[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Das Kabel Thema ist echt dermaßen...wie kann man nur so eine Panik schieben? Ist hier der Anonyme Club an Hypochonder?
Zudem: Wen interessiert was nVidia sagt was man für Kabel nutzen darf? Was ich nicht weiß, macht mich nicht heiß. Wie sollen die das jemals nachprüfen.
Einfach bisschen den eigenen Verstand benutzen.
Naja du musst bedenken es geht hier um eine Karte mit dem Anschaffungspreis von meist ~50-100% des monatlichen Nettoeinkommens vieler. Da ist die Frage "Was passiert im Falles eines Defektes?" schon angemessen und hat auch nichts mit Hypochonder zu tun.
Auch du solltest deinem Rat folgen und deinen Verstand benutzen. Die meisten Boardpartner schreiben in den Garantiebestimmungen, dass die Karte mit dem Orginalzubehör einzusenden ist. Garantie ist eine freiwillige
Leistung des Herstellers, die Bedingungen darf er völlig frei formulieren (nicht mit Gewährleistung verwechseln).
Wenn ich nun meine verbrannte Karte einschicke und einen unbeschädigten Adapter beilege wird es schon schwierig mit der Garantie (Kulanz mal ignoriert), auch den Adapter mit z.B. einem Heißluftföhn einschmelzen würde nichts bringen. Das blöde bei geschmolzenen Plastik: Man kann sehr eindeutig zuordnen, ob die beiden Teile zum Zeitpunkt des Ereignisses verbunden war. Kurz: Der Hersteller weiß ziemlich genau was im Falle eines geschmolzenen Anschlusses passiert ist.
Andere Frage in eigenem Interesse: Hat hier jemand Erfahrungen mit der PNY XLR8? Ich hatte die mal "günstig" bei Amazon für 2130€ geschossen, VRM ist aber ziemlicher Müll wie ich nachträglich herausgefunden habe (14x50A auf Vcore)... ist der Kühler der Karte gut, man liest unterschiedliche Infos? Oder trash und direkt zu Jeff zurück?
Vorteil bei Jeff: Wenn wirklich mal was mit dem Ding ist, dann gibt es eben bei Amazon die ersten 24 Monate das Geld binnen 48h zurück, no questions asked...
Zielsetzung war eigentlich ja eine 4090 TUF für 1949€, aber das ist wohl aktuell realistisch betrachtet eine Träumerei...
Mal ganz abgesehen davon, dass die Schäden (jedenfalls bisher) immer "von-innen-nach-außen" an den Pins entstanden sind. Einen solchen Schaden zu simulieren (wenn man genug kriminelle Energie hat) wäre selbst bei geeignetem Equipment eher schwierig, ein Heißluftföhn von außen wird keinen Gewährleister (Mitarbeiter, die die Fälle checken) täuschen (anhand der Verfärbung/Schattierung des Hitzeschadens am geschmolzenen Plastik kann man den "Gang" des Schadens nachvollziehen). Hier müsste man im Gehäuse von innen punktartig große Hitze erzeugen, die sich schlagartig ausbreitet. Nicht so einfach machbar.
Da NVIDIA aktuell bei jedem Fall unbedingt die Adapter will, hat man hier keine große Chance, wenn man Drittprodukte nutzt.
Mal ganz abgesehen davon, dass der FE Kühler von den Ausmaßen viel kleiner ist als riesige Brocken wie die Strix, ähnliche aber leicht schwächere Leistung zu erzielen ist hier also positiv und nicht negativ^^
Hässlicher ist aber immer noch die Palit mit diesem Möchtegern Kristalldesign :kotz:
Mal ganz abgesehen davon, dass die Schäden (jedenfalls bisher) immer "von-innen-nach-außen" an den Pins entstanden sind. Einen solchen Schaden zu simulieren (wenn man genug kriminelle Energie hat) wäre selbst bei geeignetem Equipment eher schwierig, ein Heißluftföhn von außen wird keinen Gewährleister (Mitarbeiter, die die Fälle checken) täuschen. Hier müsste man im Gehäuse von innen punktartig große Hitze erzeugen, die sich schlagartig ausbreitet. Nicht so einfach machbar.
In dem Moment kommt es eben auch wirklich auf den Hersteller an. Was Nvidia will interessiert ja erstmal nur bei der FE. Nvidia ist btw auch der einzige Hersteller, welcher explizit die Nutzung des Adapters vorschreibt, bei meiner PNY ist zB nur eine Skizze dabei, wo sogar noch normale 8-Pin-PCIe Kabel an die Karte sollen ^^
Im Zweifel hat man aber trotzdem schlechte Karten, ist und bleibt eben ein Betrieb ausserhalb der Spec, wenn kein ATX 3.0 PSU verwendet wird... und selbst da its bei Kabel/Anschluss eigentlich der PSU-Hersteller der erste Ansprechpartner. GPU Hersteller wird eigentlich erst relevant bei allem was hinter dem Stromanschluss passiert, bzw. hinter dem ersten Kettenglied was eben vom Hersteller kommt (da zählt dann eben auch zu wenn der Adapter raucht)
Durch ist man, wie wir letzte Woche gelernt haben, erst mit der Versandbestätigung :d (rechtlich eigentlich mit der Auftragsbestätigung) meine Zahlung steht noch auf "Autorisierung"
Dito, und ich hab ewig mit dem PayPal-Login rumgemacht und beim Absetzen der Bestellung eine halbe Minute gebraucht zu verstehen, dass ich die Versandart noch anklicken muss um die Bestellung abschließen zu können. Hoffe dass die AB die nun da ist das fix macht und nicht doch noch ein Storno kommt. Und das es kein Rückläufer ist...
Dann geh ich mal wie erwartet von einer Stornierung aus bei mir :d
Hmm Paypal ist jetzt auf "Zahlung" gesprungen xD
Meine kam auch gerade! :banana:
Meine ist auch durch, habe die Auftragsbestätigung gerade erhalten
Ist die durch? :-)
Edit: Sie ist durch! :-) Nach nur 4 Wochen harter Arbeit :-)
Bei mir hat es leider nicht geklappt mit der FE. In PayPal ist nichts ersichtlich. Aber alles kein Beinbruch. Das Leben geht weiter. Hätte die FE allerdings schon gerne mal getestet...
Herzlichen Glückwunsch an alle, die es geschafft haben :)
Da ist ja jetzt doch ne AB gekommen, verrückt und ich hatte ne hohe Bestellnummer, war echt langsam... 5xx sieht man mal, dass es definitiv nicht "nach der Reihe" gemacht wird, scheiß System.
Sorry aber so ein Käse hab ich ja lange nicht mehr gehört.
Was interessieren mich irgendwelche dubiosen Garantiebestimmungen, die nachdem die zwei Jahre Gewährleistung vorbei sind sowieso nichts weiter sind als reine Willkür und Kulanz des Herstellers? Garnix!
Solange ich mich in der Gewährleistung befinde, besonders innerhalb der ersten 12 Monate wo die Beweislastumkehr klar geregelt ist zum Schutze des Käufers, kann mir das alles herzlich egal sein. Da kann sich nVidia noch soviel Bullshit und AGBs/Gerantiebestimmungen whatever einfallen lassen.
Das Vorschreiben eines Adapters bei einem Stecker der von der PCI-SIG genormt ist, lässt natürlich alle sonstigen Stecker/Kabel die dieser Norm entsprechen ebenfalls zu. Da hat nVidia aber schlechte Karten wenn es zu einem Prozess käme das zu rechtfertigen, warum ihr (minderwertige) Adapter ausnahmslos der einzig Wahre ist. In AGBs etc. kann vieles stehen ob das aber Bestand hat ist was völlig anderes.
Glückwunsch an alle. Bei mir kam noch nix. Ist auch nicht schlimm 😃 wahrscheinlich wegen Amazon Pay und Gastbestellung, weil ich dachte, dass das schneller geht.
Und mal davon abgesehen, dass das Teil ausschaut wie ein Designerprodukt, und nicht wie ein Kindergartenprojekt mit Wassermalfarben.
Die 3090 Strix sah besser aus als das 4090 Pendant. Warum die das Produkt für die 4090 kaputt-designed haben, verstehe ich nicht.
Ich habe ja auch nicht gesagt das die FE die beste Kühlung hat ich habe nur darauf hingewiesen das dieses Diagramm darüber keine Aussage gibt da das Diagramm eben über die Lautstärke gemacht wurde nicht über die Kühlleistung. Da muß man andere Diagramme über die Kühlleistung der Karten herran nehmen, gibts ja auch, um darüber eine Aussage zu treffen. Übertrieben dagestellt ich will wissen wie schnell eine Grafikkarte ist und nehme dafür ein Diagramm vom CPUZ Bench wo dann der Rechner mit der 4090 der langsamste ist weil ne 4790k drin ist und der Rechnre mit der 980 ist der schnellste mit 13900k.
Um ehrlich zu sein, verstehe ich nicht, warum ASUS die Preise um knapp 70-80 Euro gesenkt hat. Aber natürlich nett von ASUS :)
Bin gerade so richtig abgenervt von dieser Schnitzel Jagd !
Wenn du das so gemeint hast, dann genau 15cm. ;)
PS: Kein Kommentar zum super Lineal. :fresse:
Uh nice... würde sogar passen..
PS: AB für FE gekommen :LOL:
Mit extra Vorfreude, da sie an meinen Zweitwohnsitz geliefert wird... 8-)
So hab ich es auch gemacht, hatte aber ne rel. niedrige Bestellnummer.
Ja, genau so sehe ich das auch. Ich nutze das von Corsair angebotene Kabel für den Anschluss der 4090. Hier wäre für mich dann Corsair der Ansprechpartner, denn sie haben das Produkt verkauft mit der Beschreibung das es für die 4090 nutzbar ist. Solange nVidia kein Serienproblem anerkennt müsste das dann aus meiner Sicht Corsair regeln, weil ihr Kabel nicht die versprochene Leistung verkraftet hat und im Sinne der Produkthaftung auch die Grafikkarte ersetzen. Und dann notfalls mit nVidia rum streiten. Aber soweit nur die Theorie und wie ich persönlich das sehe. In der Praxis kann das alle möglichen Formen von Komplikationen annehmen, wenn sich Corsair querstellen würde und behaupten die Karte hätte eine unzulässige Leistung angefordert usw. Das kann dann in einem Ping-Pong Spiel enden bei dem man als Kunde der Dumme ist. Ich hoffe daher, daß ich es nie rausfinden muss und wenn doch, daß man es dann unbürokratisch regelt. Ein weiterer Grund, warum ich nicht auf ein echtes Drittanbieterkabel setzen würde, es verkompliziert die Dinge im Zweifelsfall eher wenn doch was schief geht.
Aktuell sieht bei mir aber alles noch sehr gut aus, das Corsair-Kabel macht einen sehr hochwertigen Eindruck, es steckt vollständig in der Buchse meiner Suprim, es ist nicht in Steckernähe gebogen, hat keine mechanische Spannung oder Druck, am Netzteil (AX1600i) habe ich jeweils einen Port Abstand zwischen den Kabeln gelassen und sowohl Netztzeilanschlussseite als auch Buchse an der Karte haben Luftstrom. Und ein 600W BIOS kommt mir auch nicht drauf. Ich habe alles getan was ich konnte und mit dem Restrisiko kann ich leben, ich habe meinen Kauf keine Sekunde bereut bisher.
Unglaublich...
Ersten Strix-Drop verpasst, weil ich kurz aufs Klo bin.
Zweiten Drop verpasst, weil ich kurz duschen war.
Beim dritten Drop war ich 5 Minuten unterwegs, hab dabei immer wieder den Shop aufm Smartphone aktualisiert und tatsächlich eine bekommen.
edit: gemeint sind natürlich die Drops vom Asus Shop heute.
Also ich bin irgendwie verunsichert:
bin eigentlich zufrieden mit meiner TUF, die hat auch im direkten Vergleich durchweg bessere Werte gehabt, als die TUF OC, die ich hier hatte.
Wenn ich jetzt aber am nächsten Tag die genau gleichen Tests durchlaufen lasse, wird das Ergebnis bei jeder Wiederholung schlechter - auch, wenn ich Zeit dazwischen lasse, zum "abkühlen" aller Komponenten.
Der Unterschied zum ersten und besten Benchmark beträgt über 7% - ohne, dass irgendetwas verändert wurde.
Und an der Temperatur der Karte kann es eigentlich auch nicht liegen - die ist bei jedem Test nicht annähernd an der 60 Grad Marke.
Habt ihr eine Idee, was da los sein kann?
Die Tests sollten sich doch eigentlich halbwegs im gleichen Rahmen befinden - vielleicht mal 1Prozent Varianz, - aber ÜBER 7 Prozent Verschlechterung, ohne Grund!? :unsure:
wobei meine Strix nonOc (diesen Dienstag im Asus Shop bestellt) zwar an der OVP und an der Anstistatik-Tüte zugeklebt gewesen ist, die Schutzfolie auf der Backplate aber sehr gebraucht ausgesehen hat:
Die Antistatiktüte wirkt auch einen kleinen Ticken wie schon mal ausgepackt und wieder eingepackt.
Zubehör war komplett und verpackt.
Beim Auspacken aus der Antistatiktüte ist mir auch noch ein unüblicher Geruch aufgefallen. Den hat man dann so im Zimmer nicht gerochen. Nur wenn man direkt mit der Nase an der Karte riecht,
hat man es dann auch weiterhin gerochen. Keine Ahnung, obs kalter Rauch ist. Wenn, dann vielleicht Wasserpfeife oder sowas. Ich kenne mich da nicht aus.
Nicht das hier noch einige paar mehr Rückläufer gerade verkauft werden sollen. Wenn der Preis gut ist, schaut der ein oder andere vielleicht darüber hinweg.
So könnte ich mir jedenfalls vorstellen, das es der Shop so sieht.
Karte geht jedenfalls zurück.
Zurückschicken ist ja das eine. Aber dann was zurückschicken, obwohl man raucht oder ähnliches macht?
Moin, ich würde gerne mal eure Meinung hören zum Thema FE vs. Partner:
Ich habe aktuell eine Gainward non GS verbaut, und muss sagen dass ich super zufrieden bin. Die Temps sind top und die Lautstärke ebenfalls. Somit würde ich eigentlich sagen, never change a running system :)
Da aber ja dieses Video von Buildzoid herumgeistert, in dem er die PCB Designs/Komponenten der Palit (aka Gainward?!) stark kritisiert und ihnen im Grunde nur den Garantiezeitraum als Lebensdauer bescheinigt, frage ich mich ob ich nicht lieber auf eine FE umsteigen sollte?
Angenommen ich komme beim Tausch auf +-0, das Aussehen der FE ist meiner Meinung nach Hammer, aber soll nicht der ausschlaggebende Grund sein. Was meint ihr, was würdet ihr machen?
Dazu muss ich noch sagen, dass ich eigentlich absolut keine Overclocking-Ambitionen mitbringe, die Karte soll einfach laufen.
Viele Grüße
Push... :d
Ähnliche Themen
