• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Nach 2 Tagen bei denen es angeblich bereits im 2nd Level sein sollte ... fängt ja gut an ... Der Support in Deutschland ist noch schlimmer seit 4 Tagen keine Rückmeldung.
Was nen Lüfter Extra ausmacht :)
Mein RAM läuft Stabil,. da hab ich drauf geachtet also aktuell hab ich +240/1850Mhz eingestellt,
Komme jetzt doch knapp über die 3 GHz und speicher ca 1,55ghz in timespy extreme bei max 574watt. Damit ist die obere Grenze ausgelotet. Als nächstes dann uv und alltagssetting finden.
Einbau war ein Krampf, 5000x case ist zu klein. Das nächste wird wieder größer.
GZ. Sieht geil aus was du da mit den Kabeln machst. Ist das Kamasutra?
Meine Suprim X schafft maximal 3060mhz mit erhöhter Spannung und bei 900 mV schafft die 2670mhz, vllt kannste das ja als Anhaltspunkt nehmen
Also ein Delta von ca. 20 Grad zw. Wassertemp und Chip Temp. ist glaube ich relativ hoch, hängt aber auch von den Watt ab, die da durch gehen, bei dir ja mit 5K entsprechend hoch.
Denke das ist in Ordnung aber mal sehen was die Experten sagen ....
Delta um die 20°C lagen beim Bauer mit der Inno3D Alphacool und im Optimus Twitter ja auch grob an. Ja, andere Power Limits aber so grob könnte man damit schon mal rechnen. Ich wünschte beim CPU wären wir auch “nur“ bei 20er Delta :/
Mehr fps?😅
Hab in the Ascent z.B. keine 80fps maxed out.
Ist kein Shooter aber mehr Bilder können nie schaden. Lüfter läuft immer auf minimum(30%,ca. 1000U/min) auch bei 1,1V
Ja okay. Ich gehe mal davon aus dass du nicht im CPU Limit hängst, oder? Bringen dann so 150 MHz mehr wirklich den Durchbruch? Also früher waren das Welten, aber bei dem Ding merkt man das doch nicht, oder?
Ja schlägt voll durch.
Mehr Bilder=smootheres Bild
Inputlag ist bei dem Spiel nicht wichtig.
Das Game solltet ihr euch mal geben. Sieht meiner Meinung nach besser aus als Cyberpunk🤩
Mit der 3090 waren es ca. 45fps hab es da gar nicht richtig angefangen.
Ich habe gestern Abend mal Time Spy Extreme durchlaufen lassen. Die GPU lief out of Box auf ca 51 Grad. Wassertemperatur waren zwischen 33 und 34 Grad. Somit war das Delta von Zimmer zu Wasser bei ca 10 bis 11 Grad und das Delta von Wasser zu Chop bei ca 17 Grad.
Bei UV sieht das anders aus. Auf 900mv @ 2650 Mhz habe ich noch ein Delta von 9 bis 10 Grad und habe nur 100 Grafikpunkte weniger.
p.s. falls es wen interessiert. Ich habe gestern mal das 1000W Netzteil verbaut und da ATX 3.0 storniert. Das bisherige kommt in den Zweitrechner. Ich warte jetzt auf das bequiet Kabel bis das irgendwann kommt. Dann wird noch alles direkt verbunden und fertig ist die Kiste.
So Mod-Kabel ist da, und ist wie erwartet top Qualität, am besten man biegt es vor dem Stecken etwas vor.
Gestern Abend noch schnell eingebaut, gerade durch die Plexiglas-Scheibe mal nen Schnappschuss aufgenommen, übrigens kein Rotztuch in der Spiegelung, sondern nen Kassenzettel. :LOL:
ähm ich find das irgendwie extrem viel 574watt für 3ghz?
meine karte macht das mit 400-450?
Ja, finde das auch sehr viel. War wie gesagt erstmal alle regler möglichst auf rechts. Werde noch optimieren bzw undervolten.
Ist das Krieg der Schläuche und Kabel?
xD, ja genau. Wird bald verfilmt :-)
Wenn irgendwann mal das be quiet Kabel geliefert wird, mach ich das nochmal ordentlich.
Nein bei seinem PC ist der Anfang ... dort hat es also begonnen .. wir erleben da die geburtstunde des Matrix Sentinels :d
Geburt : -------------------------------------------------------- 2tes Lebensjahr ------------------------------------------------------------------------------- 10tes Lebensjahr
P.S : @Aphexz ... nich böse gemeint aber das war nun leider zu einladent für diesen kleinen Scherz :d
Richtig erkannt, das ist das Thema meines builds.
Kabelsutra um genau zu sein.
Schön zu hören, dass auch andere normale Karten haben.
Bin zufrieden mit der Karte, werde sie eh nicht am Limit laufen lassen. Spulenfiepen hör ich auch nicht mehr.
Da lob ich mir "wieder" oldscool. Normales Gehäuse ohne Sichtfenster und gib ihm. Ganz egal was du tust es ist einfach so. Keiner schaut drauf und keiner sagt was.
Ich hatte auch mal ne komplett andere Zeit. Da musste ich das O11 haben voll RGB. Wasser war farbig und überall waren LED Leisten und LED Lüfter usw. Aber dann wurde es mir zu "bunt" und ich bin wieder auf stinknormal unterm Tisch gegangen. Schläuche von der Custom Wasserkühlung sind jetzt nichtmehr durchsichtig. War auch echt wild das Zeug loszuwerden damals. War alles rot :d
Ja kenn ich :-)
Mittlerweile verwende ich auch nur noch schwarze zmt schläuche. Fenster (mit dunkel getöntem) Glas finde ich aber immer noch gut. Hat etwas beruhigendes, wenn man da reinschauen kann :-)
Hast Du mal die Temperatur am Stecker gemessen?
Noch nicht will ich am WE machen, mein Messgerät ist seit dem letzten Umzug im Keller verschwunden.
Hab gestern noch ne Stunde gebencht und an den Stecker gefasst, war höchstens lauwarm.
Ich habe da mal eine Frage. Silverstone liefert zum SX1000 Platinum Netzteil folgenden Hinweis mit:
Die maximale Stromstärke eines einzelnen 8-poligen PCIe-Kabels und Anschlusses beträgt 12,5 A, was 150 W (+12 V x 12,5 A) entspricht. Daher deckt die SilverStone-Garantie keine Schäden oder Fehlfunktionen durch den Einsatz einer Grafikkarte oder Erweiterung- skarte mit einem einzigen 8-poligen PCIe-Anschluss ab, die die Standardleistungsaufnahme von insgesamt 225 W übersteigt (150 W vom 8-poligen PCIe-Anschluss + 75 W vom PCIe-Motherboard-Steck- platz). Ebenso wird die Verwendung einer Grafikkarte oder Erweiterungskarte mit zwei 8-poligen PCIe-Anschlüssen, die eine Leistungsaufnahme von insgesamt 375 übersteigen (300 W von den beiden 8-poligen PCIe-Anschlüssen + 75 W vom PCIe-Mother- board-Steckplatz) nicht durch die Garantie abgedeckt.
Diese Spezifikation der PCIe Kabel dürfte für die Netzteile aller Hersteller gelten? Pro Kabel also 150W, für ein 450W Powertarget also 3 SEPARATE Kabel, die 75W vom Motherboard lässt die 4090 ja links liegen.
Habe ich nur 2 Kabel, sollte ich auch nur 300W abrufen, indem ich das PT entsprechend einschränke. Soweit richtig?
Ich habe hier imho einigen Unsinn gelesen, dass pro (Y-) Kabel 300W möglich seien, aber das bezweifle ich.
Und der gespiegelte Buzzer mit blauem LED Ring ist der Not-Aus ? :fresse:
Auf dem Bild sieht das beim ersten Hingucken wie eine 6 Slot Karte aus ^^
Das blaue Ding ist der Soundblaster X3
Unten ist das GPU Bracket, hab ich mir angeschafft als die Karten noch kleiner waren. :banana:
Das Ding kommt mit der 4090 an seine Grenzen.
GPU-Halterung, ARGB LED lässt sich mit der nicht allzu guten MSI Software steuern.
So meine Rücksendung der defekten 4090 ist zum Glück nun abgeschlossen. Nun heißt es wieder auf die Suche nach einer 4090 gehen. Bin mir aber unsicher, welche Marke und Modell, nachdem ich mit der Suprim X nun keinen guten Start hatte.
Irgendwie habe ich im Gefühl, dass die vereinzelten Karten, die in letzter Zeit von dem Bot erkannt wurden, alles Rückläufer sind. Anscheinend muss man echt warten, bis wieder eine neue Charge frischer Karten kommt.
Habe meine 4090 anfangs mit zwei Y-Kabel ohne PL zu senken betrieben und war absolut gar kein Problem. Hatte auch zuvor meine 3090 an einem einzelnen Y Kabel und demensprechend ca. 275W drauf. Warum sollten 300W auch ein Problem für die dicken 8 Pins sein, wenn jetzt wesentlich dünnere Kabel und Pins für 600W spezifiziert sind?
Das ist wohl die 1 Millionen Dollar Frage, im Endeffekt scheint jeder Hersteller da Macken mitzuliefern, von Rasseln bis Spulenfiepen bis Lüftergeräusche ist alles vertreten und das teils leider sehr massiv. 🤮
Will eigentlich auch eine TUF wegen 2x HDMI, aber die Berichte zu Spulenfiepen werden immer mehr und mehr… bei der Strix sieht’s ja nicht besser aus.
Bei KFA2 und Zotac soll man wohl am meisten Glück haben zur Zeit wenn man eine ruhige Karte sucht.
Aber bei Zotac hast gerne mal ein Brummen vom Lüfter her. Meiner Meinung nach zwar wesentlich erträglicher als pfeiff, quietsch und Schnarrgeräusche, aber das empfindet ja jeder anders. Deshalb sollte das erwähnt sein.
Ähnliche Themen
