[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Habe auch das Corsair da es komplett ungeslevt ist hat das zum knicken die besten Vorraussetzungen.
Hab ein bequiet Netzteil. Man darf doch keine Kabel anderer Hersteller wegen der eventuell anders belegten Leitungen benutzen, oder?
Habe gerade eine Aorus Waterforce da.
Max. PL liegt bei 500W, nicht 450W, wie hier gestern von jemandem geschrieben. Scheint aber auch schon eine zweite Revision (1.1) zu geben, wozu man natürlich mal wieder absolut nichts zu finden kann.
Karte hat einen ordentlichen Stock Boost von 2820mhz@1.05v. Macht mit einem +200 Offset somit die 3ghz mit default Spannung bisher stabil in Cyberpunk und Co. Mit 1.1v laufen auch 3105. Beim Speicher ist bei +1400 Schluss.
Temps mit Push/Pull config und Noctuas im geschlossenen O11-Dynamic liegen bei ~450W um die 57°-59°. Das "große Manko" an der Karte, was sie scheinbar ziemlich verkackt haben, ist die VRAM Kühlung. Der geht bis 78° und ist im Vergleich zu den Luftkühlern gute 10°-15° höher, natürlich immer noch voll im Rahmen.
Pumpe ist relativ leise, hört man aus 1-2m nicht mehr, wenn man sein Ohr ans Gehäuse hält ist sie schon leicht am sprenkeln.
Kein Fiepen, leichtes surren/buzzing, dass sich ähnlich wie das Pumpengeräusch verhält. Aus 1-2m kein Problem und keine Klangbelästigung.
Die 4090 Waterforce Variante haben sie definitiv schnell hingeschustert, die 4080 Variante kommt in einem ganz anderen Design und nicht aus dem 3090Ti Ersatzteillager. :hust::fresse:
Temps mit Push/Pull config und Noctuas im geschlossenen O11-Dynamic liegen bei ~450W um die 57°-59°. Das "große Manko" an der Karte, was sie scheinbar ziemlich verkackt haben, ist die VRAM Kühlung. Der geht bis 78° und ist im Vergleich zu den Luftkühlern gute 10-15° höher, natürlich immer noch voll im Rahmen.
Interessant, hat Gigabyte VRAM Tempprobleme?
Die Preise scheinen trotz Nvidia Preissenkung wieder angezogen zu haben. Cutsom Modelle unter 2000€ eher selten bis keine.
Billigster Preis bei der Master lag bei 1350€. am 12.10 war das 2250€ bzw 2180€ nach -70€ Cashback
Wenn alles gut geht kommt die Master heute mit Hermes :) ... natürlich schneit es heute ^^
Bzgl Lüftersteuerung bin ich schon gespannt. Werde auf jeden Fall die Bios/Firmeware Updates machen
Kann dann die FE mit der Master vergleichen. Die FE steckt halt im OC die Temps nicht ganz so leicht weg bei geschlossenem Gehäuse. Da drosselt es schon ein wenig.
Berichte mal wie es sich bei der verhält.
Oh das weiß ich nicht damit habe ich mich noch nie beschäftigt !
Denke Mal wen das gehen würde dann hätten die Leute das hier auch schon erwähnt.
Die Custom Kabel sind jat auch separat für bestimmte Netzteil Marken gekennzeichnet!
Von daher ist mir auch kein Universal Kabel in dem Sinne bekannt!
Nein, ist nur bei der Waterforce meines Wissens. Gaming OC und co. haben dieses "Problem" nicht. Ich persönlich sehe das wirklich nicht als Problem, wenn er doch sogar besser gehen soll bei mehr Hitze.
Im Vergleich zum 3090 Speicher sind 78° ja noch fast kalt. :bigok:
Ok, ich muss sagen, ich bin mit der PNY 4090 mega zufrieden - sie ist gestern angekommen und ich habe sie heute eingebaut und ein paar Tests gemacht. Lüfter sind kaum wahrnehmbar (mit Kopfhörer sowieso nicht), Temperatur passt und ich nehme auch kein Spulenfiepen wahr (vielleicht bin ich für hochfrequente Töne auch einfach zu alt). Kurzum: Passt für mich.
Wie schauts mit Rasseln aus?
Wenn er für hochfrequente Töne zu alt ist, ist er für Rasseln vermutlich auch zu alt. Oder er klebt nicht mit dem Ohr an der Seitenwand vom Gehäuse :)
Also ich nehme kein Rasseln wahr, die Lüfter sind ganz normal und leise.
Offensichtlich ist 38 da schon kritisch, ja.
Gehäuse steht am Boden, wie es sich gehört, neben dem Tisch. :angel:
Kann ich beides komplett nachvollziehen. Ähnliches Alter und Gehäuse steht auch unten auf dem Boden. :d
Ich kann mir wirklich sehr gut vorstellen, dass hier einige mit nem Stethoskop oder dem Pappkern einer Küchenrolle unterwegs sind und an ihrer Hardware lauschen, ob nicht doch etwas fiept oder rasselt :LOL:
P.S.: Zähle mich dazu (Papprolle)... :fresse:
Ja da würde ich nicht weit gehen um das zu glauben. Hier ist der Verrückten Sammelpunkt.
Soeben das Thema RTX 4090 für dieses Jahr beendet. SuprimX auf dem Rückweg.
So leit es mir tut, aber beim Rendern das rasseln, ich komme einfach darauf nicht klar.
Da lasse ich lieber länger Rendern hab aber dafür meine Ruhe. Winterurlaub steht eh an, da darf sich wer anders über die Karte freuen.
Neues Jahr, und vielleicht neues Glück dann.
Beste Grüße und viel Spaß weiterhin mit den gut gehenden Karten.
Hol dir die kfa2, habe kein Spulenfiepen, die Karte ist leise und im Gaming bisher max 60 Grad gesehen, einfach nur geil das Ding
Einmal im Dunkeln, einmal bei eingeschaltetem Licht. Auf den Boden damit und gut ist. :xmas:
Sie ist im Übrigen deutlich wuchtiger als die 3090 oder die 6900. Hat im Gehäuse gut Platz, aber auf dem Mini-Mainboard schaut das lustig aus.
Kann ich auch nur empfehlen...vor allem passt sie selbst in ITX Gehäuse wunderbar rein 😁
voltage control aktiviert :bigok:
kann deine mit 600 Watt laufen oder hast du auf 450 Watt reduziert ? Ich bin ja auf 450 Watt begrenzt wegen 3 x 8 Pin und mein Durschnittstakt is niedriger als deiner obwohl meine Karte kühler lief
und mehr Core Takt hat .. die Erklärung dafür für mich grad wäre nun nur das deine 600 Watt ziehen darf wohin meine ja nur 450 Watt darf und würde auch mit den Temp unterschied erklären.
Deiner :
Meiner :
Anhang anzeigen 826553-- Anhang anzeigen 826555
Anhang anzeigen 826554--------------------------Anhang anzeigen 826556
Deiner :
Meiner :
Eure Karten sind schon gut. Über 21k im TSE ist schon cool. Meine schafft unter Wasser und Fenster offen nur maximal ~20600.
So gerade den Witcher installiert nun kann das next Gen Update kommen bin Mal gespannt wie die Strix das managed.
Deiner :
Meiner :
495W, müsste flashen...
Okay das erklärt dann deinen höheren Durchschnittstakt bei mir geht ja nich mehr wie 450 Watt... viel mehr Punkte kann ich aus meiner Karte aber nich mehr rausholen ... mit etwas mehr CPU takt
und vielleicht noch mehr VRAM Takt könnte ich vielleicht noch die 15.000 Punkte knacken aber ich glaub ich lass das Benchen nun erstmal bis der Wakü Block da is.
Im Overclock Forum sind sie begeistert vom Galax 666W BIOS - wer probiert es?
Teuflisches BIOS, macht meiner ASUS TUF non-OC richtiges Höllenfeuer.
Der härteste Stresstest ist auch bei Ada immer noch Quake 2 RTX mit dem Vulkan path tracer.
Mit dem Asus Bios ist man dort noch regelmäßig ins Powerlimit gelaufen. Das sind die grünen Blöcke unten bei "PerfCap" Reason. Beim Galax HOF Bios gibt es das Problem nicht, nur noch die Spannung begenzt siehe blauer Balken. Zudem schiebt das Bios zum Teil über 500 Watt nur in den GPU Chip. Habe ich so auch noch nie gesehen.
Um bei diesem extremen Szenario auch die 3 GHz aufrecht zu halten, braucht es viel Leistung. Kleiner Haken für ASUS Flasher, der zweite HDMI Port läuft mit dem Galax Bios nur auf 1080p/60hz.
Hier mal ein Video vom Surren ( ein Fiepen oder Rasseln isses jedenfalls nich ) meiner 4090 Strix OC .. es läuft da grad 3D Mark Speed Way Test... am Anfang und am ende hört man ungefähr die Lautstärke des Surrens die ich auch höre wenn ich ganz normal am PC sitze und erst wenn man nah an die Karte geht is das surren laut ... läuft im Hintergrund Musik im Falle von zb Cyberpunk der Game Sound hör ich davon nichts mehr.
Die Surren Geräuschlautstärke is in etwa die selbe wie bei meinen 140mm Lüftern wenn die mit 700- 800 umdrehungen laufen alles absolut okay für mich persönlich
Das Tuckern was man im Hintergrund hört kommt von meiner HDD Festplatte.
@Youngtimmer dann Bitte später dafür die Werte mit dem ALPHACOOL Kühler nach liefern.
Die Macht ja richtig Party :bigok:
Hab mir das gerade auf meinen HIFIMAN reingezogen.
Findest du ? Ich find das eher sehr seicht ... aber klar wenn man mit seinem Ohr so nah rangeht wie ich mit dem Handy isses schon lauter .. aber bei einem Normalen Sitzabstand is das schon sehr seicht
und wenn mann dann noch Game Sound anhat ( Normale Stereo Lautsprecher ) hört ma nix mehr ... wie gesagt am Anfang ( die ersten 2 sek ) und am ende ( die letzte 2 sek ) des Videos isses so wie ich es höre wenn ich normal daneben sitze erst wenn ich unnormal nah an mein PC rangehe wird es logischerweise lauter .. genau deswegen bin ich extra von weiter weg gestartet und dann näher gekommen und am ende wieder weiter weggegangen im Video
Surrt aber auch nur bei 3D Mark sowie Cyberpunk und bei Borderlands 3 auch leicht
@Stagefire
Ja ist schon deutlich zu hören hier auf meinem HIFIMAN Kopfhörer .
Vielleicht nimmt das Micro das ja übertrieben auf.
Ähnliche Themen
Antworten
4K
Aufrufe
194K
