[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Kennt jemand von euch dieses Adapterkabel?
Daran muß man nur zwei 8 Pin-PCI Express Stecker anschließen statt die üblichen 4 und das funktioniert?
ja das habe ich hier anfangs mal verteilt und der ein oder andere hat es bestellt. Erfahrungen waren bisher gut. Musst halt das passende Netzteil haben das auch mit 2x8 Pin die 600W stemmen könnte. Da fallen einige raus.
In der Theorie ein NoGo...
6+2 Pin = 150 Watt max, demnach dürfte das Kabel maximal 300W haben...
In der Praxis verträgt der Stecker auch mehr und je nach Netzteil, Rails und Belegung funktionierts...
Ich würds trotzdem lassen...
Das be quiet Kabel kam an und ist gut verarbeitet.Anschließen und fertig.
Links oben sieht es nicht sauber aus aber nix lose und die Pins vorne sehen auch sauber aus. Also passt.
Mein 1200 Watt-Netzteil hat jede PCI-Express-Leitung auf zwei 8 Pin gesplittet, daher sollten eigentlich 300 Watt über ein einzelnes Kabel auch gehen.
ich auch, warte auf den Kühlblock, kommt am 14.11.:d, kein Bock Gehäuse zu zersägen, oder neu zu kaufen, solange habe ich noch nie gewartet...
Ich hatte es auch dermaßen satt zu warten und habe es jetzt eingebaut
Nimm doch einfach den Adapter der beiliegt. Ein bisschen aufpassen und fertig. Dann nur noch losdaddeln.
Wo gibts (oder "gabs") die denn zu kaufen?
Bei Caseking gab es welche. Allerdings preislich nicht geil. Da wäre Block + Karte günstiger gewesen.
Werde meine Tuf auch unter Wasser legen. Einfach aus Spaß. Aber der Block dauert ... ist erstmal unter Luft jetzt. Habe die "alte" Karte schon verkauft.
Hm, wer weiß es, mir war das Spulenkonzert schlicht zu laut, eben ähnlich laut bzw. noch etwas lauter wie die auf meiner 3080, sind ja auch dieselben Spulen. Die Asus klingen schlicht anders und sind für mein Empfinden einfach leiser bzw. angenehmer vom Geräusch her, bei bis zu 450 Watt und mehr können die Dinger aber eben nicht lautlos sein, egal welche Spulenart - das Spulenthema ist einfach das undankbarste Thema überhaupt, das muss schlicht jeder mit sich selbst ausmachen bzw. hören, ob die Geräuschkulisse für ihn ok ist, es gibt einfach keine geräuschlosen Spulen auf den Consumer Karten, egal welche Marke.
Bei mir ist es halt genau andersrum. Meine 3090 Strix war dahingehend fast nervtötend gegenüber meiner 4090 FE und eigentlich nur mit UV zu ertragen. Vielleicht kann ich auch deshalb sogut damit leben aber ich habe den Eindruck, dass die FE minimal vor sich hin surrt. Kein Fiepen! Habe auch paar 4090 TUF Videos angehört und anschießend nicht mehr soviel Lust drauf gehabt. Ich denke aber, dass das in Vids evtl. krasser rüberkommt als in Echt. Gibt halt evtl. doch auch Unterschiede bei den Karten trotz gleicher Hersteller.
Muss es auch. Du bist mit dem Ohr nie so nah dran wie mit dem Handy oder whatever wenn du das Video machst. Wenn du das in Sitzabstand machen würdest, würde man eventuell nichts hören.
Lecker !
Hast du The Division 2 ? da würden mich mal die Temps nach einer Stunde mit OC interessieren da kommt man wenn man die 3GHZ angeht deutlich über 500W.
teste ich nachher mal
wieso hast Du nur 408W bei max Powertarget von 133 erreicht ich mit der FE 486W Leistung !
da stimmt was nicht, hast Du nur 100 als Powertarget eingestellt, anders kann ich mir das nicht ganz erklären.
250l/h Durchfluss schaffe mein Pumpe nicht hab aber mit 190l/h den gleichen Benchmark damit mal durchgeführt.
21c delta bei OC, max PT, max voltage, 150+gpu, 1000+ memory
10 minuten bright infinity benchmark
5120x1440p
rtx: very high
dlss: quality
die active Backplate scheint also bessere Temps zu bringen.
vermutlich tragen die 60l/h mehr Durchfluss auch dazu bei.
schon alles auf anschlag,
ich hab davon schon im OCN gelesen, dass nach waku auf der 4090 der wattverbrauch runtergeht.
ich hab nicht nur dass, mein OC den ich vorher mit luft erreichen konnte, geht jetzt ueberhaupt nicht mehr lol, trotz kuehlere temps ueberall.
@xl_digit + @dante`afk
Was genau wird mit der BP gekühlt? Ich fand das beim "Absolut" recht nice mit dem riesigen WLPad
alles was vorne gekuehlt wird, bekommt hinten auch nen pad.
das hat mir jetzt keine Ruhe gelassen @dante`afk
hab mein EK Block nochmal auseinander gebaut.
die Kryonaut Extreme war wohl nicht die beste Wahl, die normale Kryonaut hat eine bessere Viskosität
hab den Benchmark dannach jetzt nochmal gemacht und komme nun auch auf anständige Werte.
18c delta bei OC, max PT, max voltage, 150+gpu, 1000+ memory
5120x1440p
rtx: very high
dlss: qualityAnhang anzeigen 812320
yep, als ich die paste gesehn habe, hab ich sie direkt wieder verschlossen und eingepackt. hier kommt fuer mich auch nur die pinke thermal grizzly extreme oder kingpin kxp in frage. habe die kxp genommen.
ziemlich begeistert vom EKWB FE block. wahnsinnstemps. kein grund die stock pads gegen 12 w/mk pads zu tauschen wenn max memory temp 36c ist :d
11c delta auf stock, 17c delta auf OC, max PT, max voltage, 250+gpu, 1400+ memory
5120x1440p
rtx: very high
dlss: quality
stock:
OC:
Anhang anzeigen 812283Anhang anzeigen 812284Anhang anzeigen 812285Anhang anzeigen 812286
Sehr geil, und das mit 311 Watt !!!
@TomCom205 Wenn das normal für ne FE ist ok. Finds halt komisch dass der andere Lüfter nicht dieses Geräusch macht. Vielleicht bin ich auch durch die Strix so verwöhnt jetzt..
Das ist normal, da "Heißleiter". Aber fast 80W weniger als @xl_digit wundert mich etwas
Wieviel OC/Takt war es mit Luft?
Kam jetzt endlich bei der KFA2 von Saturn durch nachdem ich es schon den ganzen Morgen probiert hab und immer kurz vorm bezahlen gescheitert bin.
Hab mit PP bezahlt aber bisher noch keine Auftragsbestätigung oder ähnliches, muss ich da noch mit ner stornierung rechnen oder wie läuft das bei MM/Saturn?
edit: hat sich gerade erledigt, bestätigung kam gerade. Bin wohl zu nervös
Es ist doch wirklich wie verhext, ich bekomme keine Gigabyte oder KFA2 Karte bei MM oder Saturn bis zum Bezahlvorgang. Sofort nach Botbenachrichtigung in den Warenkorb gelegt und im nächsten Schritt ist der Button ZUR KASSE schon ausgegraut. Unfassbar ärgerlich!!!!
Ich bleib dran!
Also ich hab die KFA2 schon länger im Warenkorb und war auch schon bevor der Bot angeschlagen hat am refreshen (Gute Deutsche Handarbeit!!)
Wenn der Bot anschlägt gar nicht erst den Link andrücken sondern sofort den Warenkorb wieder aktualisieren.
Vor ca. ner stunde hats bei mir auch nicht ganz gereicht, da kam ich kurz vorm bezahlen drücken nicht weiter.
Aber jetzt ging es.
Unter Wasser macht das einfach spaß. Mit UV auch noch. Einfach heftig das man unter 4k gute FPS hat und kaum verbrauch und eine ungewöhnlich kühle Karte. Eigentlich kann das so bleiben die nächsten Jahre.
Bin total gespannt, freue mich tierisch, mein X38S macht 3840x1600, sollte die Karte doch auch noch ausreizen:unsure:
Gestern bei CK eine Frostbite bestellt - war etwas komisch. In der 4090 Übersicht war die auf nicht lieferbar, die Produktseite zeigte lieferbar. Direkt bestellt, kam dann sofort eine E-Mail:
Bedauerlicherweise müssen wir Ihnen mitteilen, dass der folgende Artikel derzeit nicht lagernd ist:
1x GCI3-219 - INNO3D GeForce RTX 4090 iChill Frostbite, 24576 MB GDDR6X
Voraussichtlicher Liefertermin: Liefertermin derzeit unbekannt
Lustigerweise 3 Stunden später:
Der Status Ihrer Bestellung lautet nun "Komplett abgeschlossen".
Ihre Lieferung mit der Tracking-Nummer: 1XYZYZYZYZYZY wird durch DHL versendet.
Kommt am Montag. Schauen wir mal, was das HX850i mit 850W damit so anfangen kann :d
Ich hab so Bock. :d
Bei der Frostbite ist der Preis wohl einfach Nebensache. :)
Ich hab so Bock. :d
Glückwunsch! Das HX850i kommt locker mit der 4090 klar. Einbauen und danach Freude haben.
Ähnliche Themen
Antworten
6K
Aufrufe
381K
