[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Darf er doch solange die Leistung etc. nicht offen gelegt wird. Aber witzig dass er überhaupt eine bekommt...
Mich hat es nur gewundert, weil ein anderer Reviewer in die Cam sagte, dass er die Karte nicht reinsteckt (nur ins Case hält)
K.A. ob es zwischen den Herstellern, verschiedene Bedingungen gibt!?
Linus testet schon entsprechende Gehäusefans für 600W. :d
Hab ich auch gerade gesehen :d
Ist der Vorläufer für diese "Bad Boys" hier :fresse:
3240mhz :)
3,3ghz mit 600W und Wakü 😍
Wird ein golden sample sein. Für den Durchschnitt werden es wohl eher um die 3GHz drin sein. Also Erwartungen sind realistisch zu halten.
Ich glaube dass das Reinstecken in diesem Fall, im Gegensatz zu anderen Lebenslagen, keine teuren Folgen haben sollte :ROFLMAO:
Bevor das Video gelöscht wird. Noch Screenshots gemacht 👍
K.a. ob es Fake ist.
Cyberpunk in 4k mit über 100 fps average - oh baby 😍 hätte gern den Wert mit RTX on gesehen.
Das ist einer von diesen yt-Fakekanälen, die vor dem Launch neuer Hardware immer solche angeblichen Vergleiche veröffentlichen.
Eine 3090Ti schafft in UHD allein in Cyberpunk keine >70fps ohne RT, nicht einmal im Ansatz. Laut PCGH und TPU ~50fps. Rest braucht man dann gar nicht mehr gucken.
In wie weit es ein Fake ist oder nicht, kann ich nicht sagen.bin halt nur vorhin drüber gestolpert
Der YT Account sieht jedenfalls besser aus als der vom letzten Video, das doch relativ offensichtlich ein Fake war.
Ist einfach als Fake zu enttarnen: Keine Worte über sein Setup, keine Erklärungen (woher Treiber?...), keine Rechtfertigungen. -> Automatische Tatsachenfeststellung, dass es ein Fake ist, bis das Gegenteil plausibel, sachlich, fundiert und nachvollziehbar von ihm bewiesen wurde. (y)
Könnte bei dem Takt am Ende auch passen das Video sieht schon authentisch aus von den Werten ist ja keine 3090!
RTX 4090 24GB vs RTX 3090 Ti 24GB | PC Gameplay Tested in 7 Games in 4K/2160p Ultra Settings System Specs : Operating System : Windows 10 Pro 64 Bit CPU : AMD Ryzen 9 7950X (Asus ROG Crosshair X670E HERO) GPU 1 : Asus ROG Strix RTX 4090 24GB GPU 2 : MSI Suprim X RTX 3090 Ti 24GB CPU Cooler : MSI MAG Coreliquid C360 AIO Liquid Cooler PSU : Cooler Master V1000 SMPS RAM : 4*16GB DDR5 5200MHz
3.2ghz unter wasser? Ich würds ja zu gern glauben, bin aber sketpisch ob das PT überhaupt reicht.
Die Videos sind immer Fake.
Ja ist bei jedem launch inzwischen so und ja ganz simpel zu machen.
Dass so jemand wie holzmann das nicht erkennt ok, aber bei manch anderen wundere ich mich schon. Hm.
Sieht man schon alleine daran dass der Takt immer der gleiche ist und nie schwankt dass es Fake ist
:ROFLMAO:
Das Video ist ein Fake. Bitte so Videos nicht hier posten, solange nicht eine Stimme, Gesicht und Karte im Video zu sehen ist. Allein die FE hält schon locker den Takt von +2700 MHz.
Aber ansonsten natürlich danke für die Mühe mit den Screenshots.
Die 4090 FE scheint ja kein Bios Switch zu haben, trotzdem gibt es wohl unterschiedliche Powerlimits 450/600. Ob man dies wohl mit den Sense Pins des neuen Steckers regelt?
Also nutzt man einen 4-in-1 Adapter oder passendes Kabel wie von Corsair wo Sense0 und Sense1 geerdet lädt man ein 600 Watt Bios. Ansonsten je nach Belegung der Sense Pins des Kabel ein anderes.
Quelle: https://www.cybenetics.com/attachs/52.pdf
Ich halte es für Ausgeschlossen das eine Karte die mit 450w adapter verkauft wird nur durch den Austausch des Adapters auf 600w plötzlich ein 600w Powerlimit bekommt. Da wird man BIOS flashen müssen.
:fresse: war abzusehen, aber trotzdem :lol:
Bin gespannt wie lange es dauert bis die Gehäusebauer mit "alle 4090 passen" werben bei Gehäusen in denen dieser Klopper platz hat und/oder ihre Gehäuse umbauen und z.B. ein "O-11 4090" bringen
Das BIOS muss natürlich immer den Rahmen festlegen und die 600W erlauben. Innerhalb des Rahmens konfigurieren die Sense Pins wie viel die Karte ziehen darf.
Soweit ich weiß können bei den ATX 2.4 dann zwischen 450 und 600 geschaltet werden .( verfügbarer Strom )
Ob das via BIOS Switch oder automatisch via anheben des PL passiert müssen die Tests klären .
Heute soll mein Corsair Kabel kommen laut UPS . Wäre dann der erste Schritt ☺️
@Don
Es wäre nett, wenn ihr beim Test erwähnt, dass ihr ein normales (nicht neues ATX 3.0) Netzteil benutzt habt für den Test, wenn das zutreffen sollte.
Ich denke, dass das Thema immer noch einige verwirrt. :)
Bisher ist ja noch nicht so viel geleakt, aber z.B. von Igor das FE Bios mit dem 600er Limit.
So wie angeblich ein Silent Bios einer MSI Suprim
Klärt sich hoffentlich morgen Alles oder zum größten Teil. Gut das ich das Corsair Kabel zusätzlich bestellt habe (was heute ankommt). Das von modDIY ist noch aufem Frachter.
Jep, meine 2 Corsair Kabel sollen auch heute kommen. Rechtzeitig zum Release :)
@Don
Na ja, es spielt doch keinen Rolle ob ATX3.0 oder Adapter mit älteren Netzteil … warum sollte er es dann erwähnen?
Ich muss noch ein komplettes Netzteil bestellen. :fresse: Werde es aber erst tun wenn ich die 4090 sicher geordert hab.
Wir wissen das :) aber viele andere sind durch die ganzen Videos von YouTuber mit nur 30 mal Kabel wechseln und Brandgefahr verwirrt und lesen nicht diesen thread jeden Tag.
Anhang anzeigen 800441 Anhang anzeigen 800443
Ähm du stellst einfach im Afterburner das Powerlimit hoch? Dazu brauchts keinen Bios Switch :)
Ähnliche Themen
Antworten
6K
Aufrufe
380K
