• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@s L i X
Ist das beim horizontalen Einbau der mitgelieferte Adapter?
Nein, ist die Nachrüstlösung von bequiet. Aber auch den NV Adapter würde ich so knicken. Bei den paar Fällen wo der Stecker weggebrannt ist, war ja nur mangelnder Sitz des Steckers die Ursache, wie man mittlerweile ja weiß.
Meine FE wird morgen erst zugestellt. Hab aktuell ein Dynamic O11 und werde wohl erstmal das Fenster weglassen wegen dem dollen Anschluss :rolleyes2:
Schon mal jemand die FE in vertikal eingebaut oder muss ich noch ein neues Case haben?
Mit dem Soft Silicon Flex Kabel von Moddiy passt die Karte "normal" rein ohne unnötiges, starkes knicken :)
FE 4090 + O11 (die alte version -> XL/EVO sind größer):
Die Palit hat etwa die selbe Tiefe wie die FE. (FE 137mm, Palit 138mm)
Ist die kleinste der ganzen Custom 4090.
@kurtftw
Das sieht erstmal ganz gut aus. Hast du einen Link zu den Kabeln. Kenne den Shop überhaupt nicht....
@kurtftw
Ich hab das auch nur über Reddit gefunden, war schon kurz davor ein neues Gehäuse zu kaufen, bin aber jetzt damit sehr happy. Hatte davor das Bequiet Kabel, war etwas besser als der Adapter von NV aber man musste immer noch sehr stark knicken. Das war mir zu heikel.
Wichtig ist beim Cable Style das Ultra-Soft-Silicon Wire auszuwählen & das richtige PSU Modell. Das Kabel wird aus HK verschickt, habe ca. 1-2 Wochen darauf gewartet und musste noch 6-8€ Zoll bei DHL zahlen.
Das schlimme ist halt, die wird wahrscheinlich genau so fiepen wie die schwarzen Strix, und dafür dann 550€ Aufpreis im Vergleich zur FE? Da muss man ja schön bescheuert sein. Aber wäre ich wahrscheinlich... so für max 250 bis 300€ mehr...
Hat hier eigentlich jemand schon eine White Strix und kann was dazu sagen? Gab es da nicht ein, zwei Besteller, die schon zugeschlagen hatten?
640 Aufpreis.
Und ja die werden wohl auch fiepen da alles gleich ist bis auf die Farbe.
Mit dem Verkauf meiner alten Platform hab ich mir für die Differenz eine Nagel neue AM5 Platform geholt inc FE und es ist noch Geld über.
Aufgrund der regen Gruppendynamik (hier MB, da CPU), konnte ich dem immensen Druck einfach nicht mehr standhalten :cry::ROFLMAO:
Hier liegen fast 1.900€... :fresse:
Z790 APEX, 13900K, G.Skill 32GB 7800MHz
Ich kann jetzt auch mitmachen, der Bote war da :fresse:
Weiß niemand ob man Hermes umrouten (andere Adresse) kann nach dem ersten fehlgeschlagenen Zustellversuch?
Bei UPS muss man den ersten Versuch abwarten, geht erst danach.
OMG - das Z790 APEX sieht live so geil aus😍
Ich finds in Weiß so hässlich, dass ich es wieder ausgebaut habe. 🙃
Was ist eigentlich mit Equippr los sind die nun Scalper Shop Nummer 1 geworden? Die hauen ja Outlet Preise raus..glaube die haben zuviel Lack gesoffen zu Sylvester...:ROFLMAO::ROFLMAO:
Bitte poste einmal Bilder vom Apex wenn du es ausgepackt hast. Das wäre mein Traumboard. Auf jeden Fall herzlichen Glückwunsch zur neuen Hardware und viel Spaß damkt. Sehr geil. :)
Aber selbst mit Cashback irgendwie noch 300€ zu teuer für mich, wenn es mir kein FPS mehr bringt. Aber irgendwie wäre schon geil, einmal so richtig auf die Kacke zu hauen. :d
Steuerrückzahlung und Bonus stehen an.
Wie ist das Ergebniss meiner FE?
OC Maximum habe ich noch keine Ahnung, oder ist das schon überschritten? Weil Sie taktet am Anfang höher und verliert dann ein paar MhZ
Sieht gut aus . Hast übrigens die Kernisolierung bei Windows aktiv .
Kostet Leistung in Timespy und Games. Hatte es selber vergessen es zu deaktivieren nach neu Installation
und war am rätseln warum im normalen Timespy die Werte nicht stimmen.
Kannst nur an nachbarn zustellen lassen oder anderen zustelltag.
Hatte mal bei ner 3080 FE einen „nachbarn“ ausgewählt der 50km entfernt ist. War auch kein problem😂. Nbb hat das feature dann aber deaktivieren lassen bei hermes.
Müsste aber mittlerweile wieder gehen
(Das geht aber nur solange das paket nicht in zustellung ist)
Erscheint mir schon gut, meine Grenze ist schon bei +180/1.1V/+1600/max PL, da lande ich dann bei ~3000Mhz average.
Schicke ich dir wegen OT per PN ;)
Mit Hermes weiß ich leider auch nicht, vllt hilft dir das weiter:
Also ich kann hier leider nichts ändern.
Könnte das mal jemand anderer gegenchecken? Kann jemand eine abweichende Adresse angeben?
60cm, aber 50cm hätten vermutlich auch gereicht. Bei mir läuft das Kabel unterhalb der GPU direkt nach hinten in die PSU.
An welcher PSU nutzt du das?
Mich irritiert etwas das "Dual 12 Pin to 12VHPWR 16 Pin" (bräuchte fürs Seasonic Focus GX 850W Dual 8 Pin psu-seitig)
Ähnliche Themen
