[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Was nützt einem mehr Leistung, wenn die Engine trotzdem ständiges stuttering verursacht:
Ja schon klar, dass das Game noch nicht fertig ist und teilweise har stottert. Für 3.18 wurden aber weitere Verbesserungen des GEN 12 Renderers und Vulkan angekündigt. Das wird immer besser und besser. 3.17 hat ja auch fps technisch zumindest ne Menge gebracht!
Deine FE hat deutlich hörbares Spulenfiepen?
Interessant, du bist der erste, von dem ich das höre.
Ist natürlich schwierig, da Feedback zu finden, weil nur so wenige Menschen überhaupt eine 4090 FE haben.
Im idle nichts zu hörena, aber wenns dann ins Game geht z.b Overwatch gehts richtig ab. Dann höre ich das schon durch das Case. Habe das mal aufgenommen, zwar ist mit dem Handy dies aufzunehmen immer da so ne Sache.... Aber hier der Link : mp3 (files.fm)
Die gleichen FPS und Ruckler bekomme ich in Lorville auch mit meinem 13700k+4090
Ist echt ein trauer Spiel. Das Spiel braucht DLSS3 ;D
Aber selbst das würde den Rucklern wenig helfen. Etwas CPU entlastung immerhin
Hoffe der Gen12 Renderer in Alpha 3.18(?) wird es richten.
Nee das ist die erste und einzige ... die werde ich auch behalten bzw. Abwickeln ;-)
Na ja das Problem siehst du jeden Tag wenn du den Rechner einschaltest bei ner 2K Grafikkarte ... Nööö muss nicht sein.
Vielleicht liegt es an ASUS ... muss später mal ein Anderes MB testen ... aber glaub ich leider nicht, wie gesagt jede andere GraKa funktioniert ... auch andere 4090 ;-)
Bei mir ging es auch mit einer anderen 4090 - nur mit der FE nicht.
EVGA hat schnell reagiert und ein Beta Bios rausgebracht.
Bei Intel CPUs soll es ungemein helfen die E-Cores zu disablen! Ansonsten ja das Game benötigt noch ne Menge Optimierung, da bringt leider auch keine 4090 Besserung.
Das macht ja mal Hoffnung ...
Werde auch mal bei Asus ein Ticket aufmachen ...
Allerdings könnte ich schwören, das es ein paar Mal funktioniert hat und irgendwann plötzlich nicht mehr.
So ging es mir auch mit der 3090.
Und bei der CPU kann ich Dich auch verstehen. Habe die gleichen Vorlieben wie Du.
Also im Singlecore Boost geht mein 5900x auch auf über 80°. Trotz optimierten CO. Bei Fullcorelast habe ich das PBO so eingestellt, dass ich auf ca. 80° komme.
Also so lang Du im Singlecore die 90° nicht erreichst würde ich sagen, dass alles normal ist.
Eventuell nochmal Wärmeleitpaste fachgerecht auftragen und Kühler kontrolieren.
Welchen Kühler hast Du? Hast DU auch einen guten Airflow?
Edit 80°
Normal wird der 5950X Stock 85°C warm, nur bei Prime 95 95°C. Aber nur 1 Kern!
Allcore mit 142W, also 60W mehr als beim ST-Boost, wird der ganze nur 65°C warm.
Es ist also nicht die Kühlung, sondern das gleiche Problem wie beim Zen4, die Wärme kommt nicht schnell genug zum Kühler.
Ich habe eine Gletscherwasser 280mm AIO von Alpenföhn (auch AM5 kompatibel :d) und Airflow, nunja die bekommt kühle Luft von der Seite durch Mesh.
Mit PBO kann ich den ein wenig einstellen und wird 2-3°C kühler, aber das wars, bei grob -10 in PBO-Curve ist Schluss. -30mv ist leider bei weitem nicht genug um die 1,5V weit zu verändern. Zu großer Offset und dann stürzt der PC ab, da vorallem der Offset auch im Idle die Spannung reduziert.
Hey und wenn ich eine CPU perfekt köpfen und mit Flüssigmetall ausstatten kann, das die CPU immernoch unverändert noch nach 5 Jahren läuft, dann kriege ich WLP bestimmt auch hin. Bin da penibel. :d
Und ja ich habe trotzdem auch WLP schon mal neu aufgetragen...
Möglicherweise sind das einfach Probleme vom Laden des Levels im Hintergrund. Da hilft am Ende vielleicht ne M.2 oder gar nichts, falls ne M.2 schon drin ist.
Ok, hört sich so anals wenn Du alles getestet hast.
Da fällt mir nur ein die CPU mit optimiertem PBO und CO laufen zu lassen und als Thermallimit im Bios 80-85° einzustellen. So hast Du vollen Allcoretakt, 1 Core Boosts und Spannungssenkung im Idle.
Zudem könntest du noch cppc deaktivieren damit windows nicht immer den gleichen kern und CCD nimmt.
Wenn du die Spannung erhöhst wird der takt höher gehen.
Dann musst du vielleicht noch in 15 mhz Schritten mit dem Takt runter gehen wenn er noch abstürzt.
Schlecht würde ich nicht sagen. Hatte eine Karte gesehen die mit Spannungserhöhung nur ca 2850 geschafft hat.
Denke um die 3000mhz is gut mit Spannungserhöhung.
Und alles über 3100 wär schon super.
Hier im Forum war das höchste was ich mitbekommen habe 3160.
Aber auf 100mhz mehr oder weniger kommts nicht an.
Was schafft denn dein Speicher? Der Speicher OC bringt noch etwas mehr nach meinem test (z.b. in shadow of the tomb raider)
Wenn du da um die +1500 schaffst, ist der Speicher gut und macht viel wieder wett.
Ob du es "sollst": bringt halt eher wenig. Nur wenn du die 3000 aus spaß mal knacken willst zu empfehlen.
Gibt ja momentan das problem mit abfackelnden stromanschlüssen und da könnte man schon etwas vorsichtiger sein.
Man kann die Karte eh besser undervolten. Dann ist sie leise, kühl, verbraucht viel wenige strom und verliert kaum Leistung dabei.
Z.b. 0,9v und 2600mhz könntest mal testen wenn dich das interessiert. Dann in 15mhz schritten hoch oder runter bis es abstürzt.
Danke das du dir die mühe machst mich dahingehend aufzuklären. auf welche spannung kann ich die gpu den maximal erhöhen? 1,1V? aktuell ist die spannung bei 1.05V. ich denke ich werde die spannung erhöhen und mit dem takt gehe ich auf 3000mhz.
also bei speicher (memory) dann auf +1500 gehen? wieviel wäre der speicher den maximal mit den +1500?
Für die interessierten der Vorseiten, die bzgl des 3x 8Pin sich Überlegungen gemacht haben.
Heißt vermutlich, dass AMD die Karten ebenfalls weit, weit jenseits jedweder vernünftigen Effizienzkurven laufen lässt, um die Balken länger zu kriegen.
Leider bringt das Temp-Limit nicht viel, weil mein Kühler eigentlich gut ist.
Da müsste schon ein 70°C Temp Limit her, aber trotzdem versucht der dann hoch zu boosten auf dem Desktop und verbraucht halt zu viel :d
80W nur für Firefox ist zuviel, mit den 4,2Ghz@1,1V liege ich bei 30-40W. (DualMonitor Setup)
CPPC ist aktuell sowieso deaktiviert..auch HT ist deaktiviert, weil ich keine 32 Threads brauche.
Wie gesagt das beste was ich in meiner Situation machen kann ist den 5800X3D einbauen.
Spiele auch gerne Anno 1800 oder Factorio z.b. da kriege ich dann auch einen schönen Boost. :d
Ach ein nettes Spulensummen, das ist nicht schlimm. Ein richtige Fiepen würde auf meinen Tinnitus schlagen :/
Overwatch hat aktuell biszu 600FPS. Dat braucht man nicht. FPS zum Monitor anpassen oder FPS-Limiter helfen.
Je höher die FPS, desto mehr müssen die Spulen hin und her schalten, das macht soweit ich weiß das Geräusch.
Bei wie viel FPS?
Overwatch bei 60fps nichts zu hören, 144fps schon eher und dann bei vollast doppelt so laut. Aber z.b bei Cyberpunk hört man das auch schon laut. Habe dort aber nur ~70 fps.
Bei Firestike oder die Benchmarks die ich bis jetzt getestet habe sind bei 100% deutlich weniger zu hören als bei Games!?!?
Hermes.... :kotz:
Laut Tracking liegt meine FE seit Mittwoch 18:25 Uhr bei Hermes in Hanover....
Hermes.... :kotz:
Ich hatte mal ne ähnliche Geschichte, wo die Pakete im Lager verlegt wurden und erst nach manueller Anfrage und suche (1 1/2 Wochen später) haben die sich dazu erbarmt, das Paket herauszukramen. Hermes ist einfach so schlecht, DHL liefert - zumindest bei uns - immer pünktlich morgens gegen 10-11 Uhr früh, Verspätungen arg selten. Keine Ahnung, warum hier NBB auf Hermes setzt. Vermutlich wollen die weniger Geld für die Lieferungen, DHL ist ziemlich teuer geworden.
Genau das ist der Grund warum ich faktisch nie bei NBB bestelle (außer halt bei der FE) , weil die Regulär mit Hermes versenden und UPS ordentlich Aufpreis kostet, sofern es überhaupt angeboten wird.
Warum müsstest Du ein 70° Templimit nehmen? Damit die karte gar keine Möglichkeit hat mal zu boosten????
Verstehe ich nicht. Gib Ihr doch 85°.
Dann hast Du doch best of both worlds. Und er boostet beim browsen ja nicht durchgehend.
Bin mal gespannt ob Du es mit dem 5800x3d bess3er hinbekommst.
Leichter ist der nicht zu kühlen...
Knapp 30 Fe's bei EK.
Da muss doch auch mal langsam der Preis droppen oder? Manche haben die Karte schon eine Woche drin.
Können wir bitte wieder mehr über Nvidia Grafikkarten und weniger über AMD CPUen diskutieren?
Möchte jemand ein Cookie für einer der MSIs bei Alternate? Dann versuche ich welche zu fangen :wink:
Pünktlich zum vorhin geposteten Bild eines geschmolzenen 12VHPWR-Steckers sind jetzt auch ATX 3.0-Netzteile von MSI lieferbar. :d
Laut Cybenetics in Ordnung von der Geräuschentwicklung. Avg Noise Output 32.12 dB(A)
Ähnliche Themen
