[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
TUF Thermalpads
Weiß jemand wie dick die Thermalpads für den VRAM sind?
Würde meine gern mit festeren besser leitenden erneuern.
Habe gelesen, dass die tweilweise unsauber aufgebracht sind.
Dann sind die noch zudem so dick und weich.
Mein Ram kackt bei +900mhz ab. Lese hier dauernd von 1500-1800mhz +.
Da kann doch bei mir was nicht stimmen?
TUF Thermalpads
Glaube 2-2,5 mm Pads beim Vram.
Hatte selber bisher im Gaming max. 66°C Vram Temps laut HWINFO mit P BIOS.
Im test waren dort 74°C gemessen worden bei CB
Hatte im Bench bis 1500 MHZ 80% Lüfter durch bekommen , aber im loop nicht stable. Port Royal / Timespy Extreme
+1000 MHZ bei Lüfter 80% waren soweit safe . Dazwischen habe ich aber nicht genau ausgelotet .
Unter Wasser geht da sicher noch was. Ja das schwankt auch sehr mit der Güte.
Bei wieviel Grad denn? Meiner macht ab +1000 dicht aber die Temps sind eigentlich ziemlich gut.
Die Temps spielen keine Rolle. Auch wenn die Karte noch kalt ist kackt es sofort mit einem Blackscreen und Driver Restart ab.
Also hast Du auch das Problem. Ich vermute das liegt an den dicken Pads und das die teilweise nicht den ganzen Ram überdecken.
Alle anderen Karten wo der Kühler im Rambereich dicker ist machen 1500.
Nur 2 Tufs nicht. Deine und meine. Vielleicht haben ja hier andere die gleiche Erfahrung...
Vielleicht weiß jemand durch den Umbau auf Wasser das genaue Mass. Würde mir gern die harten Pads kaufen. Da ist dann nicht viel Toleranz. Oder noch besser ein Coppermod. Echt arm von Asus. Dickes fettes metalshroud und Kühlerplatte schlechter als jede Billigkarte.
Dass das beim O11 XL so eng ist hätt ich nicht gedacht.
Stellt euch mal nicht so an. Bei meinem Kollegen hat das wunderbar gepasst. War zwar nicht einfach die Glasscheibe zu schließen, aber zu ist zu und der Adapter ist obendrein auch noch dezent verlegt. :coolblue:
Also ich habe kein ECC aktiv. Bei mir kackt dann auch der Bench ab wenn es zu viel ist .
Haben manche im Treiber ECC eingeschaltet? Das würde erklären, wieso bei denen 1500+ stable läuft :shot:
Bringt das wirklich was, um hohen Speichertakt durch benchmarks zu bringen?
Hast dann weniger Punkte , weil dann die Fehlerkorrektur läuft.
Habe auch bei manchen gesehen die höheren GPU und Speichertakt gebencht haben aber weniger Grafikpunkte als ich hatten.
Meine TUF OC macht auch +1500 im Benchmark mit. Aber in Games habe ich minimale, kaum sichtbar Fehler bei +1200 MHz.
+1000 sieht ganz gut bisher aus. Bin noch am Testen.
Sollte es nicht eher andersherum sein? ECC Ein = Fehlerkorrektur an, RAM schmiert ab, sobald Fehler in den Berechnungen auftauchen = niedrigeres OC Potential // ECC Aus = Fehlerkorrektur aus, RAM läuft durch obwohl der weiß Gott was zusammenrechnet, was Bildfehler verursachen kann = höheres OC Potential?
Meine FE hab' ich ingame auf aktuell +1500, aber es liefen in allen getesteten Benches bisher auch die +2000... was mich wundert. ECC aus.
Ne mit ECC siehst du die Fehler ja nicht :d, werden ja korrigiert...
Bei +1000 hab ich schon aufem Desktop Bildfehler. ECC hatte ich bis dato nie an.
Kann hier höchstens mit +1300 durch 3dMark gehen, die Speicherchip Qualität scheint leider stark zu schwanken . /:
Nachricht gelöscht
Damit eine Karte wirklich bei +1500 oder gar +2000 stable ist, muss man 12mal Glück haben!!
Jeder Speicherbaustein auf der Karte muss das mitmachen.
Exakt, daher bin ich auch so verwundert.
Ist aber auch am Ende des Tages egal... ich will ja kein Max-OC, die Karte läuft eh im Gaming-Betrieb mit UV, und solange ich bei +1500 keine Bildfehler sehe, bleibts auch einfach dabei. Es muss ja nicht alles an der Kotzgrenze laufen :)
Ja aufjedenfall. Besitze keine persönlich aber konnte mal an einer rumspielen. :d
Die Grafikfehler werden auch korrekt angezeigt :d
Genau so sehe ich es auch und sogar noch strenger. Bei mir muss die Karte nur immer so viel leisten, wie es für mich von den FPS und Verbrauch her vernünftig erscheint. Und bisher gebe ich mich erst zufrieden wenn ich in 4k ultra und min. Raytracing normal unter 250 Watt verbrauche. Mehr kommt defintiv nicht in Frage und wird immer reduziert! Ich schmeiße doch nicht mein hart erarbeitetes Geld aus dem Fenster für ein paar lausige FPS oder Details mehr, die ich im Spiele Fluss sowieso nicht bemerke!!!
Ansonsten sollte man die Grünen aus dem Bundestag schmeißen und denen noch einen ordentlicheb Arschtritt verpassen für ihre seltendämliche Energiepolitik. Strom muss wieder zu normalen Preisen erwirtschaftet werden!
Du hast aber auch eine 4090 oder? :d Kann es verstehen haha, find die Aussage nur lustig.
Eventuell sind die auch wirklich Temp empfindlich. Mann kennt es vom Samsung B-Die, manche kacken bei 45°C ab, andere laufen bis 60°C ohne Probleme.
Am Ende ist es schwer einzuschätzen. Dass können auch nur Leute, die ne Karte haben mit +800 oder +1000, anschließend nen Block montieren mit genug Kühlfläche und abschließend berichten, ob tatsächlich mehr geht.
Meine @dante`afk hatte durch sein EKWB Sandwitch mehr erreichen können , aber bin mir grad nicht sicher.
Er hatte im Anschluss definitv sehr niedrige Vram Temps.
Zum Verständnis, für jemand der manuell seine Karte tweaked hat das ganze "OC" oder "non OC" doch sowieso keine Bedeutung? Hab es immer so verstanden das nur Karten die ein Bios haben die ein höheres Power Limit erlauben so wirklich besser performen können. Schließlich kann ich auf ner TUF "normal" wie auch einer TUF OC einfach den Takt manuell anpassen?!
Habe ich und ich finde es auch selbst lustig!
Bin auf die ersten handfesten Benchmarks der RX 7900 XTX gespannt und werde die RTX 4090 evtl wieder verkaufen, da ich einfach immer wieder merke wie unwichtig Raytracing für mich ist und wie wenig das einfach im Vergleich zu ohne Raytracing ausmacht. Da ist mir eine günstigere und dennoch ausreichend leistungsstarke GPU wichtiger.
Wollte sowieso eigentlich auf die AMD Karten warten aber dennoch auch Raytracing endlich mal eine Chance geben nach meiner RX 6900 XT LC, die immer komplett ohne RT verwendet habe und merke jetzt einfach wieder wie egal mir RT ist und der Mehrbedarf an Strom es einfach nicht wert ist mit RT zu spielen!
Warte aber noch ab und teste mehr Spiele. Bisher konnte mich aber Metro Exodus, Cyberpunk 2077 und Godfall nicht mit Raytracing überzeugen es unbedingt haben zu wollen 💩
Jetzt könnte man sagen " mensch du musst dich doch im Vorfeld informieren ob du das brauchst oder nicht bevor man sich so eine teure Grafikkarte kauft" nein eben absolut nicht weil man einfach keine Ahnung hat, ob es einem am Ende gefällt oder nicht, wenn man es nicht selbst ausgiebig genutzt hat! Außerdem macht man ja nichts falsch wenn man sich eine kauft, man kann sie auch sehr gut wieder verkaufen, es gibt genug Abnehmer.
Dennoch hoffe ich dass ich bei dieser Grafikkarte bleibe und den Wert dieser für mich tatsächlich noch erkenne! Ich bin auf jeden Fall hin und hergerissen.
Ganz zu schweigen mit dem neuen Stromanschluss und den damit eventuell verbundenen Problemen auf Dauer. Ich muss da auf jeden Fall auch ehrlich gestehen, dass mir ein herkömmlicher 3 x 8pin oder eben 4 x 8pin Anschluss VIEL besser gefallen hätte!
Klar kann man das . PL haben TUFs und Strix sogar beide bis 600 Watt und Volt lässt sich bei beide bis 1,1 V erhöhen.
Die Strix haben halt PCB Vollausbau mit 24+4 Phasen und die TUF 18+4 Phasen.
Also die hinterlegten Basisboosttakte der Biose der TUF und TUF OC sind auf jeden Fall nicht gleich. Die normale TUF hat als Default Boost ja 2520, die TUF OC 2565, egal ob im Quiet oder Performance Mode, hier gibt es also schon einen Unterschied bei den Versionen, ansonsten wäre das schlicht ****** von Asus. Das Bios einer TUF OC kann daher sehr wohl einen Einfluss auf den max. erreichbaren MHz Boost@Default haben, wenn die Güte des Chips es eben zulässt und das Plus umsetzen kann - dumm eben, weil keine besseren GPUs auf die OC verbaut werden, also nicht selektiert wird, das ist dann eben die eigentlich Verarsche von Asus, ganz abgesehen davon, dass die PCB Bestückung identisch ist. Bei anderen Herstellern unterscheiden die sich doch deutlich zwischen OC und non OC Versionen. Der Käufer der normalen TUF macht also klar den besseren Deal, ganz abgesehen davon, dass das Asus VRM mit das Beste ist aller Karten.
Ich mache mir die Tage mal den Spaß das Strix Bios zu flashen, meine macht 2715 mit dem TUF OC Bios, ca. zwei Schritte im Boost@Default müssten mit dem Strix Bios dann zusätzlich schon drin sein, das ja 2610 hinterlegt hat, also wenn meine GPU es im Table zulässt.
Der ***** hatte mit dem TUF OC Bios kein Mehrwert . Mit dem Strix Bios ging der Takt nach oben .
Macht schon Sinn, fühle es da ähnlich. Glaube bei RT macht es auch einfach nen großen Unterschied welchen Monitor man betreibt. Ein OLED oder ein high end HDR1000+ Display macht da glaub ich einfach das RT erst so richtig gut.
Ähnliche Themen
