[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@Trill Danke hatte die Settings gefunden bzgl. Voltage, ging aber nicht... mit der Beta war es dann möglich.
Für dich als Vergleichswert mit 1050mV macht meine TUF 3060MHz stable im Superposition.
In heutigen Zeiten muss man aufpassen, dass man von so einem Typen keine Anzeige, wegen Diskriminierung bekommt
(Ich sage nur "Anzeige, wegen Nutzung eines falschen Pronomen" :rolleyes2:)
Wie ist denn +180 MHz (auf ner Karte die schon 60 MHz über OEM per default hat) zu bewerten? Reicht ohne Spannungszuschlag nicht für 3 GHz. Mit 1.1V bei 60 Grad dann 3030 MHz.
Speicher ist ganz komisch, super position läuft noch mit +1800 durch und skaliert auch noch, Heaven 4k kackt offenbar mit +1700 schon ab.
Ganz einfach: ein einziger Benchmark ist in keinster Weise genug, um Stabilität zu gewährleisten. Hier braucht man eine ganze Fülle an Tests, die mehrere Stunden laufen - dann kann man von Stabil reden.
Die AMD Software hat immerhin inbuild OC. Frag mich warum das NV GUI diese Funktion nicht hat. Dann könnte man auf diesen dämlichen Afterburner verzichten.
Da bin ich bei dir wäre cool wenn alles über den Treiber gehen würde auch das OC.
Ja das ist schon klar. Nur kenne ich so ein Verhalten beim VRAM nicht.
Falls jemand Familie in Polen hat.
Ich will dann bitte auch eins. 😅
Hier ein Schnäppchen 😜
Gerade bei #eBayKleinanzeigen gefunden. Wie findest du das?
Mit ALLEM auf Anschlag verstehe ICH i.d.R. maximale Einstellungen + Screen Resolution auf 100% + "sinnige" AA-Settings. ;)
Und genau deshalb, weil jeder eine eigene Definition von einem eigentlich absolut konkreten Zustand hat, reden in den Foren alle aneinander vorbei. Find ich traurig. Brauche ich nicht. Produziert nur Missverständnisse und Unzufriedenheit.
Entweder es ist „alles“ oder es ist nicht „alles“. Warum ist es so schwer das auseinander zu halten?
Was Du für eine tolle AA Einstellung hältst kann der nächste doch schon für Schrott halten, weil er andere Präferenzen in Bildqualität und FPS hat. Und schon ist es umsonst.
Da hast Du natürlich vollkommen recht. Man müsse normalerweise, wenn man solche Aussagen in einem Forum tätigt, immer auch zugleich Screenshots der gewählten Settings mit anhängen. Dann gibt es auch keine Missverständnisse. Das machen halt die wenigsten.
Sehe ich das richtig, dass man für das Gigabyte-Cashback bei Alternate keine Bewertung abgeben kann, weil die die Produktseite runternehmen, wenn die Karte nicht verfügbar ist? :oops:
und so manche Games packes das dann sowieso nicht, viele Benchmark- Tweaks sind sowieso nicht alltagstauglich.
Hier muss schon Stundenlang mit diversen Games getestet werden um das optimale auszuloten.
Nachdem man das dort machen soll wo man gekauft hat... Blöde Nummer...
Amen!
Das ist doch safe der experte hier
Da war bei mir nix. Auch kein Aufkleber auf der Schraube. Hätte ich das eventuell sogar reklamieren sollen. Mhh..
Dann hast Du ein Problem. Denn die Backplate ist mit einem Siegel auf das PCB versehen. Aber Du hsat ja sowie so schon umgebaut, von daher spielt es wohl keine Rolle mehr. Weil Garantie erloschen.
Sagmal, habe ihr auch seit dem Patch Probleme mit COD MW2? Sorry für OT. Meine 4090 lief mit den UV Settings super stable. Seit gestern keine Chance mehr. Bereits den Takt reduziert. Dann ging es mal gut und heute mit dem reduzierten Takt genau die gleichen Probleme, obwohl es gestern Abend ging... Komme da nicht mehr mit... Integrität etc bereits überprüft.
@***** und @HisN
Auch nett (Kingdom Come Deliverance)
Urgh das sieht ja echt mies aus...und ich meine die harten Schatten...hier müssen raytraced Shadows her...
Auch die Texturen sehen nicht so toll aus, total Flach...Aber das ist nur mein Geschmack...
"On Demand Texture Streaming" mal deaktiviert? Hatte auch Probleme Anfang liefs gut, dann immer eingefroren, egal mit welchen GPU Settings. Texture Streaming aus und es läuft wieder.
Ich habe kein Problem. Darüber mache ich mir garkeine Gedanken :)
Es ist wie es ist. Garantie habe ich noch nie gebraucht. Und falls es so wäre, würde ich das auch durchbekommen.
Wofür brauchen wir dann alle eine 4090 ? :ROFLMAO:
@***** und @HisN
Hab ich mit der 4090 und dem 13900k tatsächlich auch gerade ne neue Runde angefangen, weil die Schatten so dermaßen auf die CPU gehen, dass die Graka alleine das gar nicht richtig rausgezogen hat auf meinem alten Ryzen. Jetzt ist es perfekt.
Da hat sich meine 3090 die zähne ausgebissen. Wie läuft es mit der 4090? Geht maxed out 4k?
Kommt wie üblich darauf an, wie man "maxed out" definiert, und wie schnell der Prozessor ist, der die Schatten berechnet. Bringt ja nix wenn Du wegen der "maxed out" Schatten ständig 20 Min-FPS hast.
Man findet aber bestimmt einen guten Kompromiss.
Gibt ja kaum Games, die sehr viel schönere Texturen haben
Ich habe mein Cyberpunk mit 4K Quixel Texturen vollgeklatscht (Die ganzen Oberflächen wie Asphalt, Gras, Schotter, usw.) und das sieht schon lecker aus. Komme dadurch auf 20-22gb VRAM Auslastung, sodass man den gigantischen Speicher auch mal tatsächlich nutzt beim zocken. *Edit: Wer es mal ausprobieren möchte kann mich gerne anschreiben, habe es bei Googledrive hochgeladen. Hier mal ein paar Vergleiche: https://imgsli.com/MTAzMjIy/0/1 https://imgsli.com/MTAzMjI0/4/5 https://imgsli.com/MTAzMjI5/4/5
link? :) nexumods?
Ähnliche Themen
Antworten
6K
Aufrufe
381K
