[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja, haben mich an NVidia verwiesen. Da scheint es wohl zu klappen, warte aber nun schon seit 1,5 Wochen auf die RMA Daten. Es kam nur eine Mail mit dem Hinweis, dass sie noch am prüfen sind. :fresse:
Edit: Ist aber alles halb so wild, die Karte funktioniert ja. Und solange ich zocken kann, habe ich Geduld. Nur warum das Lieferdatum bei Amazon erst nach vorne und dann nach hinten rutscht, über den ursprünglich angesetzten Liefertermin hinaus, ist mir auch als nicht Prime Kunde ein Rätsel. Aber it is what it is.:coffee2:
Der GPU-Die meiner TUF scheint extrem „bauchig“ zu sein :(
Hab mal testweise den Block nur aufgelegt und von den anderen Seite eine Lampe durchscheinen lassen. Man kann deutlich sehen, dass der GPU-Die ziemlich mittig aufliegt und rundherum minimal Licht durchkommt. Das auflegte PCB kippelt auch nicht - es „schaukelt“ - je nachdem auf welche Stelle man am PCB drückt. Mit dem planen Uhrenglas das Gleiche… :rolleyes2:
Ein sehr dünner Kühlerboden wäre hier von Vorteil
Ich habe gerade die FE-Version der RTX 4090 eingebaut (gekauft bei NBB für 1859 Euro). Die Lüfter laufen ganz ohne Störgeräusche und sind bei 1100 Umdrehungen unhörbar. Die Karte zirpt nur leicht ohne zu stören bei Port Royale.
Nachdem die Karte bei Port Royale 25500 Punkte mit Default-Einstellugen erreichte, habe ich das Powertarget auf 75% begrenzt und +100 MHz auf GPU und +1200 MHz auf den Speicher eingestellt: 24999 Punkte bei Port Royale. So kann das bleiben. :)
Oh nein. Jetzt fängt das schon wieder an... gibt es doch leise Karten? :-)
Mach mal ein Video ähnlich wie hier...
Das die FE bei 1100 rpm unhörbar ist kann ich mir einfach nicht vorstellen, meine habe ich einen Raum weiter noch leicht gehört 🥹
Stochastische Fragestellung:
Wie hoch ist die Wahrscheinlichkeit, dass der "Meine-FE-ist-bei-1100PRM-komplett-leise"-Nutzer objektiv Recht hat?
Antithese sind alle anderen FE-Besitzer und jedes einzelne geschriebene Hardware-Review, welches bei geschlossenem Case ca. 40+-db aus kurzer Entfernung statuiert.
Ich will dir nicht zu nahe treten miro, aber du hörst entweder nicht mehr sonderlich gut oder hast die Noctua nf-a-FE-Special Edition gezogen, mit den guten resonanzfreien Lüftern drauf.
So, bei meiner bei Amazon bestellten PNY steht jetzt als Lieferdatum der 21. bis 28.12. mit dem Hinweis dass sie evtl. nicht mehr vor Weihnachten kommt. Werde aber trotzdem kein Prime Mitglied, Ihr kriegt mich niemals leeeeebend! :d
Bei NBB bestelle ich nicht, die boykottiere ich seit dem sie meine RMA als Zweikäufer trotz Abtretungsformular abgelehnt haben.
Oh man tut mir Leid, das ist echt bitter. War ja eh schon schockiert (wenn auch auf freudige Art und Weise) wie das bei mir Verlaufen ist, aber dass gleichzeitig das Pendel anderswo ins entgegengesetzte Extrem schwingt, hätte ich nicht gedacht =(
Hat wer bei der Gigabyte Gaming OC 4090 ne eigene Lüfterkurve erstellt und mit welchem Tool? Bei mir funktioniert das nicht im Afterburner. Stell ich da ne eigene Kurve ein springen die Lüfterdrehzahlen komplett im Nvidia Overlay hin und her z.B. von 0 auf 500, 1000, 0, 3000 und das alles in ein paar sekunden. Die Lüfter drehen auch nur kurz hoch mit geringer Drehzahl und gehen dann immer wieder aus.
Jo das war bei der Aorus Master auch so, lässt sich nicht vernünftig regeln
Naja Hauptsache ich habe sie für die Tage nach Weihnachten. Da hab ich nämlich Urlaub und kann ausgiebig testen. Insofern halb so schlimm, aber trotzdem ärgerlich. Habe bei Amazon nun doch mal angerufen, die Dame am Telefon konnte mir aber auch keinen Grund nennen. Nicht Prime Mitglieder werden aber angeblich nicht benachteiligt bei der Reihenfolge. Nur der Versand ist nicht so schnell.
1100 RPM sind bei der FE 30% die geringste Geschwindigkeit, die ist dann kaum lauter als die Asus TUF mit gleicher RPM.
Bei PCGH liest man immer 3 Sone, aber das sind ja Maximallast-Lautstärken. Bei meinem Hörtest sind 30% gerade so laut, daß sie im Verband der anderen Gehäuselüfter im Einklang bleibt, daß sind die Gehäuselüfter eines BeQuiet Pure Base 500 DX. Ab 35% übertönt sie aber schon die anderen Lüfter. Aber wenn man zockt, ist das nicht störend. Kopfhörer muß ich bei der FE nicht tragen.
Für Dying light 2 gibt es jetzt einen internen Benchmark.
Bei meiner Zotac fast gleiches Ergebnis in dem Bereich
Ich hatte da nur kurz mal angetestet das is noch nich das Limit meiner Karte ... wollte eigentlich nur mal den Abstand von der 4090 zur 3080 aufzeigen die ich vorher hatte und lief auch mit 450 Watt max. weil 3 x 8Pin
... zumal mit Wasser dann ja nochmal mehr gehe sollte. Aber war ein stressiger Abend gestern hatte ja dann nur noch ein paar Std bis ich pennen musste weil die Karte erst um 19 Uhr kamm und ich noch umbauen musste aber wollte noch etwas OC Testen aber vorranigig wollte ich einige Games testen und schauen wie meine 4090 Strix so fiept bzw eben nicht fiept sondern eher surrt da hab ich dann nur mal für 30 min etwas 3D Mark OC getestet .. dennoch werden die sich alle sicherlich ähneln .. Am WE werd ich nochmal etwas mehr 3D Mark OC machen da hab ich dann mehr zeit dafür .. und interessant wirds dann eh erst mit Wasser :d
nur is bei mir halt ab 450 Watt Sense beim OC Testen mit meiner 4090 Strix weil halt nur 3 x 8 Pin und fürs Gaming drossel ich auf 400 Watt
Hast dieses Häckchen bei "use Firmware Mode" oder wie das heiß bei der Lüfterkruve aktiviert im MSI Afterburner?
Ah und Gigabyte hat nen Bios und Firmewareupdate auf der Webseite.
Ärgerlich, wenn man das nicht fixen könnte.
Hab ich probiert kam aber ne Fehlermeldung, dass es bei 3 Lüfter oder so nicht geht. Keine Ahnung wieso. Bios Update muss ich mal machen momentan geht das Internet nicht...
Und wie hoch drehen deine gehäuselüfter? und welcher durchmesser?
Aktuell neuer Tiefstpreis der 4090 Strix 2.229 Euro .. die UVP ( aus meiner Sicht gesehen ) sinkt weiter.. vi####
Preise sind wieder "wie vorher", STRIX OC auf ~2400€ und TUF OC auf ~2300€.
Ist aber am Ende eh egal für welchen Preis es die "gibt", ich hab seit 22.11. da ne Bestellung offen für ne TUF OC die einfach nicht versendet wird. Konnte man bestellen (und natürlich bezahlen) und dann kam auf Nachfrage die Antwort:
Leider kommt es momentan aufgrund der hohen Nachfrage zu Lieferverzögerungen. Es kann daher vorkommen, dass sich Ihre Warenlieferung um ein paar Tage verschiebt. Leider gibt es aktuell noch keinen neuen Liefertermin.
"paar Tage"...is klar. Was sind schon 2 Wochen unter Freunden wenn man mit 2100€ in Vorleistung gegangen ist.
Zwischen ASUS die nicht verschicken, und NBB die mir "weil ich schon ne FE hab" stornieren warte ich jetzt einfach mal ab bis nächste Woche die AMD Karten kommen. Vielleicht verrückt sich was am Preis, vielleicht nicht. Auf die paar Tage kommts jetzt auch nimmer an.
Also entweder hast du schnell drehende Gehäuselüfter, oder die TUF ist merklich schlechter als ich dachte.
Ich PNY 4090 und FE haben bei mir Welten getrennt. Ja, die FE war nicht brutal laut, aber ganz weit weg von leise oder gar unhörbar.
Naja selbst Schuld. Ohne Lieferdatum hätte ich nach ein paar Tagen storniert.
Jup is normal beim Asus Shop und hatte ich in diesem Thread schon so 3 - 4 mal geschrieben als das mal aufkamm ... die Preise dort schwanken oft mal höher dann wieder niedriger und wieder höher
mal 100 euro dann mal 50 euro dann mal 70 und mal 200 euro usw war 2020 auch schon ich weiss aber nich warum der Asus Shop das so handhabt is schon etwas strange aber auch teils gut
da man so rausfinden kann wie der eigentlich Preis ohne Shop Scalper Aufschlag der Karte ist und da liegt die 4090 Strix bei 2229 Euro wohin sie bei anderen shops immernoch für 2500 Euro
angeboten wird aber so weiss man das man da dann 270 Euro Shop Scalper Aufschlag draufzahlt und kann dann entscheiden ob man bereit ist dies zu tun um eine Karte zu bekommen
oder noch wartet bis man ne UVP 4090 Strix bekommt
Da hatten an dem Tag wohl zuviele bestellt .. wundert mich das du kein Storno bekommen hast denke du bist da dann halt nun direkt in der Warte Posi und wenn die wieder ne Ladung bekommen
bekommst du deine dann.
Auf die 4090 wird ne AMD 7900 XT oder 7900 XTX Karte Preislich keinen Einfluss haben dafür is die Kluft zu gross aber bei der 4080 könnte sich vielleicht noch was tun da AMD da bei 4K Rasta wohl besser rauskommt
aber bei Nvidia is dann halt Ray wieder besser ... also wenn dann wird nur die 4080 etwas günstiger werden und die 4090 nur wenn halt der Euro Preis an den Dollar angepasst wird
wie letztens passiert oder halt wenn AMD ne 7950 XTX rausbringt die an die 4090 rannkommt
... oder wenn der Markt zu dem jetzigen Preis gesättigt ist und einfach keiner mehr kauft. Damit rechnet meine Glaskugel ab Januar/Februar 😁
Nvidia Level 3 Support hat sich gemeldet bzgl. dem Black Screen Issue bei Multi-Monitor.
*Wow wow viva - gefixt endlich.
Ja sowas könntest du bei AMD vergessen .
Ist zwar nervig , dass Moment ein Treiber nach den anderen kommt , aber die setzen sich wenigstens dran und versuchen allem Anschein nach ihr bestes .
Auch da bezweifel ich das die Preise fallen werden ... gabs 2018 halt auch die 2080 TI lag dort bei vielen karten immernoch bei 1.200 Euro und teils auch bei 1.500 Euro
obwohl die Karten auf Lager waren erst kurz vor der 3000er Serie gabs ein paar günstige Karten. So zumindest das was ich damals mitbekommen hab
mag sein das ihr andere erfahrungen gemacht habt aber in meinen erinnerungen hat sich bei der 2000er Serie kaum was getahn bis kurz vor Release der 3000er
Ich schätze Nvidia sogar so ein das selbst wenn die AMD Karten besser sind sie die Preise so lassen würden.
Aber ich gönns euch wenn ich da falsch liege
Ähnliche Themen
