[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
God of war.... zieht einfach mal auf stock 420-430W haha
ich war damals mit meiner 3080 ( non Ti ) 10 GB Strix im Bereich 50 - 65 FPS wenn ich mich grad recht erinnere
Stimmt mein Fehler. Ich hatte glaube ich noch die 1080p FPS im Kopf.... Hatte nur eine session in 4K 3080 ti und wollte dann nicht mehr und habe auf die 4090 gewartet.
limitiert die CPU?
sieht man doch :) gpu ist nicht am anschlag. ergo gpu ist NICHT das problem
In dem Video sieht man, dass deutlich mehr geht in dem game.
12900k, 5,3
G.Skill Trident Z5 RGB 6400Mhz DDR5 32GB 16x2 CL32-38-38-60 1.40v
ja zumindest in Elden Ring. In Forza ist die load bei 99%. Bis jetzt die einzigen games die ich getestet habe. Mal schauen..
jedes game ist anders
Ich konnte bzw. wollte es nicht glauben, dass meine CPU bei 4K die 4090 limitieren kann. :/
Bin tatsächlich am überlegen den 5800x3d zu nehmen. Baue eh noch auf wakü um. Und muss meinen CPU wb mal säubern, da bietet sich gleich ein upgrade an ^^
weil die cpu nichts mit der auflösung zu tun hat. die limitiert auch auf 8k wenn deine gpu mehr fps bringt als deine cpu
du kannst auch einfach die settings hochschrauben wnen es dir lediglich um die auslastung der 4090 geht. will du aber mehr fps bei gleichen settings brauchst du ne stärkere cpu :)
Ach scheiß drauf. Mit der hätte ich im Durchschnitt 10 fps mehr. Das sind keine 350€ wert. Habe grad mit dem Video an der gleichen Stelle im Spiel mit mir verglichen.
Video 90-100 FPS
Ich 80-90 FPS
Wärens 120 fps wie bei dem anderen Video, dann wär das nochmal anders.
Oh man ich hab die für 295€ gekauft und die geht jetzt für 140€ gebraucht weg...
du hast die cpu aber dafür schon ewig^^
Ich habe auch das Galax getestet - 3180 MHz liefen durch, allerdings mit Fenstermod ;-)
Vorher hatte ich auch schon 3180 MHz - ohne Fenstermod, allerdings MHz nicht durchgehend:
Speicher OC +/- gleich 1500 MHz, da bringt das Galax Bios bei mir nichts.
Wenn die Karte unter Wasser ist, teste ich noch einmal.
Generell wären sicherlich noch mehr Punkte drinnen, aber dann müsste ich erst alle Hintergrundprogramme/Prozesse aufräumen.
Das Galax Bios haut echt rein. Gerade kurz mit OCCT getestet ob das neue Powerlimit auch angenommen wurde. Holy...
Benchmarks laufen stabil, 21k GPU Score im Timespy Extreme hatte ich bisher noch nicht: https://www.3dmark.com/3dm/84810360?
Aber dafür braucht es kein Galax HOF Bios. Das geht auch bei 520W Bios. HOF brauchst du nur wenn du auch mehr als 1,1V drauf geben kannst und extrem kühlen kannst.
Mit Luftkühlung.
Beste Grüße
@kmwteam Meine TUF ist kein golden Sample, viel mehr als 3 Ghz geht da nicht. Mit dem Galax Bios schaffe ich aber mehrere hundert Punkte mehr als mit dem ASUS Bios. Bei dem Benchmark komme ich auch kaum an 500 Watt. Trotzdem hat Galax da irgenwas gemacht da es besser läuft.
Ist auch der Tenor im Overclock.net Forum: https://www.overclock.net/threads/official-nvidia-rtx-4090-owners-club.1800847/page-357
@UdoG Speed Way Durchschnittliche Taktfrequenz 3.180 MHz. Holy! Golden Sample würde ich sagen. (y)
Ich warte hier ebenfalls noch auf meinem Wasserkühler. Das Galax bleibt aber erstmal drauf, wofür hat man denn schon ein Dual-Bios.
Hier habt ihr die einmalige Chance eine RTX 4090 von EVGA zu kaufen
Viel Glück :)
meine Frau hat gerade gelüftet, scheiße kalt an den Füßen..., ohne Bildfehler, brauche kühlere Temps, Monsta ist am Ende:)
K mal schauen was kommt. Informiere mich gerade bei techpowerup, dort hat auch einer gemeldet, dass mehrere User meinten, sie haben mehr Probleme mit niedriegeren VRAMs temps.
Die User versuchten dann schlechtere pads einzubauen. (y) AC hat 1mm pads mitgeliefert für die VRAMs.
Weitere Möglichkeit wäre, die dünne Folie zumindest auf einer Seite der pads zu belassen für höhere Temps auf den VRAMs.
knapp an 11k vorbei
2. Monsta oder ein Mo-Ra :)?
weshalb sollte ich die news nicht gelesen haben?
externer Radi, muss ich mal entstauben sehe ich gerade
Wie sind die Kühlleistungen?
Erste Werte:
2940MHz GPU (mehr ist nicht drin, GPU ist eine oc-Krücke), +1800MHz VRAM:
430-440W: Wasser: 23,5°C, deltaGPU: 21°C, VRAM: 32-34°C, max 36°C
530-540W: Wasser: 23,5°C, deltaGPU: 27°C, VRAM: 36°C, max 40°C
Der VRAM ist aber alles andere als stabil mit den niedrigeren VRAM-temps. Bin am Überlegen ob ich die Temps nicht mit der pads-Folie raufprügeln soll. 60-70°C, eher 60°C weil Winter, wären das Ziel.
Erste Werte:
Der VRAM ist aber alles andere als stabil mit den niedrigeren VRAM-temps. Bin am überlegen ob ich die temps mit der pads-Folie raufprügeln soll. 60-70°C, eher 60°C weil Winter wären das Ziel.
Echt komisch das die Temps beim Ram da Schwierigkeiten machen.
Ab welchen Takt ist das den so?
Nen Schnelltest ergab auch +1500MHz instabil, nach ca 10-15min crash to desktop in Warhammer Darktide. Mit mehr oc kommen die crashes deutlich schneller, oft instant.
Unter Luft gingen noch +2000MHz im loop 20x port royal.
Ja Shice, habe eine GPU oc-Krücke (2860MHz unter Luft, darüber instabil, 2955-2940MHz unter Wasser), dann soll wenigesten der VRAM kompensieren. :o
Weiterer Lösungsansatz:
Den pad-streifen halbieren, als so dass die VRAMs nur noch zur Hälfte abgedeckt sind. Das sollte die Wärmeabfuhr grob halbieren.
Hast du mal probiert, ob der Leistungszuwachs auch in Spielen vorhanden ist?
schreit nach Push/Pull. Extern hast du kein Platzproblem und die Leistung wurdest du mit dem Radi definitiv steigern können.
Warhammer ist technisch wirklich top (y). Ich spiele alles maxxed (mit DLSS-Q, FGon) in DLDSR 2,25x (=5k), auch wenn es nur wenig bringt in dem Spiel in Sachen Bildschärfe, aber die Graka hat eben die Power dazu.
Nur die Helligkeit kann man nicht dunkel genug einstellen, es liegt immer so nen weiß/grau-Schleier über dem Bild. Muss dann über nvidia free style anpassen: Belichtung +40, Schatten +40 und Gamma -20. Dann wird alles dünkler und düsterer, so wie man es in einem dunklen dungeon zu erwarten hat. Der Schleier ist dann nicht mehr vorhanden. (y)Zusätzlich nutze ich Schärfen+ (20 und 20 als Einstellung) in free style um das Bild schärfer zu bekommen.
Nachricht gelöscht
Also das RAM Module besser laufen, wenn sie wärmer sind, halte ich ja für fragwürdig. SubZero ist das sicher was anderes, aber RAM reagiert in der Regel bei hohem Takt eher empfindlicher auf Temperatur.
Ähnliche Themen
