[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja ist schon deutlich zu hören hier auf meinem HIFIMAN Kopfhörer .
Vielleicht nimmt das Micro das ja übertrieben auf.
Das sowieso also bei Normaler Lautstärken einstellung meiner Stereo Boxen und Windows lautstärke auf 25 is das ok .. aber klar je lauter icch meine Anlage aufdrehe umso schlimmer wird dann auch die Lautstärke des Surrens im Video .. besonders wenn man das dann auch noch direkt mit Kopfhörer hört wie du zb grad klar is das dann sehr laut :ROFLMAO: :d .... und wie gesagt das surren ist zu vergleichen vom Pegel wie 140mm Lüfter die mit 700 - 800 umdrehungen drehen das is in etwa die selbe Lautstärke wie das des Surrens bei Normalen Sitzabstand .. das is eher sehr seicht alles.
Übrigens müsste deine 4090 Strix ja ähnlich bei 3D Mark kligen wie meine
Gottes Werk und Teufels Beitrag. :d
Und der ganze Aufwand mit 4k/120 OLED nur um ein unheiliges Spiel zu spielen...
Und das Surren kommt ja auch nur selten vor ... hier mal die Liste aus meinem Beitrag im Spulenfiepen Thread : ( 1 , 4 und 10 kommt surren vor bei den restlichen kommt kein surren vor sieht man von 7 ab)
bisher getestete Software ( 4K mit 117 FPS Cap ausser 3D Mark )
1. 3D Mark = Leichtes bis Mittleres Surren schwankt je nach Scene
2. Elex 2 = Nichts was ich mit meinen Ohren hören konnte
3. Spiderman mit Ray = Nichts was ich mit meinen Ohren höhren konnte
4. Cyberpunk mit Ray = Surren ähnlich dem von 3D Mark aber für mich nich stöhrend und geht größtenteils im Spielsound unter
5. Control mit Ray = Nichts was ich mit meinen Ohren höhren konnte
6. Quake 2 RTX = Nichts was ich mit meinen Ohren höhren konnte
7. Age of Empires 4 = beim normalen Spielen hört man nix nur wenn man ganz ganz schnell von oben nach unten die Karte scrollt mit den Pfeiltasten kommt ein leichtes Surren was man aber mit Game Sound nicht hört
8. Age of Empires 2 Def. Edition = Nichts was ich mit meinen Ohren höhren konnte
9. Golf With Your Friends = Nichts was ich mit meinen Ohren höhren konnte
10. Borderlands 3 = leichtes Surren .. wird weniger wenn man im Game in den Himmel schaut und dann noch nur 200 Watt anliegen .. stöhrt mich 0 is so seicht das der Game Sound das locker übertönnt.
Ab 230 Watt fängt das Surren bei Borderlands 3 an.
Bin halt echt absolut zufrieden mit der 4090 Strix ausser das sie natürlich günstiger hätte sein können :d
Hat eig schon jemand ein 600 watt bios auf eine 4090 Ref Karte geflashed pny/kfa2/inno?
Teuflisches BIOS, macht meiner ASUS TUF non-OC richtiges Höllenfeuer.
Anhang anzeigen 826622Anhang anzeigen 826621
Der härteste Stresstest ist auch bei Ada immer noch Quake 2 RTX mit dem Vulkan path tracer.
Mit dem Asus Bios ist man dort noch regelmäßig ins Powerlimit gelaufen. Das sind die grünen Blöcke unten bei "PerfCap" Reason. Beim Galax HOF Bios gibt es das Problem nicht, nur noch die Spannung begenzt siehe blauer Balken. Zudem schiebt das Bios zum Teil über 500 Watt nur in den GPU Chip. Habe ich so auch noch nie gesehen.
Anhang anzeigen 826627 Anhang anzeigen 826628
Um bei diesem extremen Szenario auch die 3 GHz aufrecht zu halten, braucht es viel Leistung. Kleiner Haken für ASUS Flasher, der zweite HDMI Port läuft mit dem Galax Bios nur auf 1080p/60hz.
Ist es easy das bios drauf zu bügeln (nvflash, cmd)?
Lüfter auf 100% bei den tests?
Galax HOF auf Strix -> bei gleicher taktrate fast 900 Punkte mehr in PR?! Wie? Warum?
Der Unterschied zw. Effective Clock und Clock ist deutlich kleiner…leider keine validen Ergebnisse da die GPU nur als „generic VGA“ erkannt wird. Selbst mit Wakü über 25c Delta T.
Von 29011 auf 29383 Punkte nur durchs Flaschen…leider lief nur 3075Mhz anstelle 3105 in PR weil das Wasser zu warm war…
Ganz ehrlich, ich würde es lassen. 450w sind ausreichend - selbst für 1.05 oder 1.1v.
Das sind Ausnahmen, wo man mehr gebrauchen kann.
Also beim benchen mit der kfa2 merke ich schon wenn ich auf 1.1v schalte und das Limit auf 510 Watt setze dass da mit 600 Watt noch mehr rauszuholen wäre, gerade in Port Royal, aber ja, muss nicht sein, in Games hab ich bis jetzt nur in God of War gesehen dass sich die Karte die vollen 510 Watt zieht, ansonsten sogar eher unter 450 Watt bzw sogar unter 400 Watt
NVflash bräuchte ich für 4000-er Serie. 5.792.0? HOF Bios gibts noch nicht bei techpowerup?
Habs gefunden.
Ja, da ist noch viel an Verbrauch rauszuholen. Aber nicht mehr an Leistung. guck dir doch bauers oder gamer nexus benches mit Eiskühlung an. Kaum mehr Punkte.
Zweiter Abend mit +1500 RAM in einem Game das die vollen 24GB belegt. Denke das kann man so lassen. Das es aber läuft, wundert mich nicht, so kann ich meine Karte bis +1800 RAM benchen bis Fehler kommen.
Jetzt könnte ich meine 2700MHz UV noch optimieren. Frage ist ob’s viel bringt. Spannung runter oder Takt ein wenig hoch. So krumme Sachen wie 2745 feiere ich aber halt auch nicht. Müssen schon „ganze Zahlen“ sein.
Die 2700@0.95v sind Rockstable, das macht sie seit ich sie habe. Ob das auch mit weniger, also irgendwas zwischen 0.90-0.94 läuft, habe ich noch gar nicht probiert. ~25mV machen es dann aber auch nicht mehr aus.
Was ich aber mega feiere, wie kühl das Teil bei 2700@0.95 schon bleibt. Ich spiele stundenlang 4K maxed out und das Ding hat einfach 54c Max oder sowas. Das hatte man früher nur mit einem Mora an der GPU.
Schade, dass die FE auf minimale 1100 rpm begrenzt ist. Sonst könnte man mit einer Custom Lüfterkurve noch was machen. Wegen mir könnte die auch auf 64c laufen.
Läuft der Ram schlechter??
Ja (y), und ich weiß ned woran das liegen soll, teilweise kacken auch +1700MHz up. Ich vermute aber es liegt am Riser-Shice. Ich werde erst mal so 1 Woche testen und dann nächstes WE die Karte wieder direkt in den Slot stecken. Oder ich verliere schneller die Geduld, dann noch vor dem WE. ^^
Ok lese ich zum ersten Mal oO Hast du nen Link zu dem Thema, finde auf die Schnelle mit google nix. oO
Ich nehme an, dass es dafür keine Lösung gibt?
Mein Kühlschrank hat auch nen Heizstab laut Hersteller. (y)
K mal schauen was kommt. Informiere mich gerade bei techpowerup, dort hat auch einer gemeldet, dass mehrere User meinten, sie haben mehr Probleme mit niedriegeren VRAMs temps.
Die User versuchten dann schlechtere pads einzubauen. (y) AC hat 1mm pads mitgeliefert für die VRAMs.
Hab heute meine 4090 eingebaut und grad in Elden ring getestet. Mich wundert es gerade, dass ich nicht wirklich unterschied zu meiner 3080 ti merke.
Hatte mit der 3080 ti auch um die 80 FPS. Habe jetzt so min 75 bis 110, je nachdem wo ich bin und was ich mach.
Was mich eher wundert ist, dass ich nur 250W ziehe und nicht auf 100% GPU auslastung komme.
Habe nur zum testen mein core clock im afterburner +261, aber an den FPS oder Power Draw hat sich nichts geändert.
Wenn ich PT auf 110% stelle ändert sich auch nichts.
In dem Video sieht man, dass deutlich mehr geht in dem game.
limitiert die CPU?
3x8 PIN 4090 FE
CPU 5600X
4K Elden Ring max settings
Elden Ring profitiert scheinbar auch nicht ganz so stark wie andere Games aber von der 3080 TI kommend sollte es da schon dennoch nen guten Boost geben
ich war damals mit meiner 3080 ( non Ti ) 10 GB Strix im Bereich 50 - 65 FPS wenn ich mich grad recht erinnere
Warum ist ist eig mein Core Voltage ausgegraut und wird nicht angezeigt? Ich würde es gerne mit 1.1V probieren.
Habe es in den Einstellungen eig eingeschalten.
Nutzt du Afterburner v4.6..5 Beta 4 Build 16358 ? Oder ne alte version ? Du brauchst ne neuere Beta Version damit das für die 4000er einstellbar is
Quelle :
ok bringt so schon etwas mehr, hatte mir aber mehr erhofft. Ich vermute echt, dass bei mir die CPU (5600X) limitiert.
In dem Video hat er auch eine GPU load von 97%. Ich komm da nicht ran.
Wie du schon erkannt hast, bremst da noch was deine Grafikkarte aus. Auslastung ist nur bei 77%.
Ähnliche Themen
Antworten
4K
Aufrufe
194K
