3D funktioniert.
Ansonsten Plan B 8-)
Interessant - die Strix ist „kleiner“ als die TUF :oops::ROFLMAO:
(war das bei der 3090 auch so?)
  • 4090 ASUS Strix OC = 3,743 Liter
  • 4090 ASUS TUF = 4,045 Liter
  • 4090 Gigabyte Aorus Master = 4,383 Liter
Sagt natürlich nichts über die Kühlleistung der TUF aus
Und krass, dass die Strix 0,64 Liter kleiner ist, als der Mega-Trümmer Aorus Master
Ich rechne mal kurz…
Strix OC für ca. 2.500€ + Optimus Absolute 500-600€ = 3.100€ :d
Holy shit. Hier wird ja schon die ganze Zeit gewitzelt, aber ich habe mal nachgemessen und festgestellt, dass die meisten Luftkühler dieser Generation bei mir tatsächlich nicht passen :eek: Absolutes Maximum ist 34cm, habe halt noch einen klassischen Big Tower und keinen "leeren Glaskasten" wie sie seit einiger Zeit modern sind...
Damit hat sich die Qual der Wahl praktisch erledigt, evtl. die Gigabyte Windforce falls sie 600W hat oder halt doch die olle FE mit dem angeknabberten PCB. Was ein Schrott ey :(
Naja theoretisch noch MSI Trio oder Inno/Palit, aber die scheinen vielleicht nur ein 450W BIOS zu haben. Ich weiß nicht wo Geizhals diese Info her hat, aber es scheint mir plausibel zu sein, nachdem diese Karten tatsächlich nur mit einem 3x 8-Pin Adapter ausgeliefert werden, während alle anderen den 4x Adapter haben.
  • Danke
Reaktionen: SH
Habt ihr bei PayPal mit später bezahlen oder auf Rate gekauft? Ich würde da aufpassen. iwo war mal was von einem Limit gestanden. Ab 5k oder 10k Gesamtraten lehnt PayPal in manchen Fällen oder immer (weiß es nimmer) weitere Ratenzahlungen ab. Also nicht jetzt schon dafür sorgen dass man am 12.10 keine Ratenzahlungen oder später Bezahlen mehr machen kann^^
Danke für den Tip :)
Ist alles im grünen bereich, war nur ne zahlung nach 30 Tage die ich heute auslösen will. Also PayPal ist für den 12.10 Clean :)
@Youngtimer Technisch nichts, die ist mit ihrem PCB halt einfach nur extrem hässlich unter Wakü 🤷‍♂️
Liquid Metal hast du vergessen da darf nix anderes drunter!
Die ganze andere Pampe kannst vergessen!
Wo bei ich mich schon frage wie gut die Temps bei diesen Luftgekühlten Monstern werden !
Könnte mir vorstellen, dass überlange Karten wie die Strix letztlich besser zu bekommen sind, weil sie kaum einer ins Gehäuse bekommt.
Bei mir gehen auch nur Karten bis maximal ca. 340cm rein, was die Auswahl schonmal stark einschränkt. /:
In mein H7 Flow passen wohl 400mm Karten rein. Die 5095 Ti GX2 kann kommen. 8-)(y)
Hab mal ne kleine Aufstellung gemacht was Proshop lagernd hat…. Ich kann mir nicht vorstellen dass es einen Engpass gibt. Nbb Mindfactory und Alternate bekommen bestimmt noch mehr Karten .
Ist ja auch noch zeit bis zum Verkaufsstart, da kommt bestimmt noch was bei
ASUS GeForce RTX 4090 ROG STRIX OC +15
MSI GeForce RTX 4090 GAMING TRIO. 5
ASUS GeForce RTX 4090 TUF. +15
GIGABYTE GeForce RTX 4090 GAMING OC. +15
GIGABYTE GeForce RTX 4090 WindForce +15
Nach dem Video von Igor bin ich mit mir am hadern ob ich nicht doch eine Masters in mein Lian Li Lancool 2 stecke
Das fette Teil passt da rein und die Chibbi Figur ist bestimmt auch wieder schnieke 😄
Alternate und MF sind halt auch mal wieder spät dran mit ihrem Sortiment. Vor allem MF lässt sich da echt jedes Mal Zeit ohne Ende.
Ähnliche Themen
