[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Nochmal ein Nachtrag zu gestern, wo ich geschrieben habe, dass bei meiner Gaming OC der Silent/OC-Switch nicht richtig funktioniert. Habe jetzt mit DDU den ganzen Nvidiakram runtergeschmissen und neuinstalliert und nun funktioniert alles wie erwartet. Ich habe zuvor am Power Target und an den Lüftereinstellungen im Overlay rumgespielt und es scheint als ob diese Einstellungen zum Teil noch galten trotz Zurücksetzen auf Default. Nur falls jemand auch solche Probleme hat.
Edit: Ok, Fehlalarm. Nach einem erneuten Wechseln zwischen Silent und OC-BIOS verhalten sich beide wieder gleich. Keine Ahnung was das soll. Das BIOS wird laut GPU-Z auf jeden Fall korrekt gewechselt. Beide gehen in Games in der selben Zeit jedoch auf die gleichen Temps & RPM hoch.
Meine 4090 will dieses Spiel, leider leider kann ich nicht zu Diensten sein 😏
Dürfte die höchste Wertung sein die ich je gesehen habe bei 4P. Naja dafür ist zum Glück meine PS5 da
(für die ich btw viel viel härter „kämpfen“ musste als für eine 3090 und eine 4090 zusammengenommen 😂)
So Ersteindruck der FE ist sehr positiv. Echt schon sehr wertig im Vergleich zur Gainward. Macht Stock 500 Punkte weniger im TSE als die Gainward und Lüfter sind leicht lauter (abgesehen vom Störgeräusch der Gainward) bei der FE. Dafür aber kein nerviges Brummen mehr :fresse: Ab so 70% machen die Lüfter aber so ein leicht metallisches Nebengeräusch, hatten hier ja glaube ich schon mehrere beschrieben. Stört mich aber vermutlich nicht, deutlich besser als das Geräusch der Gainward, das immer hörbar ist. Spulenfiepen ist vorhanden, auch mehr als die Gainward, aber alles im Rahmen.
Fazit: Die Gainward wäre eine echt geile Karte eigentlich, wenn die Lüfter nicht wären. Der Qualitätsunterschied beim Aufbau der Karte ist aber gewaltig. Ein Außenstehender, der mal beide Karten in die Hand nimmt würde niemals ahnen, dass die quasi gleich viel kosten. In meinem Fall war die Gainward sogar 50€ teurer. Mal sehen was die FE OC technisch noch kann, dafür habe ich erst am Wochenende Zeit. Bleibt aber auf jeden Fall jetzt drin. :)
28 FE's bei EKA seit gestern drin. Seit 3 Wochen hänge ich fast nur am PC um nen Drop mitzubkommen.
2x Storno
Und gestern einmal das Handy neu gebootet währen der Drop morgens, statt wie sonst miittags, kam.
Der PC Gott gönnt mir keine FE.
Bei der 3090 nicht und bei der 4090 auch nicht.
Bis die normal zu bekommen sind steht die 5090 in den Startlöchern.
War manchmal echt kurz davor bei einem Scalper zu kaufen.
Weiß aber nicht was mich mehr abgehalten hat.
Angst keine Garantie zu bekommen oder die Kohle einem Parasiten zu geben.
Echt ne Schande. Die eine FE bekommen bauen auf Wakü um. Den Sinn verstehe ich gar nicht wenn man schon das schönste Air Modell hat
Und die anderen verkaufen eine nach der anderen bei Ebay.
Ich denke Jensen will das genau so.
Sonst könnte man doch einfach bei NBB bestellen und warten bis sie geliefert wird.
Ich tröste mich derweil mit 2x HDMI an der Tuf :-)
Ich hab jetzt endlich mal meine Phantom ausprobiert. Leider schönes Spulenfiepen. In etwa so wie bei der Gaming Trio. Da behalte ich liebe die MSI. Karte Geht dann wohl an Alternate zurück.
Also ich muss Taub sein, aber ich höre nix bei meiner Gainward. Allerdings sind die Lüfter nicht leise, und das persönlich stört, wenn man weiß, das es besser geht ^^
und leute meinen hier "dinge verkaufen" sei etwas legales. na klar, mit bots karten kaufen und nur mit gewinnabsicht verkaufen ist aber nicht legal
20 Grad Differenz von WaKü zu Luftkühlung soll wenig bringen ? da bin ich aber anderer Meinung ;)
Wenn du mal richtig zockst hast du auch über
50•C GPU bei einem mora . Richtig Vorteile beim GPU Clock hast eigentlich erst bei unter 40•C . Du kommst locker bei einem dicken System auf 35 •C Wassertemperatur.
Habe selber alles hier und 6 Jahre benutzt . Mir braucht man nichts mehr erzählen .
Bei einer 1080TI hatte man noch 6 Kelvin Delta und bei Turing und ampere war es schon deutlich mehr und hier hast du 20 Kelvin über Wassertemperatur.
Geil ist was anderes ;-)
Und genau aus diesem Grund und kein andere habe ich eine playstation 5. Die exclusiv Games. Last of us 1/2, God of War... Viele kommen zwar jetzt auch für den PC aber die Exklusivität ist dennoch vorhanden.
weisst du welche W/mK die pads beim ekwb block haben?
/edit
nur 3.5 lol, direkt mal fujipads bestellen.
Hier mal ein paar Impressionen des "pinken Steckers" von Amazon :) läuft auf 2x8 Pin am Seasonic PX 850... Im Furmark gerade knapp 570 Watt gezogen
das sind meines erachtens die gleichen WLPads wie bei dem Vector der 30gen, den W/mK Wert hab ich jetzt aber nicht mehr im Kopf...
Es sind jedoch 0.8mm, 1mm, 1.5mm, 2mm Pads zu verbauen nicht nur 1mm wie bei der letzten Vector FE Version.
Ausserdem wurde der ursprünglichen geplante Version abgeändert,
das Manual https://www.ekwb.com/shop/EK-IM/EK-IM-3831109900703.pdf sieht 1mm, 1.5mm, 2mm WLPads vor.
Es lag aber ein zusätzlicher Ausdruck bei welcher wie zu sehen ist andere WLPads aufführt.
Ich wollte auch erst ne FE weil ich dachte das ist die günstigste Variante um auf Wasser umzubauen. Optisch finde ich die FE echt ugly. Passt gar nicht zum Rest eines PCs. Bin froh keine FE bekommen zu haben und hab stattdessen ne TUF non OC zum selben Preis bekommen. Die TUF finde ich bis auf die Gigabyte Windforce am schönsten. Und Garantie bei nem Umbau bleibt auch bestehen. Aber ich verstehe echt nicht den Hype um die FE abgesehen davon dass sie kleiner ist.
Sieht halt nicht nach Kinderzimmer aus die FE, wie viele der ganzen anderen Plastikbomber...
Ist natürlich am Ende des Tages alles subjektiver Geschmack, aber mir gefällt z.B. die FE super und ich bin froh, dieses Mal eine bekommen zu haben (obwohl ich erstmal abwarten wollte bzw. die 4090 ggf. ganz überspringen, lol).
Wenn man aber auf Wasser umbauen will, sollte man sich ja eher daran orientieren, welcher Block am schönsten ist und dann die passende Karte dazu bestellen.
Anhang anzeigen 811615Anhang anzeigen 811616Anhang anzeigen 811617Anhang anzeigen 811618Anhang anzeigen 811619
Mh, da ist überhaupt keine Zugentlastung oder sonstige "Sicherheit" an den Pins. Der Adapter mag von der Farbe gefallen, aber ob der technisch gut ist? Sieht für mich qualitativ deutlich schlechter aus als der originale NVIDIA Adapter. Die Abstandshalter der Kabel werden wenig helfen, wenn Zugkraft auf das Adapterstück vorne kommt.
Wenn Menschen ihre Wünsche/Träume nicht erfüllen können, suchen sie sich Alternativen und reden sich diese dann schön; das ist normal und menschlich. Man will immer eine "gute" Entscheidung treffen.
Mich hyped die FE weil die einfach edel aussieht. Alle AIB's sehen aus wie ne platine mit nem viereckigen Kühler und da drüber ein viereckiger Shroud. Die Tuf sieht noch ganz ok aus und fühlt sich auch geil an. Aber an das Alleinstellungsmerkmal der FE kommt sie nicht ran. Ein weiterer Vorteil der FE ist, dass sie einen Teil der warmen Luft hinten rausbläst und nicht das ganze Gehäuse ausfüllt.
Bei mir steigt die Zuversicht. Es kommt jetzt immer mal was rein, bei Eka stapeln sich die Dinger, erste Seriöse Weiterverkäufer mit UVP-Preisvorstellung... das wird schon.
Die FE ist halt kompakt, es gibt Wasserkühler, das PCB ist gut bestückt und sie ist "günstig". Für 2200+ UVP gäbs keinen Hype auf das Teil...
Dabei kommt die TUF vom Design her der FE eigentlich am nächsten. Quasi eine FE mit traditionellem Kühler.
Ähnliche Themen
