[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wegen der icill kommt es bei mir auf das PT an, wenn die auch 600 Watt hat ist Sie auf jeden Fall in der engeren Auswahl,
Ja das ist noch ein Punkt, hoffe das wir das noch vor Mittwoch noch raus finden können....
Wegen der icill kommt es bei mir auf das PT an, wenn die auch 600 Watt hat ist Sie auf jeden Fall in der engeren Auswahl, sonst die Suprim oder Strix Und später Wasserkühler.
Hat denn die Suprim X 600Watt PL?
Ich glaube eher nicht - da Netzteilanforderung 850W und keine 1000 Watt wie bei den anderen.
Vielleicht hat die Karte 2 BIOS Möglichkeit und eines ist mit 450W und das andere 600W. Ich glaube aber eher nicht.
Nicht bestätigt. Igor hatte ein Bild wo das Quiet bios laufen hatte gepostet mit 450watt.
ABER da die Supreme das high end Modell ist geh ich zu 99.9% davon aus das es ein 600w bios hat
Kühler-Oberfläche/pi*daumen=PL o_O
:oops:
Nicht bestätigt. Igor hatte ein Bild wo der Quiet bios laufen hatte gepostet mit 450watt.
Na ja was das PL angeht hat MSI bislang nicht wirklich viel riskiert 3090 und 3090ti sind ja eher verhalten. Abgesehen von der schrecklichen Software fürs RGB oder BIOS updates.
Oh oki... Hatte mal eine MSI 970er danach nie wieder ne MSI
Warum?
Am besten warten wir alle auf eine Galax HOF ;)
Ich bin mir sicher das MSI sicher wieder eine der leisesten Karten baut.
Für Asus wird’s sicher wieder ein XOC BIOS geben. Vermutlich inkl. Spulenfiepen ;-)
Die inno3d wird zum Launch mit WaKü vermutlich garnicht verfügbar sein oder sehr wenig.
Werde vermutlich bei der FE und bei der Strix zuschlagen vielleicht auch noch bei der MSI und dann halt mal wieder selbst testen.
Ich glaube (anders als andere hier) noch nicht dran, das die 4090 gut verfügbar sein wird.
Aber das ist ja Bald so weit ;-)
Warum?
Falsch rüber gekommen.
Danach nie wieder eine MSI gekauft. Sollte nicht so rüber kommen weil die scheiße war, sondern einfach weil keine mehr gekauft :)
Auf der Website wird nix von Dualbios erwähnt!
lol wenn die Suprim keine 600W hat 🙈🙈
Immerhin ist die Karte bei mehreren Reviewern eingetroffen, wir wissen es also am Dienstag.
Kann ja nicht so schwer zu produzieren sein oder?
Wenn sie einfach einen abgewinkelten 16 Pin Stecker machen würden gäbe es keine Probleme mit Biegeradien... manche Probleme sind echt unnötig
Vielleicht ist es aber bei dem Kabeltyp und der Leistung einfach nicht zulässig. Es gibt so viele Regeln und Normen im elektrischen Bereich welche die wenigstens von uns kennen alle, könnte daher auch sein, daß es deswegen keine gibt. Ist aber nur Spekulation.
Wohl nicht sehr häufig. Wenn es dann aber doch mal soweit kommt, ist das Geschrei groß.
Ja, weil die Leute meist keine Reserven einplanen und von potentiellen Konsequenzen ihrer Entscheidungen auch nix wissen wollen. Wenn ich meine Hardware modifiziere, dann erst wenn ich genug Geld im Budget habe um ggf. einen kompletten Ersatz kaufen zu können, ansonsten bleibe ich innerhalb der Garantiebestimmungen.
Und wenn ich mich über Garantiebestimmungen hinwegsetze, dann trage ich auch das volle Risiko, dann heule ich nicht rum wenn was schief geht und ich keinen Ersatz kostenlos erstattet bekomme. Es gibt nun mal kein Grundrecht auf Wasserkühlung, es ist daher völlig legitim wenn ein Hersteller sagt "Umbau auf eigenes Risiko".
Mach es doch wie ich. Ich nehm nen halben Tag frei.🤗
hehe ich arbeite immer noch im Homeoffice, ich habe mir daher einfach eine Pause als Termin in meinem Kalender geblockt für den Zeitraum des Releases, damit mir da keiner mit Arbeit dazwischen kommt :d Kann ich alles später einfach nacharbeiten wenn ich alles erledigt habe was ich ggf. erledigen will.
Kennt jemand den Unterschied der MSI RTX4090 Gaming und Gaming X?
Nur bissl mehr Takt out of the box, wie die „OC“ Versionen bei Asus.
Gaming kommt mit 3x8 Pin und 450 Watt, X Trio kommt mit 4x8 Pin und sicher einem Bios mit mehr als 450 Watt, du kannst aber mittels bios flash aus einer gaming eine gaming x machen
Äh, momentan wissen wir außer bei der FE bei keiner Karte „sicher“, dass diese 450W hat.
:oops:
Fake? Falls das echt ist dann ist ne 4090 nur 40-50% schneller als ne 3090Ti in all diesen Titeln mit nem 5950X
Die meisten Kommentare sind außerdem schon vom 06.10, gabs da schon Treiber für die Reviewer?
Das wäre dann doch ein gutes Stück unter den bisher genannten 60-70% gegenüber der 3090Ti.
3240mhz :)
3,3ghz mit 600W und Wakü 😍
3,5GHz mit DICE und/oder LN2? 😍
Naja, im Kern ist das ja ein Problem der Kausalität, Beweisbarkeit und auch des Misstrauens zwischen Händler und Kunden (vermutlich auch berechtigt, weil sicher in Vergangenheit auch viele Kunden nach eigenen Fehlern unehrlich waren und die Karte ersetzt haben wollten, statt es als Lehrgeld abzuschreiben).
Eigentlich ist damit aber ja auch gemeint dass man nicht für Schäden, die beim Umbau passieren, haften möchte (verständlich). So verstehe ich das zumindest. Wenn der Umbau aber zu 100% mit Gewissenhaftigkeit und ohne Beschädigung durchgeführt wurde und die Karte, unabhängig vom Umbau auch so kaputt gegangen wäre, gibt es eigentlich auch keinen logischen Grund weshalb die Garantie (oder Gewährleistung) erlöschen sollte.
Das Problem ist aber wie gesagt die Kausalität/Beweisführung, denn im Endeffekt wissen weder Händler noch der Kunde selbst ob der Umbau ursächlich für den (ggf. auch erst später auftretenden) Defekt war oder nicht. Da gibt es ja viele Variablen und mögliche Ursachen. Daher wird, vermutlich aber auch durch viele negativen Erfahrungen aus der Vergangenheit, bei Anzeichen eines Umbaus mittlerweile oft sehr penibel reagiert.
Folgende probleme gab es schon.
Von Haus aus Pads vergesssen oder zu dünn.
Demontieren und wechseln nicht erlaubt.
Risse im Plexi . Kunde selber schuld.
Wird eine Karte eingeschickt erhält der Händler Credits um eine neue Karte sich auszusuchen .
Der Kunde bekommt dann meist nur einen Wertanteil und nicht den vollen Kaufpreis oder bekommt auch keine Austauschkarte.
Hier kommt auch bisschen der Händler mit ins Spiel , aber gute Händler gibt es ja kaum.
Also muss man Stress machen , sonst wird man verarscht .
Daher schon schwierig mit Inno3d.
Bei Asus zb. schicken die eine Austauschkarte oder erstatten den Händler den vollen Kaufpreis zurück und diese leietet
den an den Kunden weiter. So zumindest auch eigene Erfahrung mit Asus und Monitor.
Ok, das klingt nicht so toll :-[
"Wer billig kauft - kauft zwei mal" :rolleyes2:
Naja viel billiger ist die inno3d jetzt auch nicht
Ähnliche Themen
Antworten
6K
Aufrufe
381K
