[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Der Wert (GPU Core NVVDD) ist durchschnittlich aber auch niedriger als die GPU Power
Alleine diese Tatsache sollte Hinweis genug sein, dass da nicht dermaßen viel aus der Steckdose gezogen wird. Ziemlich merkwürdig, dass sich einige hier von Software Messdaten so verunsichern lassen.
  • Danke
Reaktionen: hwk
Asus Strix im Asus Shop ( Nicht lieferbar ) für 2.291 Euro : ( bisher der Tiefstpreis soweit ich das mitbekommen hab und somit fürs erste wieder die neue eigentliche UVP dieser Karte die vorher bei 2325 Euro lag und manche Scalper Shops für 2500 - 2600 Euro raushauen )
Habe eine Steckdose mit Strommessung direkt dran, was soll ich den am besten testen? Einfach auch mal Cyberpunk mit 4K Psycho + DLSS Qualität durchlaufen lassen und den Wert der Steckdose hier posten?
z.B. und ob dir irgendwas auffällt, also ob es da auch "spiked" oder so... aus dem Nichts kann die Karte das ja nicht ziehen, selbst wenn es Leistungsspitzen sind, eventuell sieht man die am Messgerät aber auch nicht.
Würde mir da jetzt auch keinen all zu großen Kopf drum machen um ehrlich zu sein :d
Hier auch mal den 5800X3D mit 3833 Mhz CL 16 Ram und etwas strafferen Subtimings. Aber wie zum teufel hast du 110 FPS gedrückt? :d meine TUF macht zwar MEM +1500 mit aber dafür ist bei ca 3000 Mhz auf Core schluss.
EDIT: Wenn ich alles im Hintergrund ausschalte komme ich auch auf 110 FPS, aber nur mit max OC. Bei dir scheint die Karte Stock zu laufen? Vielleicht sollte ich mein Windows mal neu aufsetzen oder auf Windows 11 gehen? Dafür läuft es bei mir ohne Ruckler :P
Ich hab keine besonderen "Tweaks".
4090 Gaming OC im Silent Modus, 2715@950mV als 24/7 Profil, RAM "nur" +1100
5800X3D PBO2 alle Kerne auf -29
RAM 3600 bissle schärfere Timings CL15 17-17-34-84 1T
Windows 10 total zugemüllt
Während dem RUN war Opera mit mehr als 50 Tabs offen.
Die Kombo 5800X3D und 4090 passt sehr gut. Vor allem Leistung-Effizienz-Temperatur.
Der Wert (GPU Core NVVDD) ist durchschnittlich aber auch niedriger als die GPU Power, eventuell sind das auch "nur" Spikes, hat ja wahrscheinlich keiner "live" beobachtet wie lang der Wert so hoch ist? :d
Im Overlay von AB war ich immer zwischen 400-420 Watt . GPU ganze Zeit voll ausgelastet .
So wie der Wert im GPU Rail Energie Verbauch .
Kein Game zieht bisher sonst so viel Leistung bei mir.
Vielleicht sind das auch Lastspitzen , aber wenn die ja unter 600 Watt sind ist doch eigentlich alles ok.
Igor hatte doch auch Lastspitzen gemessen und die gingen auch in diese Richtung ohne große Ausreißer.
Mir persönlich reicht Stock vollkommen aus . PL ist ja ausreichend dimensioniert nicht wie bei Ampere wo ich bei meiner Ref. Karte immer im PL war.
Muss jetzt nicht auf 1,1 V und 133% PL im alltag gehen ^^
Einzige was Igor noch erwähnt hat ist bei den ATX 2.xx Nt´s , dass die übervolten bei den 4090er , aber alle halt .
Die Frage wie sich das bei ATX 3.0 verhält.
Ne bei mir gibt´s keinen Peak:
Bild von der Steckdose habe ich dann gemacht, als sie am meisten zog (Messung ist in Echtzeit), dass war kurz vor dem Ende des Benchmarks.
Da ist die FE, dieses mal war ich unendlich langsam xD
Gerade eine FE bestellen können. Mal sehen, ob es klappt.
Edit: Zahlungsmittel war PayPal. War nicht bei NBB eingeloggt.
Bitte bitte beliefert mich diesmal
Eingeloggt mit einem alten Account der schon Bestellungen hatte. PayPal. Schnell war ich nicht.
"Note, that the core power might sometimes seem higher, due to instantaneous peaks"
Die Werte stimmen also, sind nur peaks die auftreten können. Gut, dass keiner meine Wette angenommen hat :ROFLMAO:
Habe mega Glück gehabt, war gerade bei NBB angemeldet und dann ist die Push Mitteilung gekommen
is ja furchtbar wie schnell die weg sind.
Konnte zwar in Warenkorb legen dann ging am Handy aber nix mehr
Dito, Papypal wollte Identifizierung per SMS :wall:
Meine Bestellung ist aber durch... wird aber bestimmt wieder storniert, war nicht angemeldet, die Anmeldung ging aber nicht weiter, dann direkt zu Paypal Checkout dann gings durch und sie steht auch im Account kein Plan.
Holy shit! hoffentlich geht das dieses mal durch ... meine letzte wurde von Amazonpay gecancelled hab jetzt mit Paypal bezahlt
Ähnliche Themen
