[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Auch wenn du es mir nicht glauben wirst, aber ja das könnte natürlich sein. Das könnten auch die ganzen nicht verkauften Scalperkarten sein. Sinnlos sich darüber Gedanken zu machen. Wirst sehen was kommt.
Oh, dachte das wird dann als B-Ware verkloppt. Woran sieht man das ist halt die Frage und welche Optionen hat man - außer Weiterverkauf.
außerdem: wenn es ungeöffnete sind von einem Weiterverkaufsversuch ist da eh kein Unterschied.
Seltenst. Meistens geht das 1 zu 1 als Neuware raus
Es wird wie üblich jeder ein Bild von der Karte posten und dann kannst du dich mit allen darüber austauschen ob es aufkleber links rechts unten und oben gibt und was in Folie wie verpackt ist. Wenn du darauf Lust hast.
Na mensch Glückwunsch gleich 7 AB's für die FE bin auf eure Posts gespannt wenn Ihr Sie in den Betrieb nimmt :d
Es gab ja genug flatternde Lüfter, fiepende Karten und Karten die an die Youtube Elite gingen ;-)
Aber ich glaube das machen die bei Nvidia nicht!
Nebenbei ich habe KEINE FE zurück geschickt ... ich habe eine die "defekt" ist UEFI Splash nicht anzeigt.
Und die schicke ich, auch wenn jeder sich aufregt, vermutlich zurück ... falls Nvidia sich nicht rührt!
Bin überrascht, dass wir hier kaum" STORNO SO EINE SCHEI*E" Meldungen bekommen haben. Letztes mal war das Verhältnis Storno zu AB ja irgendwo bei 60:1.
Danke Euch Jungs, dann fahr ich jetzt mal los nach Laatzen mit meiner Hermes Karre :fresse:
Es gab ja genug flatternde Lüfter und fiepende Karten und Karten die an die Youtube Elite gingen ;-) aber ich glaube das machen Nvidia nicht!
Kein Plan was du mir mit dieser Aussage sagen möchtest
Und die schicke ich auch wenn jeder sich aufregt vermutlich zurück falls Nvidia sich nicht rührt!
Sei klüger und kommunizier es einfach nicht. Selbst wenn du 30 Karten zurückschickst muss das keiner Wissen. Du bist selbst schuld wenn du dafür angegangen wirst.
Das ist Ironie oder?
Also da ich derjenige bin der ohnehin schon gesteinigt wird deswegen dachte ich ... ich mach den Witz.
Ist der Ruf erst ruiniert dann lebt es sich ganz ungeniert
*ACHTUNG EIN WITZ*
Hier ebenfalls AB um 12:50 gekommen, nice
Ganz ehrlich? Das würde wohl jeder so machen. Auf einer defekten Karte würde keiner Sitzenbleiben. DA finde ich es auch völligst in Ordnung. Gerade wenn man vorher versucht noch einen Support zu erreichen und eine blöde Antwort bekommt.
Arbeitsvorbereitung abgeschlossen, nach der Mittagspause wird umgebaut.
Die 4090 FEs sind, abgesehen von den kleinen Stickern auf der Seite der Verpackung (die man abreißen muss), nicht weiter verpackt, da gibt's keine Folie, kein Papier, kein garnichts; dementsprechend ist es sehr schwierig, hier Versandrückläufer zu erkennen. Soweit die "neu" verpackt werden (Sticker erneuern oder neue Verpackung), hat da man (abgesehen von Spuren auf der Graka, die abgewischt werden können) - wenn keine Schäden dran sind - keine großen Chancen, sowas zu erkennen. Andere Grafikkarten sind von Werk aus verschweißt bzw. so zusammengepresst in der Schale, dass man die nie wieder ordentlich rein bekommt, ohne dass das auffällt - das ist bei der 4090 FE nicht der Fall. Die liegt einfach nur "nackt" in einer Kuhle.
Scheiße, bei mir noch keine AB bisher 😰
Hab ich was verpasst? DHL hat grad ATX 3.0 Netzteil und 4090 gebracht.
Das ist natürlich doof, wenn man gebrauchte Ware nicht erkennen kann...
zkg ;-)
Storno 😰 😰 😰
Es kotzt mich so dermaßen an... solln se die Dinger doch einfach versteigern.
Ich hoffe jetzt wirklich das die Gigabyte erträglich ist... War meine heimliche Hoffnung - und zum ordentlichen Preis erwischt. Die MUSS jetzt in Ordnung sein.
Ähnliche Themen
