[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Alle die hier eine RTX 4090 am laufen haben, mit welchen Netzteil hab ihr eure RTX 4090 am laufen? Und läuft alles in Ordnung mit den 12VHPWR Kabel ohne anbrennen etc.?
NT: Fractal Design Ion+ Platinum 860Wt
Hab mal an den Adapter gepackt nach paar Stunden Gaming und war sogar ziemlich kühl. Reinschauen habe ich mich nicht getraut :fresse:
Mit Armoury Crate oder besser Evga Prec X. Hab aber keine FE, bei der 3090 war es so
Ohje Armoury hab ich mir geschworen nie wieder zu installieren. Muss mal etwas recherchieren.
Riecht etwas seltsam aber passt schon.
Nein Mal im Ernst, bei bisher 100k verkauften Karten hält sich das noch gut in Grenzen.
So Leute, ich möchte hier den Code für das "press_build_nvidia" Update für Cyberpunk 2077 auf Steam mit euch zu teilen!
Geht einfach in eurer Steambibliothek mit der rechten Maustaste auf Cyberpunk 2077 -> Eigenschaften -> Betas und tragt dort (F17WZy1H6rWVyujz) ein
Dann startet das Spiel aus dem Ordner raus: bin\x64\Cyberpunk.exe
Und voila, ihr habt DLSS 3 und Frame Generation zur Auswahl :)
Viel Spaß beim Testen :)
So, habe die Shice jetzt mal etwas ausprobiert.
Ein paar Zahlen:
DLDSR 2.25x, DLSSoff, FGoff: ca 32fps
DLSS-Qoff, FGon: ca 64fps
DLSS-Qon, FGon: ca 94fps.
Bei DLSS-Qon gibt es natürlich ein paar Artefakte, etwa wie hier zu sehen, beim Rückwärtslaufen:
Zu sehen sind schwarze "Flammen" oberhalb des Schriftzugs "BRAIN". Auch der violette Dingsbums "flammt" ein wenig an der Oberseite.
Auffallend ist das auch bei Stromleitungen, vorallem wenn sie noch dünn (also in der Ferne) sind. Erinnert an frühste DLSS Versionen.
Artefakte wie in Spiderman (zerhackte Arme und ähnliches) sind mir nicht aufgefallen.
Ghosting beim Autofahren (hinter der hinteren Stroßstange) konnte ich auch nicht wahrnehmen.
Inputlag: Es ist schon mal nativ ein kleiner Inputlag vorhanden. Ich bilde mir ein, dass es mit FGon dezent zunimmt. Allerdings ist das so an der Schwelle "könnte sein, muss nicht sein, Einbildung", jedenfalls subjektiv nicht eindeutig als Zunahme eines Inputlags beschreibbar. Durch die Verdoppleung der fps fühlt es sich aber sicher nicht direkter an.
Hey Leute, wie kann es eigentlich sein, dass es noch immer kein offizielles Statement von Nvidia gibt? Schon ein ziemliches Armutszeugnis, die Sache so totzuschweigen.
Da hat sich meine 3090 die zähne ausgebissen. Wie läuft es mit der 4090? Geht maxed out 4k?
Hatte es mal kurz mit WQHD getestet und es fühlte sich nicht rund an. Könnte aber auch an der tollen Cryengine liegen...
habe ich mir gedacht. der titel könnte can it run crysis ablösen :-) Spiel war aber ganz gut. Tolle Atmosphäre. und bis heute der beste Wald!
Be quiet Straight Power 10, 700 Watt, bisher keine Probleme mit dem Adapter. Nach 2 Wochen mal abgemacht, man sieht nix. ^^
Ya alles cool hier. Corsair HX850.
Habe 1h lang 530W durch den Stecker geballert, kein Thema. (y)
Puh keine Ahnung. Entweder kommt tatsächlich noch was oder sie warten bis sich die schlechten Adapter von selbst kenntlich machen bzw.aussortieren...(ein paar haben dies ja schon getan)
noch 2 lagernd: FSP PC- NETZTEIL FORTRON HYDRO PTM PRO ATX3.0 1200W 80+PLATINUM 245€
Laut Bewertungen verkaufen die nicht selbst, sondern kaufen in anderen Shops, mit der Lieferadresse des Kunden :<
700 Watt, passiv, brennt jeden Tag die Hütte, die Feuerwehr hat keinen Bock mehr und kommt auch nicht mehr.
Inzwischen habe ich mich aber daran gewöhnt und grille mein Fleisch über den PC- Feuer 🔥
Die paar Tage kann man nun auch auf die Big Player warten, ich hole mir im Dezember wohl ein ATX 3.0 von (Platinum/1200W) Seasonic:
Obwohl ich mir nicht sicher bin ob ich das tatsächlich machen muss/soll/will.
Mein 700W läuft hier wirklich ohne Probleme, egal wie sehr und lange ich es quäle 🤔
Obwohl ich mir nicht sicher bin ob ich das tatsächlich machen muss/soll. Mein 700W läuft hier wirklich ohne Probleme, egal wie sehr und lange ich es quäle 🤔
same :d
Hatte das Silverstone ATX 3.0 850W dran aber irgendwie wollte das nicht so richtig. Bin dann wieder auf das 1000W Straight Power 11 zurück. Es roch jeden tag verschmort, aber wenn ich aus dem Haus gehe roch es draußen auch so. Adapter ist Top in Schuss.
Lass es, ich habe mir ein ATX 3.0 direkt zur GPU dazu bestellt und bin wieder zurück. Irgendwie wurde ich mit dem Netzteil nicht warm. Es ist auch nicht nötig.
Lol ich hatte eine 4090FE auf Ebay ersteigert und nun bricht der Verkäufer den Kauf ab, mit dem Grund er habe die Karte auf dem Bild schon in einem PC eingebaut und keine neue bei NBB bekommen.
Ist eigentlich nicht erlaubt, kannst du melden. Verkauf bindet.
Die Zotac Trinity bei equippr ist übrigens noch lagernd, falls wer Interesse an einer 4090 hat.
Seasonic Prime Ultra 1300 Watt Platinum. Mit dem beiliegenden 12VHPWR Adapter und alles bestens 👌
Würde ich ja knallhart bleiben. Sein Problem.
Hoffe du bestehst weiterhin darauf... der hat es nicht anders verdient.
Ok.. Danke für das Teilen. Habe mal reingeschaut.. hab wieder zurückgestellt erstmal. Wenn das FrameGeneration an ist, fühlt es sich beim ansehen zwar schneller an, aber die Bild-Fehler sind für mich deutlich sichtbar. Überall leichtes Flackern bei Zäunen. Obwohl ich Vsync nicht an habe und unter 120 Hz bin, hab ich im Oberen Bildschirmbereich teilweise so eine Art Bild-zerreissen. Wenn ich mit dem Caliburn rumfahre und seitlich draufschaue.. Je nach Blickwinkel, gehen die Felgen.. übelst ab mit Fehlern und Ghosting. Das hab ich auch sehr oft beim drehen. Besonders bei dünnen Linien oder Zäunen. Bei der Jig Jig Street, sind die 30FPS mehr zwar schön, aber trotzdem seh ich das Microruckeln durch das CPU Limit (I7 8700k). Vielleicht bin ich auch zu empfindlich. DLSS auf Quality reicht mir.. das FrameGeneration ist irgendwie nichts für mich bei Cyberpunk. Mal sehen, vllt mit dem Update, wenn Raytracing aufgebohrt wird.
Dann opfert man die Qualität durch neue schönere Features.. :)
Das Problem ist, für Ebay ist alles OK, weil er ja den Kauf über Ebay selbst abgebrochen hat. Geld ist schon zurückgebucht. Die können/wollen da nicht helfen.
Aber lassen wir das, der Thread ist nicht fürs Ebay-Recht. Wenn einer Hilfe anbieten will :P bitte über PN.
Es gibt bei Ebay sogar ne Seite dafür:
bitte löschen, vorheriger Text wurde geändert...
Ähnliche Themen
