[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
War bei meiner Gaming OC genau so. Karton war aber perfekt aber nicht versiegelt. Adapter Tüte offen und die Karte an sich ist versiegelt und Aufkleber an den Lüftern und der Backplate. Das Gigabyte Zeichen rechts unten nach Einbau hat keinen.
Gut, wie gesagt die Marken an der Verpackung könnten durch diese blöde Diebstahlsicherung kommen, die in den Märkten immer dran ist. Wurde ja aus einem Berliner Saturn Markt versendet.
Der offene Adapter hat mich beunruhigt.
Dass die Falsch herum drin war kann sein, dass die die im Markt kontrolliert haben ob auch alles bzw. das richtige in der Box ist. Ich rede mir das jetzt mal schön.
Eigentlich ist der Benchmark Müll weder mein noch dein Ergebniss ist Gamestable im Alltag ...
Aber ich kann deinen Ehrgeiz verstehen ;-)
P.S. Radiator im Kaltem Wasserbad könnte helfen ;-)
Kaltes Wasserbad könnte dir auch gut tun vielleicht kommst dann mal zur vernunft und kaufst nicht mehr 100 GPUs von denen 99 zurückgehen ;-)
So Bestellung der 4090 bei Caseking ist abgeschlossen, dann hoffe ich mal, die Karte kommt am Montag :).
Hier übrigens noch ein Review der iChill Black, welche vielversprechend aussieht :) (gibt auch ein paar schöne Bilder)!
Gut das du dich (siehe gestern), HEUTE wieder voll unter Kontrolle hast!
Ich bin bei AMD eher auf die neuen 500€ Modelle gespannt...für nen Freund.
Ob die ne Leistung wie eine 3090 oder 6900XT haben werden. Da würde ein Upgrade von seiner 3060 aus lohnen.
Sorry ohne GPU dastehen macht depressiv 🥲
Mich auch...die 4090FE will einfach nicht in meine Hände fallen...für <2000€...
Und ich sehe es nicht ein für quasi keine Arbeit einem Scalper mehr als nen füffi in die Hand zu drücken...
Edit: Bei mir wartet auch ein 5800X3D, den ich zusammen mit der 4090 einbauen will, da ich dafür den PC auseinander nehmen muss. Die AIO passt nur dann rein, wenn ich den NR200P wortwörtlich in Einzelteile zerlege :d
Wer hat denn bisher für die iChill Black oder Frostbite eine Versandbestätigung erhalten?
Welche CPU hast Du denn jetzt drin. War kurz davor meinen 5900x mit einem 5800x 3d zu tauschen. Aber ich finde keine richtige ussage, dass sich das lohnt. Die einen sagen mehr Kerne sind besser die anderen sagen der Cache ist besser. Manche spiele laufen damit schneller und manche langsamer...
Uuuund das erste native ATX 3.0 Kabel ist abgeraucht :d
Jay. Wie ich schon sagte, da die Adapter für die Tonne sind, dürfte es bei den Kabeln (die auf denselben Spezifikationen beruhen) auch ähnliche Fehler geben. Hier sollte man also eine Generation 2 abwarten, oder man hat eben Glück.
(MSI MEG 1300 hier in dem Fall)
Laut User war das Kabel, der er sich der Probleme bewusst war, nicht stark gebogen und saß bombenfest drinnen.
wasn Witz dieser Stecker
Doch war heute mal kurz auf Grün ....
@UdoG
UEFI / GOP funktioniert nicht wie er soll.
Zeigt kein UEFI Boot logo mehr bzw. wenn dann nur das Windows Logo ...
Hab dem Support von Nvidia ein Video geschickt wo ich offensichtlich zeige das es an der Karte liegt ;-) was ein Aufwand ;-)
Ausreichend für eine 4090?
Ich gehe meistens nach dem Motto "probieren geht über studieren". Mit meinem Corsair HX750i hatte ich @Stock bisher keine Probleme. Die Karte zieht auch bis Dato maximal 400W, kann sich aber mit anderen Games natürlich ändern. Nichtdestotrotz denke ich wären sogar bei 500W noch Reserven verfügbar. Wenn du natürlich vor hast die Karte auf 600W zu preschen, dann könnte es passieren das es mal abschaltet.
Hast Du mal Fastboot ausgeschalten und CSM deaktiviert?
Einen 5950X. :d Ich brauche die 16 Kerne aber nicht und bin mit dem 5800X3D deutlich besser dran.
Bei mir war die Wahl, jetzt wechseln oder in ein paar Jahren.
Heute bekomme ich noch ca 400-450€ für den 5950X, was über dem Kaufpreis des 5800X3D ist.
In ein paar Jahren wird das nicht mehr 400€ sind, sondern möglicherweise weniger.
"Verlust" habe ich so oder so gemacht, da ich damals für den 5950X ca 700€ gezahlt hatte.
Ich hatte einfach die falsche CPU für mich gekauft. Damals gab es leider den 5800X3D noch nicht, also wusste noch keiner wieviel besser der fürs Gaming gewesen wäre. Tja...
Ich habe auch kein Interesse einen 7800X3D zu kaufen, wenn der mal kommt.
Mein Board/RAM ist noch keine 2 Jahre alt und das nächste CPU Upgrade ist erst in 3-4 Jahren geplant.
Schaut euch mal die Bilder genau an. Irgendwie sieht das was in seiner Hand liegt nicht aus wie das beigelegte Kabel von MSI. Das hat nen Gummi-Schrumpfschlauch. Bei ihm sieht es nach Faserband aus. Maybe Fake. Auf keinem der Bilder sieht man das ganze Kabel!
Ich frage mich wann Seasonic die gratis Kabel verschickt, laut ihrer Mail hieß es Ende Oktober, mittlerweile haben wir November und noch keine Versandmail...
Ähnliche Themen
Antworten
6K
Aufrufe
381K
