[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Irgend jemand hier im Thread hat doch mal darauf hingewiesen, daß man seine Asus RTX 4090 bei Asus direkt registrieren kann, und man erhält dann ein weiteres Jahr Garantie? Ist das richtig?
weis gar nicht wie lange die normale ist.
die ti wurde im november 2021 gekauft. die non ti im oktober 20
Kleines Addendum, habe gerade Gears 5 mal angemacht und Benchmark laufen lassen.
Mein 900mv UV hatte im Schnitt 40-50W weniger als 70% PL bei selber Leistung.
Achja mein 5800X3D läuft nun auch schön...Stock mit 4,45Ghz auf allen Kernen, max Temp unter 80°C bei ca 100W.
Nein, die Person wusste nicht wie lange die Garantie bei Asus ist.
Windows meldet: Es ist bereits der beste Treiber installiert.
Hilft alles nicht.
Irgendwo im Internet stand (kann mich nicht mehr erinnern, ob in Deutsch oder Englisch), dass etwas an der Windows 11 Anzeige geändert wurde und es an Microsoft liegen würde.
Komisch, dass es mit dem 522.25 einwandfrei über Wochen lief.
Wenn der nächste Treiber es nicht fixt, dann hole ich mir ein HDMI 2.1 zu Display-Port Kabel. Alternative wäre ein LG42C2 :fresse2:
Ich nutze den LG C2 42" seit einiger Zeit, aber noch vor dem Exo-Panel Upgrade. Der Läuft mit dem neusten NV Treiber und meinem 27" 1080p 144hz Monitor.
Hilft alles nicht.
Ging nur darum das manche LG Monitore spezifische Treiber brauchen statt dem Generic Windows Treiber. Hier als Beispiel der Gn 850 B. Wiederum kann es buggen wenn Du bei einem Gsync hast und beim anderen nicht...
Kann euch aus Erfahrung sagen: Asus schickt euch in den ersten 2 Jahren bei GPUs innerhalb der Gewährleistung zum Händler. Erst danach kümmert sich Asus drum und da laufen die 5 Jahre über Seriennummer ab, Produktionsdatum.
3 Jahre
3+2 gibt´s bei Zotac
Eigentlich ging es nur darum das hier vor langer Zeit wer sagte man muss die Karte registrieren damit man mehr Garantie hat. Das war einfach nur eine Falschaussage weil die Person nicht wusste das es 3 Jahre sind, sondern dachte es sind 2 Jahre. Mehr steckt nicht dahinter.
Der nächste ist schon da.
Nvidia GeForce Game Ready 526.86 WHQL
Mir war so als würde es keine vernünftigen Lösungen für HDMI2.1 zu DP1.4 oder umgekehrt geben. Meistens verlierst Du VRR. Wird doch im LG-Fernseher-Thread immer groß erzählt.
Weil todgesagte ja länger leben :sneaky: und mich der Vergleich zu den Wassergekühlten FE's interessiert hat, habe ich mir meine FE unter LUFT nochmal vorgenommen.
OHNE Treiberoptimierungen ! Ohne offene Fenster! (Raum Temp 21,5°C) Auf dem offenem Testbench!
Lüfter 100% PL133% 1,1Volt
Ergebnis schwankt zwischen 11060~11100 für ne FE glaube ich nicht mal so schlecht.
Mehr Kühlleistung würde sicher helfen.
Also bei meiner ist bei VRAM +1800 unter Luft schluss
GPU +285 scheint das Limit zu sein, danach werden es aktuell nicht mehr Punkte auch wenn +300 noch durchläuft.
Gilt aber nur für Speed Way!
sagt mal, ist es normal, dass die Benchmarks, die man macht, immer ziemlich unterschiedlich sind?
Ich bekomme irgendwie nach jedem Benchmark ein schlechteres Ergebnis :unsure:
Ist das normal?
Plague of Requiem jetzt mal mit Framegeneration durchgezockt. Ich finds geil. Konstant fast durchgehend 120FPS in 4K nativ mit RT.
Übrigens ein richtiges Happy End das Spiel :-)
Ist das normal?
Vielleicht weil es immer wärmer wird.
Der hat den Bug immer noch...
Ich meine, dass das so bei Gigabyte war. Zumindest habe ich es blass in Erinnerung, dass ich für meine damalige Aorus 1080Ti für 3 Jahre, anstelle von 2, mich mit der S/N registrieren lassen musste.
Hier mal ein kleiner Schnappschuss vom Mitternachts UV der FE ;-)
Spulenfiepen hört man ein wenn man das Micro direkt an die Karte hält.
Im Video auch kurz zu hören wenn man genau hinhört.
In einem Gehäuse wirds vermutlich nicht nach außen dringen.
Aber immerhin kein "Rasseln" wie viele andere Karten.
Bin sehr ähnlich unterwegs. :d Eingestellt im AB 2760Mhz (+210Mhz) bei 0,95V + 498 Mem. Komme bei 2745 raus und Mem im Graphen auf exakt 11000. Ich mag volle Zahlen :fresse:
bei 0,95Volt habe ich etwa 6% mehr FPS Leistung aber fast 80Watt höheren verbrauch ... hab ihr mal nachgemessen wieviel mehr rauskommt?
dafuq
das war RES 8 maxed out mit RTX und 5120x1440p, 60-70fps
Ähnliche Themen
