[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wie viel haste für die FE gezahlt?
1859 den normalen Preis .
Ist schon geil wen man bedenkt das es Performance mässig keine Unterschied gibt zu den teuren Karten .
Desweiteren haben meist alle außer die Nadel im Heuhaufen mit Abstrichen zu kämpfen ob Lüfter oder Spulen da kann ich auch gleich das günstigste kaufen zu Mal die Founders ja auch nicht hässlich ist .
Bin Mal gespannt wie die in Natura rüber kommt.
Hätte das gleich so versuchen sollen .
Aber na ja ich wollte unbedingt Mal ne Strix haben und so war das eine lange Irrfahrt.
Für die 5090 weiß ich was zu tun ist!
Der Bot von Hardwareluxx hatte auch angeschlagen.
Kumpel konnte noch nach einigen Minuten die Karte in den Warenkorb legen.
1710€.. Die Preise rasen ja richtig nach unten :d
Wie lange dauert das bei Asus mit dem Cashback oder bzw. wann sollte es spätestens da sein ?
Kohle aufs Konto dauert bis zu 90 Tage, gerne mal länger. Keys gehen meines Wissens nach schneller.
Ist eher bisschen durstiger .
Quelle
wenn man die Leistungsaufnahme beschränkt, dann sehe ich beim 7950x durchwegs wesentlich höhere Ergebnisse, gerade bei den produktiven Sachen. Stock kann man doch heute gar keine Hardware mehr betreiben :d Meine 4090 wird auch nicht mehr als 300 Watt kriegen. Auch meinen jetzigen 5950X habe ich auf 140 Watt beschränkt.
Hoffentlich bin ich hier richtig.
Wenn man die Beleuchtung einer MSI RTX4090 Suprim X dauerhaft deaktivieren möchte, muss die Software wo man dies einstellt dauerhaft im Hintergrund laufen, oder kann man dies einmal einstellen und die Software dann löschen?
Danke im Vorhinein :-)
B-Ware halt.
Und ja die kommenden Wochen sollten die Karten die UVP erreichen oder knapp unterschreiten .
Muss in Hintergrund laufen.
Meine 4090FE vom gestrigen Drop wurde soeben zugestellt. Das ging dann wohl mal zackig würde ich sagen (y)
wow, du musst ja direkt neben dem Warenlager leben! :)
Bei meiner Hermes Versandbestätigung wird immer noch auf die Daten gewartet. Ich bin aber auch ein gutes Stück weg, vermutlich.
Ach man ey, genau die würde ich haben wollen. Aber 2500 kann ich echt nicht machen, das ist lächerlich übertrieben für das bisschen weiß im Vergleich zur FE. Aber die passt einfach so gaaaar nicht in meinen white build, nervt mich jedes mal wenn ich da drauf schauen "muss".
Der ASUS Shop baut gerade um https://webshop.asus.com/de/grafikkarten/nach-grafikchip/nvidia-rtx4090-rtx4080/
Wahrscheinlich wird die White auch gleich dort sein. Aber ich denke der Preis wird bei 2449 - 2499 Euro ebenfalls liegen. Wird also leider nicht günstiger.
Das schlimme ist halt, die wird wahrscheinlich genau so fiepen wie die schwarzen Strix, und dafür dann 550€ Aufpreis im Vergleich zur FE? Da muss man ja schön bescheuert sein. Aber wäre ich wahrscheinlich... so für max 250 bis 300€ mehr...
Hat hier eigentlich jemand schon eine White Strix und kann was dazu sagen? Gab es da nicht ein, zwei Besteller, die schon zugeschlagen hatten?
Das schlimme ist halt, die wird wahrscheinlich genau so fiepen wie die schwarzen Strix, und dafür dann 550€ Aufpreis im Vergleich zur FE? Da muss man ja schon bescheuert sein. Aber wäre ich wahrscheinlich... so für max 250 bis 300€ mehr...
Bei der Karte wird alles gleich sein. Außer die Farbe des Kühlers :)
Kollege Lackdose hilft :d
Meine FE wird morgen erst zugestellt. Hab aktuell ein Dynamic O11 und werde wohl erstmal das Fenster weglassen wegen dem dollen Anschluss :rolleyes2:
Schon mal jemand die FE in vertikal eingebaut oder muss ich noch ein neues Case haben?
oh oh, wieviel Abstand ist denn zwischen pcie slot und Glas? Ich habe ein uraltes Define S, da sind es ca 18cm und ich hoffe dass das reicht!
Nicht so zimperlich. Knick den blöden Stecker einfach. Da passiert eh nichts. Lief 2 Wochen ohne probleme.
Aber ja, auch vertikal überhaupt kein problem mit dem o11.
So sieht es aus. Habe auch "geknickt" und alles cool. Original NVidia Adapter bis das weiße Seasonic Kabel verfügbar ist.
Heyho :),
ich hatte ne Suprim X im O11 Dynamic Mini ohne Probleme drin.
4090 Founders Edition304 x 137 x 61mm
MSI Sumprime X 4090336 x 142 x 78 mm
Der Adapter ist zwar an der Scheibe, aber er hat genug Platz, um vernünftig weggeführt zu werden. Das o11 dürfte wahrscheinlich gleich breit oder breiter als das O11 sein :)
Ähnliche Themen
