[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Naja, im Kern ist das ja ein Problem der Kausalität, Beweisbarkeit und auch des Misstrauens zwischen Händler und Kunden (vermutlich auch berechtigt, weil sicher in Vergangenheit auch viele Kunden nach eigenen Fehlern unehrlich waren und die Karte ersetzt haben wollten, statt es als Lehrgeld abzuschreiben).
Eigentlich ist damit aber ja auch gemeint dass man nicht für Schäden, die beim Umbau passieren, haften möchte (verständlich). So verstehe ich das zumindest. Wenn der Umbau aber zu 100% mit Gewissenhaftigkeit und ohne Beschädigung durchgeführt wurde und die Karte, unabhängig vom Umbau auch so kaputt gegangen wäre, gibt es eigentlich auch keinen logischen Grund weshalb die Garantie (oder Gewährleistung) erlöschen sollte.
Das Problem ist aber wie gesagt die Kausalität/Beweisführung, denn im Endeffekt wissen weder Händler noch der Kunde selbst ob der Umbau ursächlich für den (ggf. auch erst später auftretenden) Defekt war oder nicht. Da gibt es ja viele Variablen und mögliche Ursachen. Daher wird, vermutlich aber auch durch viele negativen Erfahrungen aus der Vergangenheit, bei Anzeichen eines Umbaus mittlerweile oft sehr penibel reagiert.
Wie sieht es bei Karten mit vorinstalliertem Block aus?
Ein WLPasten-Pump-Out macht auch vor solchen Karten keinen Halt. Wechselt der Hersteller dann regelmäßig die Paste oder das ich das tun? :d
Äh, momentan wissen wir außer bei der FE bei keiner Karte „sicher“, dass diese 450W hat.
Ich denke mich zu erinnern das IGOR die 4090FE mit 600W ausgelesen hat.
Nur weil Sie kein DualBios hat muss das Powerlimit doch nicht bei 450W sein.
OK du muss dann halt mit dem Afterburner mit +33% beim Powerlimit die 600W frei schalten.
Und die Frostbyte an ein Referenz Layout, so wie die meisten anderen Karten.
Demnach müssten ja die wenigsten Karten mit 600W fahren können.
Wir werden dann ja sehen.
3,5GHz mit DICE und/oder LN2? 😍
Laut kopite nicht :(
Hier von IgorsLab, bevor er es gelöscht hatte. FE mit 600W Peak und 133% Afterburneroption
Wenn man sich das hier so durchliest würde ich fast wetten abschließen das innerhalb 15 Minuten alle ausverkauft sind.
Und die Nächsten sicherlich 1-4 Wochen warten müssen.
Inno3d werden nicht wissen wo ihnen der Kopf steht und MSI bekommt das was Sie an der 3090ti verloren haben wieder zurück.
FE wird wie gewohnt gut verkauft. Asus Strix schreckt der Preis ab und viele greifen zur TUF.
Ich werde jetzt Wahrsager
Ich hoffe auf ordentliche Tests auch beim Rendern. Das ist aktuell für mich der limitierende Faktor und ist dann der ausschlaggebende Punkt ob beim Release eine 4090 kommt. Aktuell werkelt eine 3090ti im Produktivsystem. Entweder kommt eine 2te dazu oder ne 4090 rein.
Beste Grüße
Auf drei Monitoren werden je ein Shop geöffnet sein und dann wird auf allen dreien so schnell es geht eine 4090 bestellt. Eine davon muss einfach durchgehen. Denke noch drüber nach, meine Frau auf eine weitere Seite anzusetzen, mal schauen.
Bist Du sicher, daß dies wirklich ein echtes Problem ist über das man sich kümmern müsste? Ich habe noch nie bei irgendwas die WLP zwischendrin erneuert und auch nie eine verschlechterung der Performance festgestellt. Der Hersteller würde das nur machen wenn ein Ausfallrisiko besteht und nicht lediogtlich weil man irgednwo ein paar Prozent Leistung verliert. Der Hersteller hätte zu definieren was gewartet werden muss und nicht der Kunde.
Da steht nichts weiter dabei...
(welche Kühlung, Hard-Mod etc)
Warten wir mal ab... ;)
Quake RTX in 4K wird sicher nicht mit 3GHZ laufen, da reichen 600Watt
und normale Kühlung auch nicht mehr aus dem Heimgebrauch sicher nicht mehr.
Bin mal gespannt wo der Sweetspot sein wird.
max. 2800Mhz bei so 480W @0,9V
min. 2500Mhz bei so 380W @0,85V
wär doch schon ein Träumchen für 24/7
Wenn du rechtlich auf der sicheren Seite sein willst, dann solltest du das wirklich den Hersteller machen lassen (falls das mal ein wirkliches Problem werden sollte).
Von einem echten Problem hab ich nichts geschrieben. Man darf sich aber nicht wundern, wenn nach einer gewissen Anzahl von Zyklen, die Kühlleistung nachlässt.
Ich hätte schon gerne die Möglichkeit WLP zu erneuern oder sie mir erneuern zu lassen. Daher tut es schon "weh", dass EVGA weggefallen ist... :cry:
Als ich meinen Kumpels den Link vom Proshop gesandt habe, wären die natürlich total begeistert. Die haben ihrerseits den Link geteilt. Das mit den 15 Karten auf Lager wird echt knapp.
Da steht 15+, was so viel heißt wie es sind mehr als 15. Ob das nun 20, 500 oder 10.000 sind weiß niemand.
Frag mal bei Mindfactory nach. Die geben das immer pauschal sogar nur mit "Lagernd: >5 Stück" an. ;)
Hab grad das ATX 3.0 Netzteil installiert (Thermaltake Toughpower GF3). Hat Spulenfiepen, kann wieder alles auseinanderbauen und zurückschicken :/
Warum kaufst du so etwas warte doch bis etwas brauchbares auf dem Markt ist.
Ist bei den meisten Shops ja absichtlich hardcapped und soweit auch nachvollziehbar. Für die Kunden ist ja vor allem interessant zu wissen wie viele Karten noch da sind wenn die Menge knapp wird (da es dann relevant ist).
Wenn die Mengen größer sind ist es ja relativ egal (da genug da ist) und es sind Einblicke (wie groß die Menge genau ist), die die Shops oft nicht gewähren wollen (vllt. auch wegen dem Preiskampf mit der Konkurrenz etc.). Wurde ja bei MMS z.B. auch aus den API Daten entfernt.
Ähnliche Themen
Antworten
6K
Aufrufe
381K
