[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Richtig... FEs stehen natürlich auch rum aber teurer. Bezweifle, dass die aktuell noch jemand für >2100 EUR kauft.
Irgendjemand hier hatte nen Referenzblock auf die KFA2 gepackt, oder?
Kann mal jemand der auch Probleme hat mit Blackscreens, Monitor geht aus, Sound kratzen etc in Verbindung mit der 4090 folgendes probieren? LatencyMon laden und bei Twitch, Youtube, herumsurfen im Idle (die Graka muss im Idle Modus sein) folgendes probieren:
Energieverwaltungsmodus:
Normal:
Maximale Leistung:
Zwischen dem umschalten der Energiemodies bitte auch prüfen ob die Graka wirklich in den Idle geht, 210Mhz/865mV.
Das ist echt ein sehr nerviger Treiberbug. Wer das Problem ebenfalls hat, als einzige Option bleibt der maximale Leistung Modus der im Idle leider 40-50Watt mehr verballert.
ich kriege die Krise, bei MM sind Gigabyte Karten gedropped, im Warenkorb hatte ich schon eine, dann konnte ich sogar "zur Kasse" clicken, kam auf die Übersichtsseite inkl. Bezahlstatus, und beim finalen clicken kam dann doch wieder die Fehlermeldung. Das Ganze ging 5 Mal ...macht keinen Spaß
Nochmal ein Nachtrag zu gestern, wo ich geschrieben habe, dass bei meiner Gaming OC der Silent/OC-Switch nicht richtig funktioniert. Habe jetzt mit DDU den ganzen Nvidiakram runtergeschmissen und neuinstalliert und nun funktioniert alles wie erwartet. Ich habe zuvor am Power Target und an den Lüftereinstellungen im Overlay rumgespielt und es scheint als ob diese Einstellungen zum Teil noch galten trotz Zurücksetzen auf Default. Nur falls jemand auch solche Probleme hat.
Edit: Ok, Fehlalarm. Nach einem erneuten Wechseln zwischen Silent und OC-BIOS verhalten sich beide wieder gleich. Keine Ahnung was das soll. Das BIOS wird laut GPU-Z auf jeden Fall korrekt gewechselt. Beide gehen in Games in der selben Zeit jedoch auf die gleichen Temps & RPM hoch.
Bios mal upgedatet? Klick mich Allerdings ist die TXT falsch geschrieben, zumindest vor paar Tagen noch.
N4090GOL.f2.exe ist das OC Bios und N4090GOA.f2.exe ist das Silent Bios.
Probier einfach aus, je nachdem welches Bios du gerade aktiv hast, kommt beim Flash ne Fehlermeldung, beim Anderen funktioniert es dann. Möglicherweise haben die auch schon die TXT richtig gestellt, hab es jetzt nicht nochmal neu runtergeladen.
Das ist echt ein sehr nerviger Treiberbug. Wer das Problem ebenfalls hat, als einzige Option bleibt der maximale Leistung Modus der im Idle leider 40-50Watt mehr verballl
Schau Mal über das MSI Tool, ob die Grafikkarte im Msi Interrupt Modus läuft. Bei mir musste ich da umstellen. Hatte nämlich auch eine Interrupt Überschneidung mit meiner Soundkarte
Kleine Info an alle Asus Käufer. Wenn ihr Eure Karte bei Asus Registriert, bekommt ihr Garantie bis 2025 bzw. fast 2026.! :banana:
Hätte ihn gerne in schwarz gehabt statt weiß :fresse:
Naja besser Pink als den Schmutz-Adapter :fresse2:
Übrigens der olle Hotfix hat Probleme mit black screen nicht gefixt. Gibt genug Leute bei CB, die auch noch Probleme haben :(
Und wieder zurück zum 522.25.
Blackscreen? Wo genau? Das mit dem Idlemodus? Besteht wohl seit 3090 Zeiten. Ist also nicht erst seit paar Treibern so.
Geht mir ebenso.:angel: Aber trotzdem nice to have.! :bigok:
Optisch finde ich die FE echt ugly. Passt gar nicht zum Rest eines PCs.
Waaaaaas? Die ist mal die Hübscheste von Allen und in Echt auch so derbe hochwertig! Ich liebe Sie... wirklich... ich liebe Sie 🥰
Muss ab und zu sogar untern Tisch gucken :fresse:
Ich finde die FE auch nicht hübsch. Keine Ahnung was man der findet. Das ist sicher nur ein Preisthema.
An meinem LG Monitor via DisplayPort.
Der LG CX65 über HDMI macht keine Probleme.
Sobald ich aber vom TV zurück zum Monitor schalte, gehts los mit black screen.
Das ist doch OLED oder ? Sicher das es ein Treiberthema ist ? Ich hatte bei meinem OLED auch Bildfehler und co. Aber habe dann ein Update gemacht vom der TV Software und es war erledigt. Bei mir gab es ein Softwareupdate.
Da bleibe ich lieber beim 522.25.
Ist aber schon komisch, dass 2 Treiber hintereinander so ein Fehler existent ist.
Dachte schon, es liegt an den TUFs :fresse:
Da ASUS abgewichen ist.
Der Fehler besteht seit Jahren. Laut anderer Seiten hatten User schon früher mit 3090 diese Treiber Abstürze.
Ich finde die TUF sehr geil gestaltet bis auf den kindischen Aufdruck auf der Backplate… naja was sollst. Gehäuse ist eh zu und unter dem Tisch.
Jo die geht. Finde auch die Phantom schick von gainward oder die inno3d x3 oc. Die sind schön schlicht. Inno3d hat nichtmal viel RGB.
Ahja. Verarbeitung, Material und sogar Farbe sind ähnlich. Auch wenig RGB.
Ähnlich ist da garnichts. Dann kannst auch eine x3 oc oder sonstwas nehmen für ähnlichkeit. Sind halt customs.
Wahnsinn! Das ist ja genauso lang, wie ohne Registrierung. 36 Monate ab Kaufdatum.
Das mit der Inno3d kann ich bestätigen. Die ist echt total unauffällig. Einfach nur schwarz. Da leuchtet tatsächlich nur das Inno3d Logo and der Seite und das kann man sogar ausmachen. Kein Bling Bling und nix.
Nee, hatte 2 Monate 3090 TUF und 1,5 Jahre ne 3090 Strix. Nie hatte ich so ein Verhalten ein einziges Mal erlebt!
Das DisplayPort wirklich hardwareseitig verbuggt war bei der GTX 970 und 980.
Du nicht, einige User schon. Ich hatte auch keine Probleme.
Mal schauen was AMD heute Abend zu bieten hat.:angel:
Was ist eure Einschätzung zur RX 7xxx Serie .?:asthanos:
Ich hatte mit all meinen 3090 Karten auch kein Problem. Aber mit all meinen 4090 Karten schon.
Ist auch egal welcher Treiber, Problem bleibt bestehen.
Ähnliche Themen
