[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So, hab mir jetzt auch ne 4090 gezogen. :devilish:
Bin gespannt ob mein 750 Watt Netzteil mit der klar kommt.
Sollte kein Thema sein wenn es ein ordentliches ist. Die Spikes sind bei der 4090 sogar smoother als bei der 3090 und das UV Potenzial ist echt crazy.
Die PNY gäbe es aktuell bei NBB für 2.079 Euro (etwas günstiger als das Angebot von Amazon). Mit Cashback (z.B. 2% über DealWise) geht noch einmal was am Preis.
Ist ein bequiet Straight Power 11 750.
Lief mit meinem 10850K@5GHz und der 3080@2,1GHz (355W PT) problemlos.
Mache ich morgen, zocke gerade noch Hunt.
Ja, scheint wirklich eine Perle zu sein. Die gib ich nicht mehr her.
Speicher läuft mit 1400 MHz schon den ganzen Tag.
Aber +1400er Speicher und 3100 MHz Core sind nun doch auch nicht so krass, also klar schon solide, aber nun auch kein golden Chip. Gibt hier ja einige Karten die 3135-3150 und teils noch mehr machen und auch auf dem Speicher gehen einige ja in Richtung +2000
Solange du das Teil nicht mit 3000mhz+ bei 1.1v @500W laufen lässt, sondern schön UV mit 2700Mhz bei 0.95v betreibst, zieht das Ding nur 250-300W, bei aktivem DLSS sogar noch mal rund 50W weniger.
Selbst wenn du sie mit 500W quälst, hast du genug headroom bei 750W. Beim Gaming kommt so ne OC CPU auf durchschnittliche 100W(max150w).
Alles easy mit 750W! Wirst sehen, mit UV ist die Karte deutlich sparsamer als deine alte 3080 und dabei gefühlt doppelt so schnell.
Ich zocke 4K mit DLSS bei 180-220FPS teilweise mit 220W GPU. Die Karten sind einfach sick.
2820 MHz bei 1.05v bis 41°C
ab 42°C 2805 MHz.
Ich habe einen neuen OC Test gefunden:
Warhammer Darktide mit allen Settings auf Max mit FrameGen (Super Resolution off)
Wenn man eine Mission startet und es beim Missionsstart abschmiert (nach dem Ladescreen, wo die 4 Players sitzen) - kann man ganz schnell herausfinden, ob die Karte stable ist.
(die Scale Option für Decals von Medium übernehmen und den Rest von Hand hochknallen).
Aktuell mit Abstand der beste Test für mich. Wenn es nach dem Ladescreen crasht, ist vorbei.
Ich wäre da vorsichtig, die Shice crasht auch bei mir nach dem Ladescreen, aber mit stock settings bilde ich mir ein.
Das Spiel ist immer noch verbugt und unfertig. Der aktuelle Crash-Patch hilft da nur wenig. Bist du dir da sicher? Ich werde das mal beobachten und mal paar Runden mit stock settings ballern.
Ja, man absolut sicher.
Ich habe mit Stock oder stable Settings absolut keine Probleme... habe mittlerweile 32.3 Std. gespielt.
Ok, da fallt mir gerade ein, wie man das feststellen can. Wenn du nen crash nach dem Ladescreen hast, check auch mal den Zuverlässigkeitsverlauf, ob da nen Hardwarefehler vorliegt. (Ggf 5min warten, manchmal dauert es etwas, bis die Shice im Zuverlässigkeitsverlauf auftaucht.) Oder check einfach so mal die history, da müssten ein paar Hardwarefehler vorliegen bei deinen crahses nach dem Ladebildschirm.
Bei einem Hardwarefehler wars tatsächlich zu viel oc.
Perfekt der Euro-kurs ist ja leicht besser geworden so sind es nur noch 11.379,26€ :)
Wieder eine von den selten Masters
1 Stück:
und hier 11 Stück:
Für Wakü ist die Master ein heißer Kandidat weil ich konnte die Spulen nur höhren wen ich das Ohr fasst auf die Karte gelegt habe und dann auch wirklich kaum Wahrnehmbar.
Und selbst mit 560 W blieb sie leise.
Ob das ein Glücksfall war kann ich natürlich nicht sagen bei nur eine Master die ich hatte.
@Air sehr Potenter Kühler aber die Lüftersteuerung ist sehr schlecht gemacht worden .
Im Silent Modus drehen die Lüfter mit 1450RPM an was völlig unnötig ist und da zu führt das die Karte unötig laut wird.
Das fixen der LS mit dem AB funktionierte nur bedingt teils nach Win Start wen das Profil geladen wurde wo feste 1000 RPM laufen sollte sprangen die Lüfter nicht an und Mal doch .
Wen es da ein BIOS gibt was das fixt dann ist alles gut wen nicht dann sollte man @Air was anderes suchen.
Ihr immer mit eurem kastrierten UV. Lasst die Karten doch einfach ihr 3 GHz-Potential entfalten und begrenzt mit Framecap und Powerlimit damit das ganze nicht ausufert.
Mit dem Spiel habe ich nichts am Hut, aber mich aus technischer Sicht die neue Unreal Engine 5.1 mit Lumen und Nanite interessiert. 4k, all-max, ca. 100fps bei 300 Watt.
Yoooo hier scheissen sich die Leut in die Hose beim biegen des Kabels. Und dann gibts sowas…. und stellt euch vor auch da fackelt nix ab. Die Schmelzaffäre liegt zu 99% beim Anwender.
Hier habt ihr die einmalige Chance eine RTX 4090 von EVGA zu kaufen
über 10k, da mach ich doch mit :d
Old news. Aber sollte es eine leise 4090 geben, die im weißen Kleid daher kommt, wird nochmal gewechselt, egal wie glücklich ich mit der FE / PNY bin.
ist die master zu empfehlen, oder lieber die strix nehmen?
Ich bin gespannt wann Alphacool und Aquacomputer sowie Watercoll den Kühler für die Strix bringen.
@***** coretechnisch dürfte das eine der besten Karten hier sein. Speicher okay, da er ja kühl gewesen sein dürfte und dann geht nicht so überragend viel.
Tja da wird wohl sein Kollege mit seiner TUF leben müssen 🤣🤣🤣
Nachricht gelöscht
Soeben das Thema RTX 4090 für dieses Jahr beendet. SuprimX auf dem Rückweg.
So leit es mir tut, aber beim Rendern das rasseln, ich komme einfach darauf nicht klar.
Da lasse ich lieber länger Rendern hab aber dafür meine Ruhe. Winterurlaub steht eh an, da darf sich wer anders über die Karte freuen.
Neues Jahr, und vielleicht neues Glück dann.
Beste Grüße und viel Spaß weiterhin mit den gut gehenden Karten.
Ähnliche Themen
