• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich habe jetzt doch die Asus RTX 4090 TUF OC eingebaut, der beigelegte Adapter ist häßlich aber ich konnte das Gehäuse (BeQuiet Purebase 500DX) schließen ohne das die Glasscheibe den Adapter berührt.
Im Gegensatz zur Gainward RTX 4090 Phantom ist die Asus unfassbar leise, keine Lüfter- oder Motorgeräusche zu hören. Die Karte zirpt zwar etwas unter Volllast aber wenn man den Powertarget auf 75% senkt nimmt man es praktisch nicht mehr wahr. Das Lagergeräusch der Phantom war furchtbar. Die 300 Euro mehr auszugeben lohnen sich, nebenbei ist das auch noch eine 600 Watt-Karte mit besserem PCB.
@UdoG
Hab jetzt das Z690 Dark auf den Testbench geschnallt.
Also beim Dark ist es mit dem Bios...
... leider so dass ich nicht mal mehr ins Bios komme.
Ich musste also alle Einstellungen mit ner andere GraKa machen.
Mit dem Asus Boards kam ich immerhin ins Bios.
Vorab...
@UdoG das was ich jetzt schreiben hat nichts mit dir zu tun .... Sonden Danke für deine Anteilnahme an meinem "Problem" und den Tipp hatte erst das falsche Bios!
Hey der Fehler ist aber bestimmt normal ;-)
Was stelle ich mich so an .... für ne 2K GraKa muss man ja nicht zwingend Bios Einstellungen machen können ;-) Das ist sicher normal und liegt an meinem Netzteil oder Board. Oder an mir ;-)
Vermutlich hab ich auch keine Ahnung was Spulenfiepen überhaupt ist und mach das ja auch erst seit gestern ;-)
Sorry das musste ich mal loswerden ... Einfach zur Verdeutlichung meines Testaufwands ...
Wieder Klappe nicht gehalten... Fu.. it!
Lustig das auf neueren Boards die 4090er Probleme machen können und auf meinem alten z490 Board mit einem 1 Jahr alten BIOS es läuft ^^
Bei AMD Boards funktioniert teilweise das runtertakten des PCI E Ports nicht was zu höheren Verbrauch führt . Z690 Boards kommen manche nicht ins BIOS und gibt spontane reboots im IDLE und bei z590 funktioniert manchmal PCI E 4.0 nur @ 8x
Dann kommt noch hinzu das nach dem BIOS Update von z690 für die Raptorlake es zu Probleme bei der Ram Erkennung auf manchen Ports gibt und m2 CPU nicht mehr funktioniert und die Leute auf Chipsatz umstecken müssen . Mensch nur noch Pfeifen am Werk bei den Herstellern 🤣
Manche Hersteller haben ja teilweise schon mit BIOS Updates nachgeholfen , aber das scheinbar nichts mehr vorab getestet wird ist echt schon hart . Qualitätskontrolle ist was anderes .
Das mit dem Splash Screen hab ich bei meiner 4090 FE auch, die Strix hat das nicht gemacht.. ins Bios komme ich aber trotzdem. Hab das TUF Gaming Z690-Plus Wifi D4
Das kann schon normal sein ... muss aber nicht ... Wenn alles richtig eingestellt ist.
Der Windows Boot sollte im "normalfall" eigentlich beim UEFI Boot nicht so aussehen. (Sofern entsprechende Einstellungen gesetzt sind!)
Da solltest du dein Tuf Logo sehen.
Sehe ich nur beim Asus so:
Beim EVGA bleibts schwarz... Bis ins Windows.
power lmit obwohl er nur 415w zieht, was da los :d
ram konnte ich 1485 machen, nun nur noch 1300. gpu ist gleich +250
Dein HWInfo hat offenbar ein Bug, hast Du mal die neue Version installiert ?
das Du so wenig Watt hast und jetzt noch dazu Powerlimit in GPU-Z angezeigt wird kann was nicht stimmen.
bei mir funktioniert es ja auch.
Was haben eure 4090 für eine Temperatur im Idle? Also ich meine die Stock und nicht umgebaut.
Ca. 35 Grad mit 30% Lüfter.
Habe mir heute Mittag mal spontan einen 13900k bei Alternate abgeholt und eingebaut, damit die 4090 am Montag (wenn sie denn kommt) auch eine ordentliche Basis hat :d. Bisher läuft er ganz gut. Z790 Unify-X und 7600 Corsair RAM kommen dann noch, sobald verfügbar!
32C, 4090FE, 21C Raumtemp
Falls es wen interessiert, 3090 2.1 Ghz, 22GBps vs. 4090 3 Ghz, 24 Gbps skaliert in extrem hohen Auflösungen (VR, 2x5880x4380 Pixel) etwa mit Faktor 1,6 und die 4090 hängt hart am Speicher.
Core OC skaliert sehr schwach (2% Performance aus 6% Takt), Speicher verhätlnissmäßig stark (5% aus 14% Takt). Leider immer noch zu langsam.
Wenn gibts jetzt endlich den vollen AD102 mit 24 Gbps Speicher?
Danke für die antworten. Die scheinen alle ja ziemlich zusammen zu sein. Meine 30Grad 30%Lüfter. Aber Case offen.
nzxt h7 flow 3x 120mm front, 2x 140mm deckel, 1x140 hinten
alle auf 800rpm
TUF-Logo?
Hab bei mir nie eins gesehen. Ist mir auch völlig egal, weil sie das tut, was sie soll - massig FPS pumpen ;)
Hab es nicht genau verfolgt...
Habt ihr wenigstens in etwa die gleichen fps?
Ja normalerweise kommt das TUF Logo, jetzt das Windows Logo so wie bei dir auf dem Bild.. aber das stört mich nicht, im Gegensatz zum Lüfter
Hatte das jemand von euch schonmal?
Task-Manager sagt 100% GPU auslastung. Kann auch schonmal so nicht stimmen.
Hwinfo sagt da glaube eher die Wahrheit. Win11/22H2
ist schon die neueste pro version ^^
ob das kabel/meine karte das macht? selbst mit stock luft vorher konnte ich hoechstens mal 430w ziehen.
Danke. Magst du mir vielleicht verraten, welches Case du nutzt oder ggf. eine Bild posten? Würde gerne den Abstand zum Sidepanel (Karte inkl. Kabel) sehen.
Ich selbst nutze das Phanteks P600S, als Orientierungspunkt nehme ich die maximale Höhe für den CPU Kühler von 190mm. Ich denke damit sollte ich ganz gut aufgestellt sein.
Beides lief mir so über den Weg und da habe ich erst einmal zugeschlagen. Ich lasse mich immer schnell von solchen Geschichten mitreißen und wollte überlegen was ich tue, wenn ich die Karte hier liegen habe.
Zum Release habe ich noch gesagt, "Ich warte dieses Mal ab und kaufe erst nächstes Jahr." Aber wie das immer so ist :d
Ich habe the Tower 900 und bin da so 99 von 100 X raus was die Sache mit dem Tower angeht 😛
Anbei ein Bild ohne Glas
@KamiSam Doch, das mit der hohen GPU-Auslastung durch die dwm.exe stimmt. Das ist ein Bug des NV-Treibers. Kann durch deaktivieren von HAGS in den Windows-Einstellungen gelöst werden.
Idle schwankt so wie bei den anderen. Nach paar Stunden zocken bleibt sie etwas höher so irgendwas mit 40 Grad.
Endlich ist der 4 Zack draußen 🥳
Dann kann ich ohne Stress und anstoßen in nem Define R7 ne Gigabyte unterbringen. 4 Zack Adapter und Anschluss an der Karte waren wild im Betrieb und schauen aus wie neu.
Ist zwar nicht ganz Idle, sondern hab World of Warcraft Classic gerade geöffnet sowie nen Twitch Stream.
Aber Lüfter sind die ganze Zeit aus, und die Karte langweilt sich natürlich
Achja, und kein Spulenfiepen :d Das kommt erst sobald die Karte (Asus TUF OC) 250Watt+ benötigt. Ich genieße die Ruhe gerade
Ähnliche Themen
