[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hat einer schon das bequit Kabel von reichelt bekommen oder zumindest ne versandmail? Bestellt am Montag
Ich bestelle erst eine 4090, wenn es grüne Gratis-Vaseline dazu gibt. Alles andere ist mir zu unsicher!
Und wo gedenkst du sie einzuführen? Also die Karte :fresse2:
Kannste lange warten. Angeblich sollte Reichelt letzte Woche Freitag beliefert werden, aber da kam bis heute wohl nichts von BeQuiet.
Ich warte schon seit über 2 Wochen.
Also ich habe den Adapter für mich persönlich deswegen weggeschmissen , weil ich dann erfahren habe , dass diese mit 8 Leitungen billigst da drauf gelötet ist und man halt durch eine Sicht Prüfung nicht feststellen kann das etwas ggf. nicht stimmt .
Bei dem Corsair oder bequiet Kabel ist jede Leitung separat gequetscht und dann kann man auch anhand einer Sichtprüfung erkennen ob ggf. etwas nicht inordnung ist wie es scheinbar anfangs bei paar wenigen bequiet Kabel der Fall war .
Mit dem Corsair Kabel bin ich recht zufrieden auch die Tatsache das es flach und nicht gesleevet ist finde ich vorerst gut , weil da halt bis 600 Watt durch müssen und keine 150 Watt wie zuvor . Man muss da erstmal mehr Erfahrungswerte abwarten und finde es erstmal gut das Corsair dies so erstmal gemacht haben .
Dazu kann man das Kabel gut vorbiegen.
Natürlich vor dem einstecken :d
Ich denke auch das paar Fälle wegen Doofheit und paar wegen mangelhafter Qualität aufgetreten sind .Dazu finde ich schon wer PC zusammenbaut sollte einigermaßen wissen was er da tut , weil kann auch Autoteile bestellen und am Auto Schrauben… bisschen Ahnung und technisches Verständnis sollte vorhanden sein .
Was ich allerdings sehr bedauerlich finde ist, dass es bis jetzt nicht einmal von Nvidia eine richtige Stellungnahme gab und wenn das Thema wirklich von Hersteller Seite totgeschwiegen wird , dann wäre dies wirklich traurig .
Jau, klappt schon bald mal - auch haben viele eines nicht auf dem Radar und das ist DLSS 3! Und hier meine ich nicht das DLSS wobei in niedriger Auflösung gerendert und dann hochscaliert wird, sondern ich meine das Einfügen von Zwischenbildern also DLSS Frame Generation bei nativer Auflösung. Da ist Grenzgenial und funktioniert mit Spider-Man Remastered und A Plague Tale: Requiem schon super. In A Plague Tale: Requiem alles auf volle Pulle in 4K, die 4090 auf 250 Watt limitieren, Frame Generation an und man hat statt 60 Frames zwischen 80 - 100. Das ist ein Feature, was derzeit viel zu wenig beachtet findet und hat enorm Potenzial, weil es Strom spart und auch dann hohe Frames ermöglicht, wenn das Game fordernd ist, die Latenz bekommt man schon in den Griff mit späteren Treibern.
Ich habe da bei 350W 120FPS
So auch mein Plan sollte dieses mal länger bleiben .
2334 Euro kostet die Strixx OC im Asus Shop ich würde für 100 Euro drauf auch eine kaufen dann ist aber auch Schluss.
Das Problem ist ich erwische ja nie einen Droop.
Die Karte gab es heute für ca. 35 Sekunden zu kaufen im ASUS Shop. Keine Ahnung, warum der Bot nicht angeht.
Der Preis ist hei
Was bedeutet Outlet Rückläufer ?
Über 200€ mehr als im Asus Shop mein
Over 9000.
So ein wenig fühl ich mich schon von CableMod beschissen, der 9. ist verstrichen, jetzt danken sie mir nur für meine Geduld :d
Es ist einfach ein unding, dass man Bestellungen nur 24h lang stornieren kann, es ist KEIN Custom Cable...
Der Laden ist das letzte. Die Lieferzeiten jenseits von gut und böse. Auf Supportticket kommt immer die Mail das alles verschickt sei.
Aber nix passiert. Nicht mehr zu empfehlen.
Mal ein aktueller Benchmark mit Forza 5 und dem neusten Raytracing Patch, alles auf Anschlag:
Mit 16GB Ram wird´s inzwischen knapp sehe ich gerade, man sollte inzwischen wohl grundsätzlich 32GB empfehlen.
Der Preis ist hei
Bei mir wurde auf Kulanz storniert, einfach e-mail schreiben an support...
Ob das besser ist 😁 jetzt nur noch warten auf mein Thermaltake ATX 3.0 Netzteil und dann damit verbinden. Auch wenn beim ATX 3.0 einiges 12VHPWR Kabel drin ist.
Hab den Verdacht das Be Quiet kaum/gar keine Händler beliefert. Bei CU ist die Lieferung auch ausstehend seit Wochen
Meine Anfrage an Be Quiet:
"Hallo,
wollte das Kabel bei Veröffentlichung bestellen aber hatte bei Computer Universe eine Stornierung bekommen.
Das Kabel gibt es niergends.
Habt Ihr davon nur 30 Stück produziert???
Gibt es die noch irgendwann einmal oder macht ein Netzteil eines anderen HErstellers mehr SInn?
Danke"
Antwort Bequiet:
herzlichen Dank, dass Sie mit dem be quiet! Service Kontakt aufgenommen haben.
Die Kabel waren leider innerhalb kürzester Zeit vergriffen.
Aktuell ist es so, dass wir auch keine Bestände mehr haben.
Wir bitten Sie daher sich an einen Händler Ihrer Wahl zu wenden um dieses Kabel käuflich zu erwerben.
Suchen Sie diesbezüglich bitte einfach nach folgender Artikelnummer: BC072
https://www.bequiet.com/de/accessories/3959
Über aktuelle Verfügbarkeiten bei Händlern können wir keine Auskünfte geben.
Dies kann der Händler nur direkt.
Soweit wir informiert sind, soll dieses bei Reichelt in Kürze wieder lieferbar sein."
Meine Rückfrage:
Also wenn Sie nicht wissen wann es diese Kabel wieder geben soll... Wer dann???
Die Händler haben alle nichts auf Lager.
Warum bekommt denn eventuell vielleicht oder auch nicht reichelt etwas?
Sind nun neue Produktionen geplant oder nicht?
Danke"
Antwort Bequiet
wir als Hersteller verkaufen unsere Produkte oder Zubehör an Händler oder Großhändler.
Diese erhalten dann einen ungefähres Lieferdatum.
Aus diesem Grund kann Ihnen der ausgewählte Händler mitteilen, wann er voraussichtlich wieder Ware von uns erhält.
Aktuell haben wir das Kabel leider nicht auf Lager, sonst hätten wir Ihnen gerne die Kabel angeboten.
Aus diesem Grund können wir Sie leider nur um Geduld bitten.
Netzteile mit dem ATX 3.0 Standard sind für das Quartal 1 – 2023 geplant."
Das Gratiskabel von Seasonic ist auf dem Weg zu mir.
Finde das MEGA kulant !!!
Wann hast du die Versand Mitteilung bekommen? Hatte letzte Woche bei Seasonic nachgefragt wann der Versand losgeht, Antwort "End of next week", bei mir hat sich aber bis dato noch nichts getan
"Hallo,
Danke"
Antwort Bequiet:
Meine Rückfrage:
Danke"
Antwort Bequiet
Oh man, dann wird das auch nix mit dem Adapter. Dann kann ich ja nur hoffen das das thermaltake die Tage kommt
mit nem fanless 700watt kann ich das kabel nichtmal beantragen. die karte zieht eh nicht mehr als 300w mit uv :poop:
Einfach den Support mal anschreiben, konnte auch 48 Stunden nach Bestellung noch stornieren, vielleicht geht's in Einzelfällen auch länger
Mfg
Kiryu
Also ich verstehe die RTX 4090 Käufer nicht, die 400-500 über UVP kaufen. Vor allem nicht, wenn andere Händler es 100 Euro günstiger anbieten!?
Die Palit Gamerock, Scalpfactory 100 Euro teurer als CU, equippr, PC KIng und NBB (Alle 100 Euro günstiger und vorrätig), und trotzdem spring es von 130 auf 140 verkaufte Karten rauf.
Finde den Fehler^^
Bei MF sind die Karten aber scheinbar trotzdem schnell weg. Von vorhin 8 verfügbaren, nur noch 4 ;)
Over 9000.
Da kannst noch ne Weile warten, bei mir wars der 05.11. und es tut sich nix :rolleyes2:
  • Danke
Reaktionen: hwk
Denke das sind Vertragspartner von irgendwelchen Kleinfirmen oder IT-Rahmenverträgen. Die haben halt nur MF auf dem Schirm. Also bei mir im Laden wird so massiv überpreisig Hardware gekauft...
Ich hab das Kabel gleich wieder eingepackt. Die Qualität wirkt ziemlich schlecht. Die Pins sind bei mir nicht alle gleich ausgerichtet etc. Nimm lieber das Kabel von deinem neuen Netzteil.
Da bin ich ja froh das ich das be quiet Kabel von Okluge Amazon bestellt hatte, dachte das wäre jetzt großflächig verfügbar, leider anscheinend nicht. Habs jetzt nach paar Tagen Betrieb mal abgesteckt und geschaut - alles einwandfrei. Ich denke trotzdem das der Markt mit GPUs noch lange nicht gesättigt ist.
An meinem beigelegten Tuf Adapter ist auch alles ok. Der war sogar die erste Woche nicht richtig eingesteckt. Da war noch knapp 0.5mm Spalt. Wusste nicht, dass man so viel Kraft beim ersten einstecken aufwänden muss.
Ähnliche Themen
