[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Aktuell neuer Tiefstpreis der 4090 Strix 2.229 Euro .. die UVP ( aus meiner Sicht gesehen ) sinkt weiter.. vielleicht gibts Freitag wieder ein Dropp zu einer Zeit wo die meisten Menschen Arbeiten so um 11-15 uhr
di strix wäre für mich sowieso raus, spulenfiepen ist da ja angeblich sehr ausgeprägt. Das ist für mich ein KO Kriterium
Hat die 4090FE keinen Zero Fan Mode mehr, wenn man eine eigene Lüfterkurve mit MSI Afterburner erstellt?
Die OC-Variante (nicht erhältlich) ist auch 200 Euro billiger geworden.
Scheint als wären alle Hardcorefreaks gesättigt...
doch.
das ging doch bei der 3090 FE schon nicht, bei der 4090 (habe keine) wird das wohl auch so sein. Meine gelesen zu haben, dass die lüfter der 4090 FE dann mit ca 1100RPM drehen, bei der 3090 sinds glaub 800 RPM was sehr leise ist
dann haste es bei der 3090 falsch gemacht. "use firmwarecontrolmode" anwählen und dann anpassen.
bei meinen screenshots musst du drauf achten, dass 40% im AB 30% im FE Bios ist.
oh dann gehts wohl doch. Ich will das aber so, dass die lüfter nicht ausgehen, daher hab ich mich nicht weiter damit beschäftigt. Aber gut zu wissen... DANKE
Wieso ist das so?
"Vernichten" deine Karte gerne mal, wenn du sie einschickst, lehnen Garantie ab, musst 6 Wochen und mehr warten, bis überhaupt was passiert und solche Geschichten.
Also die 4090 Strix is bisher recht leise .. hab aber nur 3D Mark getestet bisher ... die Fiept nich sondern surrt eher dunkel bis mittel hell .. kann einige sicherlich nerven
aber wenn man seine Boxen anhat und zockt wird man das nich hören... aber ich muss erstmal schauen wie das ausserhalb von 3D Mark is
4090 Strix Komplett @stock mit 3 x 8 Pin angeschlossen :
Und mit +190 core und + 1000 VRAM :
Und mein alter Score mit der 3080 Strix mit Max OC und Wasser Block :
Bei meiner Zotac fast gleiches Ergebnis in dem Bereich
Die Master taugt nix, es sei denn du bist taub.
PNY GeForce RTX® 4090 24GB XLR8 Gaming VERTO™ EPIC-X RGB Triple Fan
Etwas übertaktet hier meine Ergebnisse:
CPU läuft ohne HT und ohne preferred cores
GPU gönnt sich bis zu 450W aber bleibt kühl (64 Grad) und Lüfter drehen mit 1200 rpm
RAM + 1000 Mhz und hier ist meine Voltage Curve:
Die 4090´er tun sich all nicht viel...
Ist doch bei asus und Gigabyte nicht anders?
Ich habe im Treiber keine DSR Option mehr seit ich den den Neo G8 (32“ 4K 240Hz MiniLED) nutze, deshalb die dumme Frage.
Ich habe heut aber bereits auch festgestellt, dass ich sobald ich den Monitor in seinem OSD von 120Hz auf 240Hz umstelle, keine Custom Auflösung mehr erstellen kann im Treiber.
Ob das gleiche Phänomen auch für DSR gilt, habe ich noch nicht geprüft, das werde ich gleich morgen tun.
DSR zusammen mit einer 4K Möhre wollt ich schon mal testen. Ich fände es jetzt nicht mega schlimm, wenn ich das nur im 120Hz Modus nutzen kann, denn mal ehrlich, mit DSR zusammen mit 4K braucht man wohl eh nicht mehr als 120 … 🤣🤣🤣
Ach und by the way. COD MW2 in 4K Ultra mit HDR auf dem MiniLED, mit DLSS Quality in 180+ FPS - der SinglePlayer. HOLY SHIT!
Man kennt ja dieses Video:
Auf dem G8 mit der 4090 sieht der ganze SinglePlayer aus wie ein fucking CGI RealWorld Render in 180+ FPS 😳😳😳
Purer Grafik Porn der SinglePlayer mit der Hardware.
CoD und gute Grafik.
Hast du Scheisse aufm Auge?:d
Alleine Schatten, Beleuchtung und Animationen sind jetzt wirklich net so pralle und viele Texturen sehen echt richtig beschissen aus.
Man betrachte sich einmal die Texturen der Bäume genauer :fresse2:
Evtl für die Münchner interessant.
Bei NBB vor Ort noch eine RTX 4090 Inno 3D X3 OC zu haben. :)
Halber Like :)
Schatten und Beleuchtung fand ich auch nicht gut und gefiel mir bei MW 2019 besser.
Aber diese gehypte Amsterdam Passage geht keine 5 Minuten und wenn man genau darauf achtet, wirkt die Geometrie fast überall unter aller Sau - Konsolenport PS4 / Xb One halt.
Konsolenmatsche :rolleyes:
So, bei meiner bei Amazon bestellten PNY steht jetzt als Lieferdatum der 21. bis 28.12. mit dem Hinweis dass sie evtl. nicht mehr vor Weihnachten kommt. Werde aber trotzdem kein Prime Mitglied, Ihr kriegt mich niemals leeeeebend! :d
Bei NBB bestelle ich nicht, die boykottiere ich seit dem sie meine RMA als Zweikäufer trotz Abtretungsformular abgelehnt haben.
Ähnliche Themen
