[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Für Interessierte: "Best Gaming CPU"
KFA2 bei MM grad durchgeclickt (via Merkzettel gecarted weil der Cache der Artikelseite scheiße war) und bei Paypal abgebrochen, ging easy. Meine Abbruch Karte wird in ~30 Minuten re-droppen, könnt euch schon mal auf die Lauer legen (falls noch wer Interesse hat).
GErade von NBB:
Sehr geehrte Kundin, sehr geehrter Kunde,
wir haben Ihren Auftrag vom 02.11.22 mit Auftragsnummer BXXXXXXX bearbeitet und die darin enthaltene Ware am 02.11.22 versandfertig gemacht. Wir übergeben Ihre Ware nun direkt an den Versanddienstleister.
Oktober und November 2020 gabs Jeden Mittwoch und Freitag nen Strix Dropp bei Media Markt .. mal um 15 uhr und mal um 20 uhr .. davon seh ich 2022 nix .. 2020 war die Quete besser
Habs verdeutlicht, ich meine die FE.
Wenn viele 4090 Karten nicht 3Ghz schaffen . Dann frage ich doch mal so in die runde was so geht bei Normalen OC ?
Liegen sie so bei + 100 bis +200 Mhz oder eher mehr was dann vieleicht 2800 bis 2900 Mhz entspricht .
Dachte jetzt an einen Durchschnit was meistens geht ?
Hab bis jetzt mehrere Stunden RDR2 und Division 2 gezockt...
Bei meiner TUF Non-OC sind +240/+1.350MHz (GPU/RAM) @ 80% PL "stabil". Der GPU-Takt ist dabei meist bei ~2.900 (max. 2.955)
Unter Wasser wird der Takt um min. 30MHz höher liegen
Mir gehts ums Spulenfiepen. War schon drauf und dran eine Zotac zu nehmen. Lieber etwas lauterer Lüfter als Kopfschmerzen von den Spulen. Das war echt so ekelhaft...
Wegen der Temperatur mache ich mir keine Sorgen. Bei mir sollte nächste Woche eine Fractal Torrent ankommen. Da müssten meine drei Trümmer reinpassen und gut durchlüftet müsste es auch sein.
Jetzt noch nach einem ordentlichen Netzteil schauen wegen dem Kabelwahnsinn und dann ist erstmal gut. Dann wird der CPU Unterbau doch etwas nach hinten verlagert... Passt auch.
/edit: Strix - gefunden auf Otto.de :rofl:
Auch die Gaming OC hier. Wollte zuerst die FE, bin aber durch Zufall auf die gekommen. Leise und kühl, weder rasseln (wenn dann kaum wahrnehmbar) noch fiepen. RGB ist in Ordnung. Karte ist aber rieeesig das ist schon ne Hausnummer. Bin aber rundum zufrieden und 4 Jahre Garantie, falls man sie länger nutzen möchte.
lol, hab das gleiche probiert und es genauso gemacht. Also werden wohl 2 re-droppen.
Heute ging das WESENTLICH besser als bisher. Warum auch immer.
Na weil ich gerade in der Küche war und mir Nüsse reingestopft habe, anstatt vorm PC zu sitzen und zu klicken... 😭
Bin bei der KFA bis zum bezahlen gekommen, dann hat es abgebrochen. Dier karte liegt aber noch im Warenkorb, lohnt es sich immer mal wieder zu aktualisieren, oder besser aus dem Warenkorb raus und evtl. nochmal von vorne?
Drin lassen. Karten werden gerne mal wieder verfügbar ohne cartbar zu sein.
lass sie drin, aber aktualisiere nicht zu häufig. Wenn du erstmal gestoppt wurdest (captcha), dann hast du das ne weile sehr empfindlich
30 MHz für so einen riesigen Aufwand. Naja. Sieht auf jedenfall schöner aus am Ende^^
NVIDIA, Intel und AMD haben dadurch, dass quasi alle Chips heutzutage an der Kotzgrenze laufen, Overclocking und den Sinn von Wasserkühlung etwas zunichte gemacht. Früher hat man da locker 15% mehr Leistung rausholen können, oder mehr. Heute? Vielleicht 1/5^^
Junge ist das heute schlimm. So viele Dramen heute. Einer bekommt die Karte nicht weil er auf Pott muss und der andere weil er in der Küche ist. Man man man. Am besten überall das Handy mitnehmen und sekündlich aktualisieren. Immerhin geht es um eine überlebenswichtige Grafikkarte.
:lol:
Ich würde nen Anwalt einschalten, wenn der Betrag raus ist.
Ehrlich, auf die 150 € SB geschissen.
Dann muss die Karte nachgereicht werden bevor neue Drops stattfinden.
Dieses Fehlverhalten seitens NBB kann nicht rechtens sein.
Ich hab nicht mal ne SB. Der Betrag wird bei PayPal aber nur reserviert und nicht direkt eingezogen. Kann also nicht als konkludente Bestellannahme gewertet werden.
Trotzdem könnten die ja mal alte Bestellungen bedienen bevor neue angenommen werden. Naja... mal sehn was AMD heut Abend bringt.
Dafür das du über diesem ganzen "Drama" stehst drückst du aber ganz schön oft F5 ;) Lass die Leute doch begeistert oder enttäuscht sein wie sie wollen?!
Hab mal bestellt. Will sehen wie sich die Strix im Vergleich zu der FE schlägt. Eine von beiden geht dann wieder zurück...
Wow, Luxusprobleme :shot: Die Strixx kann nie und nimmer 700 euro mehr wert sein :fresse:
Aber... man könnte... mit hintergedanken... die FE auf kleinanzeigen für 2500 verscherbeln 🤷‍♀️
1/5 wäre 20% und damit mehr Leistung als die 15% die du von früher angepriesen hast.
Bin mal auf das Delta gespannt
Ähnliche Themen
