[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Eben Division 2 angeworfen, aber kein HDR-Content angezeigt bekommen...
Der HDR-Switch steht auf "Auto" hatte ich auch seit Ewigkeiten nicht mehr angefasst. Stelle ich auf "HDR10" hab ich immer noch kein HDR-Content.
Erst, wenn HDR auf "AUS" steht, bekomme ich HDR-Content. Normal ist anders... :confused:
Kann jmd mal schnell nachgucken, wie bei euch der HDR-Switch steht?
edit:
Musste den Treiber neu installieren. Jetzt gehts wieder auf "auto" und "HDR10" :rolleyes2:
Habe gestern auch eine 4090 TUF OC geliefert über Asus Web Shop bekommen. Im Vergleich zur FE, die ich durch Glück ganz am Anfang bei der ersten Ladung ergattern konnte (die ist aber auch schon wieder zurück bei NBB), ist sie im Quiet Mode eine Wohltat gegenüber der FE, also was die Lüfter angeht, einiges leiser bei ähnlichen Temps. Die Spulen sind auch einiges leiser, rasseln und buzzing haben sie natürlich auch, es gibt keine Karten ohne, aber gegenüber der FE vertretbar, die kann bleiben, Spulengeräusche sind mit UV auch noch gut leiser zu bekommen, sodass sie gar nicht mehr stören - mein bisherige 3080 FE ist gegen die Asus 4090 auch einiges lauter. Ob ich auf Wasser umbaue, weiß ich ehrlich gesagt noch nicht, da ich so bei ca. 350W bleiben möchte, ist sie eigentlich weit weg davon störend zu lärmen bzw. regelrecht leise durch den massiven Kühler.
Ich nutze übrigens ein Seasonic Netzteil PRIME TX-750, auch absolut problemfrei selbst bis Kotzgrenze von an die 430 Watt! Ich belege alle vier Stromstecker am Adapter, der, wen richtig, gerade und sorgfältig eingesteckt problemfrei ist, auch bei der FE nach einer Woche und intensiver Nutzung war der Adapter vollkommen ok nach dem Abziehen. Wer Strom sparen möchte, im Idle, im Bios ASPM für PCIE aktivieren, läuft auf meinem Asus Z690-A absolut problemfrei und man hat um die 10 -12 Watt Board Power Draw auf dem Desktop, teils sogar runter bis auf 8 -9 Watt, siehe Screen - in eigentlich allen Tests wird mal wieder nichts davon erwähnt, die Karte arbeitet absolut problemfrei. ;)
Scheinbar hattest Du echt ne kaputte FE erwischt :(
Auf Reddit brennen jetzt sogar schon bei 2 native ATX 3.0 Kabel. Scheint wohl doch nicht am Adapter zu liegen. Mal schauen ob die 4090 Ti dann wieder 3x 8-Pin hat.
Laut User "The cable was not bent, twisted, or manhandled whilst installed."
Auch schon wieder dasselbe MSI Netzteil, allerdings kann das auch daran liegen, dass dieses in den USA besser erhältlich war/ist und dementsprechend die Zahl der Käufer einfach höher ist.
Wie schon vermutet, scheinen wir hier ein Problem mit den Spezifikationen von ATX (Intel) zu haben, da sind die Adapter alleine nicht die einzig "betroffenen".
Wenn man also einen Adapter hat, der keine Probleme macht, sollte man gegebenenfalls einfach die Füße still halten, auf ein Update/neue Revision der Netzteile warten und gut ist.
Ja muss mit Treiber zusammenhängen, hab ich auch ohne DLSS. Dachte zu erst an UV Instabilität, tritt aber auch unter Stock auf.
526 is buggy voherigen verwenden selbst der hotfix ist noch buggy
Wenn das stimmen sollte, dann müssten das ganze atx 3.0 System gestoppt werden.
Wäre dann eine echte Katastrophe :oops:
Oder man sieht das ganze etwas weniger kritisch und die welt geht nicht unter und stoppt einfach nur das MSI Netzteil. Eventuell einfach etwas falsch verbaut oder ein Herstellungsfehler. Es gibt ja bereits ATX 3.0 Netzteile die unter den Menschen sind ohne diese Probleme. Es kann durchaus auch einfach nur am Hersteller und der Produktion liegen. Genauso wie beim Adapter eben. Das wird mit sicherheit auch nur ein Hersteller sein der fehlerhaft produziert hat.
Wenigsten kann jetzt keiner mehr den schwarzen Peter auf Nvidia und dessen QS schieben. Denn beim Netzteil sind die raus.
Wie Igor schon mehrfach erwähnte, warum man auf so winziger Fläche mit Kabelsträngen beginnt, Wattmassen hin und her zu schieben, die durchmessermäßig so in aller Regel in Unterseekabeln zum Einsatz kommen... ist etwas bescheuert...
Hoffentlich ist an ATX 3.0 alles in Ordnung, und die Kabel selbst haben nur Probleme in der Fertigung (vllt. sind die Toleranzen zu hoch). Andernfalls müsste hier natürlich jedes neue Netzteil und JEDE Grafikkarte umgetauscht werden. Das würde ein gewaltiger Rattenschwanz werden...
Welches Tool kann man nehmen um schnell (+/- 1-2 Taktstufen) den Maximaltakt zu ermitteln? Haben wir schon eine Liste bzw. ein Gefühl wie viel Core Clock gut ist bei 1.1V?
das navi 31 block diagram ist übrigens geleaked, hier im vergleich zu Ada
wie geht das denn bitte? unabhängig jetzt von den finanziellen mitteln/background, aber ich habe noch nicht mal eine 4090 in einem shop lagernd gesehen, geschweige im warenkorb gehabt und andere sammeln!!!
Home Office :)
Telegram chat immer offen auf dem Desktop mit dem Verfügbarkeitsbot von Luxx und mit Distill Webseiten aktualisieren, um eingeloggt zu bleiben. Auch auf Paypal bin ich immer eingeloggt.
So geht ein Kaufvorgang meist in 5 Sekunden.
Ich habe nie mehr als 2 Karten bei mir. Soviel will ich jetzt nicht auch hier lagern. Testen und direkt weiter geben, wenn ich nicht zufrieden mit dem OC.
Moin,
ich konnte eine MSI 4090 Suprim X erstehen. Ein bequiet! Kabel soll am Dienstag auch aus Frankreich bei mir ankommen. Trotzdem bin ich aufgrund der aktuellen Lage unsicher, ob ich die Karte behalten soll. Ich hatte meine EVGA 3090 FTW3 nach den New World Geschehnissen ausgetauscht. Auch wenn keine Beschädigungen vorlag. Ich bin eher vorsichtiger Natur. Eure Meinung? :d
Ich habe meine Suprim seid Release und das bequiet Kabel direkt bei Verfügbarkeit gekauft. Habe keine Probleme und bin zu 100%von der Karte überzeugt.
Übrigens, ich habe meine RTX 4090 Gaming OC immer noch nicht eingebaut, seit fast 2 Wochen😂✌️
ABER
Morgen ist es soweit mit dem mitgelieferten Adapter, der sogar SEHR STARK geknickt werden muss 🤪😂 ich halte euch auf dem Laufenden wie lange die RTX 4090 das überlebt 🙏
ich auch, warte auf den Kühlblock, kommt am 14.11.:d, kein Bock Gehäuse zu zersägen, oder neu zu kaufen, solange habe ich noch nie gewartet...
settings runter > weniger last > weniger fiepen :) fps habt ihr ja sowieso alle bei 118 oder 142/162/172
Jede GPU hat fiepen ab einer gewissen Aulastung.
Das scheinen einige noch nicht so ganz begriffen zu haben.
Warum genau hast du dir eine 4090 und sogar das Kabel von bequiet gekauft ? Um das jetzt doch nicht zu nutzen?
Meine Meinung: einfach nutzen und nicht großartig beeinflussen lassen von Panikmachern oder Weltuntergangsphilosophen. Hier nutzen die meisten ihre Kabel, Adapter und ihre 4090 schon Wochen und es gibt so gut wie keine Probleme. Bis auf eben das Treiberthema ab und zu. Viel Spaß mit der neuen Grafikkarte.
Dann bin ich aber froh das es bei mir bis 300 FPS bisher nicht zu hören ist. Wenn es darüber anfängt, kann es ruhig bleiben :)
Und jeder reagiert unterschiedlich empflindlich.
Ich kann bei meiner Karte auch nichts hören.
Meine 6800XT war ohne UV hingegen für mich unerträglich.
Gehe stark davon aus das von AMD DualGPUs kommen aufgrund des Chiplet Designs
Unter Wasser macht das einfach spaß. Mit UV auch noch. Einfach heftig das man unter 4k gute FPS hat und kaum verbrauch und eine ungewöhnlich kühle Karte. Eigentlich kann das so bleiben die nächsten Jahre.
https://www.mboxdrive.com/FE Lüfter.mp4
Hier hört man es ganz gut, ihr müsst evtl. etwas lauter machen. Der Lüfter dreht im Moment der Aufnahme von 30% auf 50% Speed hoch
Klingt relativ normal würde ich so sagen (evtl. Etwas hochfrequenter als bei meiner) … wie die FE Lüfter halt klingen bei steigender Drehzahl.
Immer noch besser als die Zotac Lüfter.
Die rasseln leider ein wenig bei 30%…
das muss schlicht jeder mit sich selbst ausmachen bzw. hören, ob die Geräuschkulisse für ihn ok ist.
absolut richtig. Lautstärkeempfinden muss jeder für sich entscheiden. Manche hören da schon was wo andere nichts hören. Entweder man kommt damit klar, oder eben nicht. Dann muss man agieren.
Ich dachte ja aus dem EU Store wird direkt aus der EU versendet.
Cablmod schreibt "Your order has been picked up by DHL on November 5, 2022"
Der DHL Link hat bisher nur "Shipment Information received", allerdings war das schon am 04.11 um 03:19 Uhr, also schon vor mehr als 32h
Mal schauen wie lange es wirklich dauert :d
Bei mir schon seit dem 1.11. xD
Ähnliche Themen
Antworten
6K
Aufrufe
381K
