[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich habe 'ne Karte da und weiß nicht so recht was ich machen soll. Brauche eh ein neues Netzteil, aber die ATX 3.0 Netzteile sind ja noch nicht wirklich verfügbar in Deutschland. Außerdem habe ich schon "gemixtes Feedback" was die Thermaltake-Teile angeht gelesen.
Einen Adapter aus Hongkong zu bestellen, bei dem der Versand teurer ist als das Produkt (wenn man es einigermaßen bald haben will)-ehhhh. Auf den Nvidia-Adapter und meine Installationsfähigkeiten zu vertrauen-ehhhh.
Nutz doch einfach den beigelegten Adapter und gut ist. Warum lasst ihr euch alle so verrückt machen?
Wenn der Stecker schmorrt, was er höchstwahrscheinlich nicht wird, dann schickste die Karte wieder zurück und lässt sie dir Ersetzen.
Ahoi!
Ich versuche meine Lüfterkurve bzw. meine Lüfterecken :LOL: anzupassen, weil die Zotac 4090 AMP Airo Extrblahhh schmeißt die Lüfter bei 46 °C an und bei 39 gehen sie wieder aus.
Jetzt versuche ich sie dazu zu überreden erst bei 50 °C zu starten, aber sie hört für keine fünf Pfennig auf mich.
Ich hab Sie schon ausgebaut und in die Stille Ecke gesetzt, wieder eingebaut und sie ist störrisch wie davor.
Das einzige woran sie sich hält ist das sie ihre minimum Drehzahl immer beibehält und die 80°C ja sowieso nie erreicht, meist ist sie so bei 63-66°C.
Es muss an meiner Erziehung liegen, oder mein Eltern-Ratgeber der MSI Afterburner hat nicht genug Rechte über meine kleine Zotac.
Helft einem frisch geworden Graphicdaddy.
Ehm... ich hab da nochmal ne dumme Frage:
Ich habe folgendes Netzteil: Lian Li SP850 ( https://www.caseking.de/en/Lian-Li-...-white-850-Watt-NELI-012.html?tplview=desktop ).
Bei dem Teil wird das Adapter-Kabel nicht benötigt - liege ich da richtig?
Danke!
Laut der Produktseite ist das Netzteil bzw. das 12VHPWR Anschlusskabel nicht für 4090er Karten geeignet.
stimmt die Spuhlen schreien förmlich und die Karte ist nicht erträglich
Datenschutzhinweis für Vimeo
An dieser Stelle möchten wir Ihnen ein Vimeo Video zeigen. Ihre Daten zu schützen, liegt uns aber am Herzen: Vimeo setzt durch das Einbinden und Abspielen Cookies auf ihrem Rechner, mit welchen sie eventuell getracked werden können. Wenn Sie dies zulassen möchten, klicken Sie einfach auf den Play-Button. Das Video wird anschließend geladen und danach abgespielt.
Vimeo Videos ab jetzt direkt anzeigen
hab die Karte mit dem Wasserblock nun seit gestern Abend getestet und alle möglichen Scenarien durch, ob Benchmarks, Games, hohe Leistung, hohe FPS.
mein FE hat kein Spuhlenfiepen, jedenfalls höre ich da nichts.
klar ich bin taub und das kann ja garnicht sein, ja nee is klar
Wo steht das denn? Ich finde es nicht :unsure:
Wo bleiben die ersten Bilder der 4090FE aus dem gestrigen Drop? Ich fand die Umverpackung vor 2 Wochen von NBB wirklich sehr sicher verpackt. War direkt mit Foxconn Aufkleber Package 106 of 200.
Ist auf Hermes mal wieder kein verlass? :d
Bei meiner FE fappt da auch nichts. (y)
-25% PT +150 Mhz Core Clock + 900 Mhz Mem Clock. Sollte ein guter Ansatz sein.
Damit liefen meine 4090er schneller als Stock bei min 80 Watt weniger max Leistungsaufnahme.
Das stimmt so übrigens nicht, habe das mal exakt nach deinen Werten ausprobiert:
Stock:
-25% PT +150 Mhz Core Clock + 900 Mhz :
Das hier sind meine (vorläufigen) 24/7 Einstellungen: -10% PT +100 Core + 880 Memory.
(Ist dabei felsenfest auf 400 Watt festgenagelt):
PS: Das gelbe Ausrufezeichen ist da, weil er noch nichts mit dem neusten Hotfix Treiber von heute anfangen kann und "Grafikkartentreiber nicht bestätigt" raus haut.
Wo bleiben die ersten Bilder der 4090FE aus dem gestrigen Drop? Ich fand die Umverpackung vor 2 Wochen von NBB wirklich sehr sicher verpackt. War direkt aus China mit Foxconn Aufkleber Package 106 of 200.
Du wirst dich damit begüngen müssen, von vor 2 Wochen. :o
man möchte es einfach nur nicht hören das es auch karten gibt die kein Spuhlenfiepen haben... und das bei der Founders Edition... Schande unglaublich, das gibts ja garnicht ;)
Deine Signatur ist falsch :d "Gigabyte 4090 Phantom" ja was denn jetzt? Gigabyte oder Gainward? :P
Trotz der neusten Beta von HWinfo64 geht nach Start des Programms immer noch das RGB meiner Supreme X aus?
Der nächste Experte, der erfolglos versucht hat, den Nvidia-Adapter kaputt zu kriegen. Laut JonnyGuru scheint das Problem beim Anwender zu liegen und nicht beim Nvidia-Adapter. Wenn nicht richtig reingesteckt, wird der Adapter heiß.
Es gibt einige Nvidia Adapter die schlecht sind : es gibt 3-4 verschiedene Arten wie gelötet wurde ( allein das sollte eigentlich schon nich sein bei einem Serien Produkt wo eigentlich immer alles gleich sein sollte ) ,
es gibt 2 Arten von verbauten Kabeln bei dem Adapter ( ein Adapter hat 150 und der nächste hat aber 300 ) , Wenn schlecht verlötet kann es passieren das eine Ader einfach abfällt vom Lötpunkt
Hat man nenn guten Nvidia Adapter erwischt passiert auch nix ... aber hat man nen schlechten Nvidia Adapter erwischt dann passiert eben was... Glücksspiel
Das Problem liegt also nich beim Anwender wie du schreibst sondern bei der Qualitätskontrolle der Adapter .. das sollte doch nun schon seit knapp 1 Woche nun klar sein
Man muss aber dazu sagen, dass er das auf Netzteilseite getestet hat, weil er eher damit klar kommt ein 200$ NT abzufackeln als eine 1600$ Grafikkarte :d Steht im Thread auf Reddit.
Ich hab jetzt endlich mal meine Phantom ausprobiert. Leider schönes Spulenfiepen. In etwa so wie bei der Gaming Trio. Da behalte ich liebe die MSI. Karte Geht dann wohl an Alternate zurück.
Meine FE ist in Zustellung. Mal sehen ob Hermes es schafft. Bin nicht Zuhause aber der Nachbar ist informiert. Hoffentlich klingeln sie da auch
Meiner schmeißt so billiges Zeug wie Grakas eigentlich immer vor die Türe :)
Ähnliche Themen
