[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Meine FE ist jetzt auch eingebaut, naja sie fiept, leicht mehr als die Phantom, aber das Lüfterbrummen geht einem ja schon bei 30% ordentlich auf den Sack :d
So ging es mir auch. Fiepen nach UV ist voll Ok und im grünen Bereich. Das surren der Lüfter hat mich allerdings hart genervt, nach ein paar Tagen könnte ich es nicht mehr hören und habe sie zurück gesendet.
Meiner Ansicht nach sind sie alle so, hatte jetzt zwei FE hier.
Es ist ja nicht der Lüfter an sich (der Hintere/Obere) sondern die Resonanz die er durch den geringen Abstand im Pull erzeugt, auch nur minimal mit dem Finger bremsen killt das Geräusch sofort, aber ob ich da jetzt rummodden will (mit Abstandshaltern o.ä.), weiß ich nicht.
Momentan tendiere ich dazu einfach die Phantom wieder einzubauen, da haben die Lüfter zwar auch ein leichtes eigengeräusch, aber das stört mich nicht annähernd so, außerdem geht der Zero Fan bei der Phantom schon früher an... die FE stoppt erst bei 30-32°C egal wie ich die Lüfterkurve im AB einstelle.
Ich fand das Lüftergeräusch der Phantom 10 mal schlimmer als das der FE
Die Lüfterkurve der FE verstehe ich um ehrlich zu sein auch nicht. Auch wenn der Lüfter manchmal anspringt, springt er direkt mit einem Spike erstmal auf 2000 und geht dann erst auf 1100 runter, was man gerade im idle dann schon hört wenn es eben leise ist. Und dann kühlt die Karte ewig, bis Sie wirklich den Kühler auf gefühlte Umgebungstemperatur runter hat...
Laut wird der Lüfter (der weiter weg von der Slotblende) allerdings erst ab so ~45% was Sie im Gaming mit UV aber trotz schlechter Case Belüftung eigentlich nie erreich. Da pendelt es zwischen 39-42% circa. Dann matched von der Lautstärke aber der eine Lüfter auf ~47% ungefähr die Lautstärke des anderen Lüfters bei ~70% :d
@****** In meinem Vergleich ist ein CPU ein normaler 5800x, der andere ein 3D. Erster läuft mit 5ghz, der x3d ist ja leider gelockt. Daher der etwas andere score. Im Spielen dreht sich das Blatt aber oft.
Also ich ab sie mit UV auf 0.9V und 2610 MHz aufheizen lassen in RE2 Remake bei über 300W und da blieben beide Lüfter gestern bei 30% (GPU 62°C, Hotspot 70°C und Memory 72°C), aber auch bei 30% erzeugt der pullende das Resonanzgeräusch, vielleicht probier ich den Mod doch mal aus, geht ja schnell :d
Da das ja alles subjektiv ist, schätze ich, dass ich gegen die tiefen Töne einfach weniger empfindlich bin als gegen die hohen. Ich sortier hier regelmäßig die USB Netzteile aus, weil die Teile fiepen ohne Ende... Da scheine ich aber relativ alleine auf weiter Flur zu sein :shot:
Können mal mehr Leute dieses angebliche Brummen der FE aufnehmen?
Ein Brummen ist ein Brummen und meine FE brummt nicht, der hintere Lüfter ist einfach abartig laut und irgendwann (zwischen 60 und 80%) pfeift der auch -> hochfrequenter Schall.
Trotz seiner Lautstärke, klingt der hintere Lüfter bei 30% bis 40% nicht unangenehm (PC ist unter dem Tisch, wo er auch hingehört).
Mit dem Afterburner hab ich zwei getrennte Lüftercurves mit Fan Stop dank Firmware Control.
[Man muss nur beachten, dass beim Afterburner 10% mehr Fan Speed eingestellt werden müssen, da 40% = 30% usw.]
Klar, wenn der PC auf Dem Tisch wäre, hätte ich die FE direkt auf Wasser umgebaut, aber ist der Vorteil, wenn man auf die Optik insgesamt scheißt.
Mein Rechner steht unter dem Schreibtisch.... und es ist nicht der Lüfter an sich der Brummt und 60-80% ist viel zu laut und zum Glück auch nicht nötig in meinem Fall.
Ich kann heute Abend versuchen es aufzunehmen.
Und egal ob Firmware Control oder nicht, der Lüfter ist steuerbar, aber den Zeitpunkt wann Zero Fan greift zu verschieben funktionierte bei mir in keiner Konstellation.
Solange sie abseits vom Gaming aus sind, passt es bei mir. Und das ist der Fall :)
Aber ja, Zero Fan lässt sich nicht weiter konfigurieren.
Generell stimme ich zu, aber wenn sie noch weiter drehen bis 30-32°C runter (mit diesem Brummgeräusch) stört das schon :d, daher wäre es "nice to have" gewesen den An- und Abschaltzeitpunkt verschieben zu können.
Naja ich werd übers WE wohl mal rumtesten :ROFLMAO:
Meine FE ist jetzt auch eingebaut, naja sie fiept, leicht mehr als die Phantom, aber das Lüfterbrummen (ist ja an sich nicht der Lüfter aber das hatten wir ja schon) geht einem ja schon bei 30% ordentlich auf den Sack :d, werd ich wohl modden, oder Retour gehen lassen müssen.
Habe meinen Lüfter der 4080 FE mit diesen Teilen höher gesetzt. Habe die kürzeren genommen. Brummen ist jetzt so gut wie weg und man hört jetzt nur noch den Luftstrom der Lüfter.
Ja über den Mod hab ich auch nachgedacht :d
Lohnt sich auf jeden Fall. Hätte auch nicht gedacht, dass die irgendwas bewirken. Mit den kürzen Abstandshaltern steht der Lüfter auch nicht so sehr aus der Karte raus.
Welche 4090 würdet ihr denn empfehlen für Umbau auf Wasserkühlung. Dann wären Lüfter ja egal und nur möglichst kein Spulenfiepen usw. wichtig.
Zotac 4090 Extreme Amp Airo ... guckstu auch hier:
Die günstigste die man kriegen kann. Ist ziemlich dumm ne Strix OC zu kaufen wenn man doch auf Wasser geht.. ich kann mit meiner Zotac genau so ein 666w Bios nutzen wie auf ner Strix. Die Komponenten aufm Brett werden auch ZU überbewertet. Es ist ja nicht mal garantiert einen besseren Chip bei ner Strix oder Suprim zu bekommen.
Oh und persönlich kann ich Zotac Trinity / AIRO empfehlen. Selbst beim "Coil Whine Test" nicht zu hören.
Jo bin mit meiner billo Manli auch zufrieden :bigok:
@AfroZwerg
Wirklich interessant, der mod! Hat eine spürbare verbesserung des Geräusches gebracht, oder? Temperaturen sind nicht schlechter geworden?
@AfroZwerg
Nach meinem empfinden ist das Brummen weg. Man hört jetzt nur noch den Luftstrom vom Lüfter. Temperaturen sind gleich geblieben. Betreibe die FE mit festen 30% Lüftergeschwindigkeit.
Manli = Zotac, das ist korrekt.
Welchen Kühlblock hast Du drauf?
Mangels Alternative den da. https://www.alphacool.com/shop/graf...ora-acryl-gpx-n-rtx-4090-suprim-mit-backplate
Also ich finde die Komponenten und Phasen schon beachtenswert. Wenn ich schon Zuviel Geld ausgebe, will ich zumindest das am besten ausgebaute Board haben. Daher bei mir auch die 4090 Suprim X
Hat man allerdings den Platz im Rechner dann muss nicht auf Wasser gewechselt werden. Ich höre die Karte jetzt genauso wenig unter Wasser wie vorher unter Luft. Fiepen ist mir bisher noch nicht aufgefallen, was aber nichts zu bedeuten hat, ich kam bisher noch nicht wieder zum Zocken und unter Luft ist mir nichts aufgefallen.
Siehe Startpost
Auch der Held, der meinte The Witcher 3 stürzt regelmäßig ab…
Ich hab jetzt in 2 Wochen über 75 Std The Witcher 3 gespielt und hatte 3 Abstürze, weil ich höhere Taktraten getestet habe.
Aber ansonsten nicht einen Absturz mit 2805 MHz@0,975 und Speicher +1300 MHz.
Danke. So sieht es aus. Den Karten werden gerne mal Probleme angelastet, die entweder nicht durch sie verursacht werden oder gar nicht so groß sind.
Ähnliche Themen
Antworten
6K
Aufrufe
311K
