[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Zen4 verkauft sich nicht weil die Boards und rammzu teuer sind. Dazu die noch etwas gestiegenen cpu Preise.
Zudem hätten die von Anfang an mit 3d Cache bringen müssen .Potenzial verschenkt und daher selber schuld .
Ja, das wäre das Zugpferd gewesesn aber so kann man sich auch mit hardcore OC nicht absetzen. Daher bleibt es auch in den Regalen liegen. Bei der 4090 wird das aber anders sein. Mehrleistung ist ja da.
Ich frag mich gerade ob @Holzmann sich Pampers für Mittwoch besorgt hat. Damit er von 12 Uhr ( geschätzt) nicht mehr aufstehen muss, und den PC verlassen muss, um einen Kauf seiner geliebten nichts in weg steht.
PS. Ersatz F5 Tasten hast du hoffentlich auch genügend vorhanden 😄
Hoffentlich kriege ich Mittwoch eine Karte ab. FE würde mir erst einmal reichen. Auf Wakü umbauen werde ich die aber nicht, weil das PCB, insbesondere die Spulen, minderwertig (lauter) sind.
Was diesen komischen holzmann user angeht, der wirkt auf mich auch etwas "durcheinander" wenn man das diplomatisch ausdrücken möchte. Könnte aber wirklich ein troll sein.
Kann ich von meiner nicht sagen Höre nichts sie ist auch unter Wasser Rtx 3090 Ti FE.
Lg
Da ist nix groß mit biegen. Das Kabel ist gerade am 16Pin Anschluss derbe steif.
Hast du das kabel auch? Mir wäre wichtig zu wissen ab wie viel cm vom stück vom kopf weg welcher nicht in der karte steckt ich das kabel biegen kann
Gab es für die Gigabyte Master eigentlich Wasserkühler !
Hat jemand schon etwas über das Gewicht der Master gelesen ?
Ist ja auch ein ganz schöner Brocken!
Ja. Habs gerade ausgepackt. Gelobt seis Homeoffice. Aber ohne Grund / nicht an der GPU biege ich da erstmal nix. Das ist ziemlich ziemlich stiff das Teil.
Hier mal das 12Pin-Kabel, das ich 2020 von bequiet bekommen habe:
Bis zu diesem Radius lässt sich dieses Kabel ohne Kraftaufwand biegen.
Der Chat bei NBB bremst einen gleich mal ein.
Auf die Frage wie ich meine Karte schneller bekomme ... am Mittwoch bestellen oder gleich im Ladenlokal vorbeikommen (ist ja hier im die Ecke, genau so wie der Käsekönig) kommt die Antwort: Am Mittwoch kann man nur "vorbestellen".
Ihr könnt euch ja selbst zusammenreimen was das zu bedeuten hat.
Mist stimmt! Bei NBB gibt es nur Vorbestell-Buttons :S lul iwie dachte ich die ganze Zeit dass ich dort am 12.10 etwas kaufen kann. Damn diese 4090 Trance verblödet einem total.
Heißt also bei NBB gibts erstmal nix zu kaufen... vorbestellen halt eben nur.
Die Eskapaden der letzten Jahre soll doch eigentlich gezeigt haben, der NBB Chat taugt für rein garnichts.
Neben der FE wirds da ganz sicher auch Customs am Mittwoch zu kaufen geben.
Ich persönlich gehe davon aus, die beliebten Karten wie die FE und Strixx werden Day1 schnell ausverkauft sein aber innerhalb von einem Monat wird fast jeder in der Lage sein seine Wunschkarte zu bekommen.
Da die Karte eigentlich schon vorher rauskommen sollte und vermutlich massig auf Lager liegt, denke ich auch das ausreichend Karten im Oktober zur Verfügung stehen werden.
Langsam einatmen und langsam ausatmen 🤣🙃
Begrenzte Anzahl – Nur 2 Stück pro Kunde
Aktionszeitraum: 10.10.2022 - 16.10.2022. Aktionspreis gültig für begrenzte Stückzahl. Die Aktion endet, wenn das Verkaufslimit erreicht ist.
Proshop bereitet sich auch schon vor, steht u.a. bei der TUF.
Die haben da ab 10cm eine Befestigung montiert, um es wahrscheinlich zu stabilisieren. Ansonsten mit Gewalt kann man es bestimmt ab 7-8cm knicken
Wenn die Teile erst so spät knicken, wie passt das dann überhaupt bei normalem Einbau in ein Gehäuse ohne gegen die Front zu stoßen? Mit Riser Kabel sieht es halt nur :poop: aus wenn es so hoch geht aber die "Normalo Einbauer" bekommen bei den Kartendimensionen echt Probleme oder?
Nur 2stk pro Kunde ist schon mal SCHEIßE
War es nicht beim 30er Launch immer nur eine, klingt doch schonmal besser ;) ....
Ist denn eigentlich inzwischen schon bekannt, um wieviel Uhr genau (deutscher Zeit) die RTX 4090 FE auf der Nvidia-Website respektive dem NBB-Shop verfügbar sein wird?
So meinte ich das nicht.
Es sollten MAX 1 sein
Leider nicht.
Morgen sollen um 15 Uhr die Reviews Online gehen. Ob es danach direkt kaufbar ist oder man bis Mittwoch 15 Uhr warten muss, ist noch nicht bekannt.
Der Adapter auf Igor`s page sieht flexibler aus. Durch die Kameraperspektive aber schwer zu sagen.
Ähnliche Themen
