[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich konnte bzw. wollte es nicht glauben, dass meine CPU bei 4K die 4090 limitieren kann. :/
Bin tatsächlich am überlegen den 5800x3d zu nehmen. Baue eh noch auf wakü um. Und muss meinen CPU wb mal säubern, da bietet sich gleich ein upgrade an ^^
Kommt aber auch drauf an ob dein Bildschirm/TV das dann kann. Bisher war es ja oft so, dass die 4k/UHD Displays meist 60 Hz hatten. Somit war man im 4K Bereich mit 60 FPS zufrieden (wenn man diese überhaupt mit den älteren GPUs erreichte) und die CPU war da eher weniger der limitierend Faktor. Bei WQHD 240Hz oder jetzt mit den UHD/4k Panels mit 144+Hz und der 4090 werden die CPUs auch zum Problem.
Hast du also ein 60 HZ Display ist es egal. Vsync oder 60 FPS Limit an, dIe Grafik aufs Maximum aufdrehen (dafür hat man ja die 4090) und gut ist. Dann wird vermutlich auch die CPU nicht so schnell limitieren.
Hast du nen 144 4k/UHD Panel dann müsstest dich tatsächlich mal nach einer besseren CPU umschauen. Wobei ich auch immer aufpassen würde dass ich mit DLSS usw. die Grafik nicht zu sehr reduziere. Wenn man eine 4090 hat, finde ich zumindest, sollte man da die Grafik aufs Maximum treiben und nicht reduzieren um unbedingt die 144Hz zu erreichen (außer in schnellen Shootern). In CyberPunk auf Max, Raytracing und 4k schafft selbst die 4090 noch nicht durchgehend mit ~60 FPS. Für CyberPunk und maximaler Grafik könnte es z.B. sein dass du eh keine 60 FPS erreichst und deine GPU statt die CPU limitiert.
Bei der 4090 ist es aber prinzipiell schon die bessere Kombi wenn man eine CPU aus dem oberen Segment nimmt (Inten i7/i9 oder Ryzen 7/9)
Meine Gainward 4090 von LDLC ist gestern gekommen. Dafür das sie aus Frankreich kam war der Versand eigentlich recht flott. DPD hat sie auch überlebt. Ich hatte schon Angst :).
Zur Info: Die Sendungsnummer von Chronopost kann man auch bei DPD eingeben und dann auch Ablageort und anderes festlegen. Dies ist in der Sendungsverfolgung von Chronopost nicht möglich.
Taktmäßig ist sie nichts besonderes ~2715Mhz. Spulenfiepen seeehr leise, ggf mit UV ganz weg. Rasseln nicht vorhanden. Lüfter mangelhaft. Direkt ab 30% brummen sie. Unter Last erreichen sie so gut wie nie 40% aber das brummen ist allgegenwärtig. Im Idle ist der Zero Fan Mode immer aktiv, der Wechsel ist auch sehr flott. Bei manueller Lüfterkurve funktiert dieser aber nicht. Aber wie es scheint ist die manuelle Kurve auch nicht unbedingt nötig. Die Werkseinstellungen im Silent Bios sind wirklich gut.
Werde mal ein paar Tage grübeln ob ich mit dem brummen klarkomme. Beim Zocken hab ich eh meine Kopfhörer auf und dann hör ich davon nichts mehr. Allerdings finde ich es schon heftig was für Kompromisse man trotz dem Kaufpreis eingehen "muss". Im großen und ganzen ist es für den Kaufpreis von knapp 1800€ doch ein "gutes" Lotterielos...
Kann die Beschreibung mit meiner Phantom von LDLC weitestgehend bestätigen. Spielenfiepen würd ich zwar nur bei UV als sehr leise bezeichnen aber wie wir ja inzwischen wissen kommt es da doch auch auf den Betrachter an. Lüfter sind einfach nicht toll.... Aber würd ich 200€+ mehr zahlen damit ich etwas leisere Lüfter mit einer anderen Custom habe? Eher nicht
Also bei meiner Gainward ganz zu Anfang habe ich auch gedacht, dass es mich nicht so stört. Aber von Tag zu Tag hat es mich mehr genervt, bis ich die dann doch Retoure geschickt habe. Mit Stocksetting oder UV mag es gerade noch gehen, aber wenn man der Karte mal die vollen 500W gibt und etwas OC drauf packt wird das Brummen teils zu einem Kreischen. Sehr unangenehm und auch wenn ich die Karte so nicht betreiben will erstmal, wurmte es mich doch, dass diese Option für mich quasi wegfällt, da der Lüftersound abartig ist. Stelle z.B. mal manuell auf 52% Lüfter im AB, dann hörst du wahrscheinlich was ich meine. Ich hatte jedenfalls 2 Gainwards hier und die haben sich exakt gleich Verhalten von der Lautstärke auf bestimmten Geschwindigkeiten.
Dass der VRAM eine, bei Dir, relativ hohe Betriebstemperatur braucht, um stabil zu laufen, höre ich zum ersten Mal.
Habe ich auch zoom ersten Mal gehört, im techpowerup wurde mir das aber auch bestätigt. Werde dem am Abend nachgehen. Inkl. risercable check.
Hat schon jmd Portal RTX getestet?
Bei mir crasht das gleich zu beginn ... brauch lange bis es startet bzw muss 1 x mit der Maus irgendwo hin clicken bevor er auf das Game switcht .. mal kommt dann ein schwarzes Bild oder mal ein Weisses oder
es kommt dann kurz das Valve Intro und wen dann das Hauptmenu geladen wird gibts n crash bzw er reagiert dann nich mehr und muss das Game dann beenden ... scheinen wohl einige grade Probs damit zu haben
OK beim 5 ten Start versuch kamm ich jetzt grad zumindest mal ins Game Menu und kann dort Settings einstellen ... habs diesmal nich in Steam direkt gestartet sondern per Desktop Icon
aber raustabben is keine Gute Idee gab n Crash mit Sound Loop beim wieder reintabben .. im Portal Reddit gabs auch Berichte das die Foto Taste F5 auch zu crashes führen kann
Portal RTX scheint also noch recht instabil zu sein
Viel mehr als eine spielbare Demo ist es ja auch nicht.
Du kennst Portal oder ? Das wurde nun nich jetzt erst entwickelt als RTX Demo sondern is ein Game aus 2007 was nun RTX und Remix dazu bekommen hat und ein paar Stunden brauch man schon
um das dann durchzuzocken das is also schon ein volles Spiel und keine Demo wo man nur mal 1 oder 2 level spielen kann .. aber ja es ist nun nich das längste Game aber eben eine Vollversion und keine Demo
wasn schrott. sieht aus wie grütze und läuft mit 30 fps.
Jupp gut läuft das bei mir grad auch nich und hatte es mir auch hübscher vorgestellt die Texturen wirken oft so seltsam zb der Tisch wo der Wecker/Radio drauf steht
... konnte es nun entlich mal starten und auch raus und rein tabben ohne das es crasht :
"No Load" und 20 FPS und so 100 - 170 Watt is schon seltsam .. und hab immer 20 FPS nich 19 oder 15 sondern immer 20 .. als wenn da ein 20 FPS Lock vorhanden is
und deswegen dann auch "No Load" .. egal ob DLSS Qualität oder Performance oder Ultra Performance immer 20 FPS
Und nun gabs wieder n Crash .. oh man ... dann Ding is noch Buggy as Hell ... zum Glück hat mich das nur 1 Euro gekostet
Wie Dumm !!!
Im Nvidia Treiber die Hintergrund Max Frame auf aus statt wie ich vorher hatte auf 20 FPS : ( wie kommt man denn auf so eine Idee das damit zu koppeln ? Oh Man )
Aber die 4090 Strix wird da mal richtig Warm bei
Und hier sieht man auch mal das die Texturen echt nicch so schick aussehen .. es sieht natürlich besser aus als das Original aber so richtig schick sieht das auch nich aus und auch recht unscharf
steht man weiter weg sieht das alles gut aus nur darf man eben nich zu nah rangehen
Mit alles Max ( ausser die Bounce Sachen die stehen noch auf dem Standart Wert ) und DLSS 3.0 auf Quality bin ich so bei 40 - 52 FPS
weiss nich wie PCGH da auf 80 FPS kommt mit 4K DLSS 3 Quality kan sein das ich die Frame Generation nich anhatte das würde dann passen von FPS her
hatte die Option dafür noch nich entdeckt im Menu
die 4090 Strix mit 450 Watt ist dabei Temp mässig bei 68 - 71 Grad wenn sie dann mal warm gelaufen is ( hab solange gezockt bis ich die Portal Gun hatte )
das Game is nun auch Stabiler man muss das wohl echt immer über das Desktop Icon Starten und nich über Steam
hat vor allem mit raytracing nicht all zu viel am hut. der raum leutet trotzdem noch wien weihnachtsbaum.
Ich kenne es eigentlich auch nur so je kühler der RAM desto mehr Takt ist drin.
Hallo zusammen, hab am Freitag dann auch meine KFA 4090 von Saturn bekommen.
Hab sie nur fix getestet, bevor der Umbau auf auch Alphacool ES erfolgt. Superposition 8K bench gestartet und mir sind direkt die Ram Temps aufgefallen, als der Bench durch war standen satte 94° in gpu-z.
Karte fiepte oder surrte null, daher direkt den Kühler abgenommen, seht selbst...
Pads waren überall vorhanden, nur die drei oberen hatten null Kontakt.
Habe mich jetzt auch mal ans manuelle Undervolting gewagt. Läuft jetzt auf 2700MHz bei 0,925V und der Verbrauch ist in den meisten Situationen deutlich besser als mit 77% PL mit +150 Core. Ca. 280-300W vs. 350W. Wobei es mit UV auch deutlich höher gehen kann. Im Metro Benchmark z.B. habe ich auch 365W kurzzeitig gesehen. Takt ist auch höher als ich mit den PL Settings erreiche unter absoluter Volllast mit RT. Speicher steht auf +1499. Denke UV bleibt jetzt erstmal, bin so ganz zufrieden. Weniger Verbrauch als meine 3090, dabei viel schneller und EXTREM viel ruhiger. Selten so zufrieden gewesen mit einer GraKa (4090 FE)
Falls du RE2 Remake hast :d schau mal was der Verbrauch am Anfang beim Zombie in der Tankstelle macht, das ist lustig 😅 (Mit RT)
Die Strixx von der8auer ist auch wieder gefixed:
Top Mann, wenn mit meiner mal was sein sollte, versuch ich mein Glück dort. Sind nicht so weit weg von mir.
hab das video auch gesehen
leidder geht die karte bei roman trotzdem nicht :d
aber gut zu wissen dass wir hier in deutschland jemanden haben der im notfall helfen kann. 250€ sind dann auch zu verschmerzen :fresse:
KFA 4090 Noctua Edition 8-)
Derzeit noch mit braunen als Testaufbau, bin aber jetzt schon schwer angetan!
gerade weil der kühler so groß ist kann man auch größere fans dran machen und dann ist es nochmal leiser. bringt halt nur was wenn das ding nicht fiept sonst kann man sich das wirklich sparen :d
Also stock Kühler aber Noctua Lüfter? Sie Backplate würde ich aus optischen Gründen drauf lassen.
Jo, Deshroud und halt zwei A12x25 direkt an der Karte selbst angeschlossen.
Mit Backplate ging der 180er vorne nimmer rein. :fresse:
@Scrush
Bin sehr zufrieden mit der Karte was das angeht, und ich bin bisher noch nicht mal zum Undervolten gekommen.
Naja ist anscheinend doch nicht gefixt :d Aber habe das Video von dem Kris auch gesehen wie er da vorgeht und was für Tools er hat. Scheint ein echter Vollprofi zu sein. Wenn ich mal so einen Fall habe werde ich den auch mal kontaktieren.
Hihi ... das kannst Du doch gar nicht wissen. Vielleicht wurde der Account-Hacker tatsächlich nur wegen seines kaputten Autos kriminell. Bei manchen reicht ja schon, wenn's Bier alle ist :rofl:
Aber jut, dass Du Dich gar nicht erst auf den Weg machen konntest - da weißt Du ja wirklich nicht, was für kaputte Typen Dich erwarten!
Diese Typen sind echt die Seuche bei EKA...
Die "Nudel" samt "Mozartkugeln" sollen denen beim Sch... abfallen!!! :fire:
Sorry, aber das musste jetzt raus... :fresse:
Das hätte mich stark gewundert, meine TUF non OC packt bis +1700MHz ohne Bildfehler.
+1.700 :oops:
Meine ist davon weit entfernt :cry:
