[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Kann man mit irgendeinem Beta Bios den 5800x3d im Uefi PBO einstellen? Oder ist immer noch die PBO Tuner 2 Software von Nöten? Bei mir läuft er in letzter Zeit immer Stock
In meinem Gigabyte Bios kann ich PBO Werte einstellen. Das und noch mehr soll auch bei manchen Asus Boards gehen. Aber den CO musst Du mit PBO2 Tuner machen. MSI soll auch noch ein Bios haben wo das freigeschaltet ist.
Jetzt ist es mit FG fast immer auf 120. Vorher ist es auf 105-110 eingebrochen.
Die 300 Seiten Steckerbeiträge brennen sich ins Hirn. Hab geträumt wie mein Stecker komplett geschmolzen ist und ich Kabel dran gelötet hab auf normale PCIE 8Pin. Als ich aufgestanden bin wollt ich ein Foto hier fürs Forum machen erst dann merkte ich das das ein Traum war :ROFLMAO: Der 19euro China Adapter ist noch ganz.
Damit du nicht mehr davon träumst, gehst du besser in den RDNA3 Thread, da passiert sowas nicht...
Also ich träume nur von Dingen ohne Stecker. :)
hab gerade ein sehr unschönes Rsonanz-Verhalten bei meiner SuprimX festgestellt,
kann mir jemend ein Gefallen tun, und mal im Afterburner die Lüfter Speed auf 46 Prozent setzen?
Und schauen ob es auch zu unschönen Geräuschen kommt?
Das gPU Bracket ist es übrigends nicht, das habe ich vorher von der Karte gelöst.
Macht das Bracket grundsätzlich bei euch allen mehr oder weniger Geräusche?
Ich warte nämlich gerade auf den Austausch meiner GPU und bin mir unsicher, ob ich das Bracket überhaupt verwenden soll🤔
Also wie gesagt ich habe das Bracket so verstellt das es nicht aufliegt, macht kein Unterschied, aufgefallen ist mir dieses Geräusch zum ersten Mal beim Start wenn die Lüfter hochfahren.
Während dem Spielen hörst du es nicht, aber sobald eben die Lüfter die 46 Prozent erreichen geht es ab.
Kann sein das eben diese bestimmte Drehtahl Resonanzen erzeugt, welche sich dann eben vom Gehäuse aus verstärken.
Die Frage ist, ob das nur bei meiner Karte/Setup so ist. oder ob es ein prinzipielles Problem bei den MSIs ist?
Hab leider kein Riser-Kabel ansonsten hätte ich die Karte mal anders eingebaut
Ähm, wie wäre es mit einer Wasserkühlung?
Das wäre ein Workaround, wobei der Lüfter bei anderer Drehzahl schon leise ist und die Karte sehr gut kühlt.
Ist halt ein gewisser Aufwand, weiß nicht ob sich das letztendlich lohnt.
Gibt die ersten 4080 Gamign Benchmarks: Die 4090 ist 8-39% schneller als die 4080. Der große Gap weist denke ich darauf hin das da noch mit Treibern und Optimisierung der Abstand verringert werden kann.
Mit OC erreiche ich max. 21812 Graphics Punkte mit der 4090. Das wären dann ca. 112%. Also 34% zur 4080 mit OC + Power Limit.
Moinsen zusammen, weiß jemand, ob es diese Woche irgendwo in Europa schon einen FE drop gab?
Kann schon sein das es ne Schwingung genau in dem Bereich ist. Mal die Karte an sich festhalten in dem Bereich oder einzelne Lüfter um die genau einzugrenzen. War es schon von Anfang an so oder gibt es im Gehäuse etwas das mitschwingt (Lüfter/Seitenwand an sich/ ne loose Schraube oder SSD an der Rückwand usw.)
Das hört sich eher danach an, als würde ein stück Blech bzw ne Kühlfinne schleifen..
Bei der FE hieße es zurechtbiegen :d
Anscheinen haben wir nun den Preis gefunden, wo Vernunft einkehrt... ;)
TUF OC schon länger verfügbar für 2450...
Die Vernunft sollte min UVP sein den das ist schon unvernünftig genug.
Die Karten trennen vielleicht 2% von 1950Euro bis 2330 Euro Strixx das sind fast 400 Euro für einen besseren Kühler und ein stärker ausgestattetes PCB mehr auch nicht und das ist schon arg viel bei der Preis Differenz.
Vermutlich dann auch noch Retour Ware !
Werde es heute Abend mal genauer untersuchen, aufgefallen ist es mir durch Zufall gestern Abend als ich ne andere NVME einbauen wollte und den PC bei offenen Case hochfuhr.
Bin dann hergegangen und hab schrittweise die Lüfterdrehzahl erhöht, bei 46 Prozent war es dann soweit.
Hab mir jetzt Gummi-Ringe zur Entkopplung besorgt, werde die heute Abend mal einsetzen und hören ob das Geräusch verschwindet.
Für die History :) und verkaufte Einheiten.
ach ja... die MSI Suprim X hätte ich auch gerne gehabt (zum fairen Preis natürlich)
hab dafür eine ASUS TUF (für 1950,- bei ASUS) und TUF OC (2300,- MediaMarkt) bekommen
welche würdet ihr behalten?
Sollten ja von der Technik her gleich identisch sein, lediglich etwas hoch getaktet bei der OC vom Hersteller her, was man auch selbst machen könnte, oder?
Die für 1949€
1950 Rest wen noch nicht geschehen für Neue Platform bei Seite legen !
Wäre die andere ne Strix dann hätte ich die Behalten :-) obwohl auch unvernünftig aber leider geil 🤩
Hab bei meiner 3090 Suprim X die Lüfter wechseln müssen weil die einfach nervige Nebengeräusche gemacht haben. Denke bei der Qualität wird sich zur 4090 nichts getan haben.
Ähnliche Themen
