[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich kann auch sagen dass die RTX 4090 FE meine bisher beste Karte ist und ich hatte schon viele... ;) Das Glück bezüglich Spulen fiepen hatte ich nicht immer aber mit dieser Karte endlich mal das Ziel erreicht.
Das einzige was ich festgestellt habe und nachteilig ist gegenüber der 3090 FE ist das nun die soundkarte eine creative ae7 gestört wird wenn man im teamspeak spricht also das Mikrofon aktiviert. Das war vorher nicht was ich sehr schade finde
Hast absolut Recht mit dem Phasenvergleich.
Dachte mir das gleiche, aber mittlerweile ist mir fast alles egal, was manche für einen Müll von sich geben.
Eine Zotac Trinity würde ich niemals mit einem 660w Bios betreiben und 600w+ durchjagen.
Hinterher wird geheult, wie immer.
Auch der Held, der meinte The Witcher 3 stürzt regelmäßig ab…
Ich hab jetzt in 2 Wochen über 75 Std The Witcher 3 gespielt und hatte 3 Abstürze, weil ich höhere Taktraten getestet habe.
Aber ansonsten nicht einen Absturz mit 2805 MHz@0,975v und Speicher +1300 MHz.
Na ist doch schön dass das Marketing seinen Zweck erfüllt.
Funktioniert das denn? Dann hat man ja nur zwei Anschlüsse am Netzteil für die Grafikkarte verwendet statt den vier, die man über den alten Weg nimmt.
Ja funktioniert habe das gleiche Standard schwarz ohne Sleve . Habe mir jetzt ein Schwarzweißes geholt, da bei mir alles schwarz weiß ist . Haben beide 600 Watt. Ich nutze das mit einer 4090 Surprime X
Lg
Mangels Alternative den da. https://www.alphacool.com/shop/graf...ora-acryl-gpx-n-rtx-4090-suprim-mit-backplate
Also ich finde die Komponenten und Phasen schon beachtenswert. Wenn ich schon Zuviel Geld ausgebe, will ich zumindest das am besten ausgebaute Board haben. Daher bei mir auch die 4090 Suprim X
Hat man allerdings den Platz im Rechner dann muss nicht auf Wasser gewechselt werden. Ich höre die Karte jetzt genauso wenig unter Wasser wie vorher unter Luft. Fiepen ist mir bisher noch nicht aufgefallen, was aber nichts zu bedeuten hat, ich kam bisher noch nicht wieder zum Zocken und unter Luft ist mir nichts aufgefallen.
Siehe Startpost
Hoffe die Infineon TDA21570 sind ok auf den TUF´s .
Die AMD 6000er Karten die hier und da sterben haben unter anderem die TDA21470 verbaut , wenn das von da wo ich gelesen kein Schreibfehler war und es die selben sind.
Die sollen nicht so Wiederstandsfähig sein . Hoffe das es passt und die Komponenten gut sind . Kann nämlich ausnahmsweise mal sein , dass ich die 4090 länger als ein Gen. Zyklus
behalten möchte , weil ich tatsächlich mal mit der Leistung zufrieden bin .
Kenne mich selber mit den einzelnen Komponenten nicht so aus , außer das Monolithic sehr gut sein soll .
Richte mich danach auf wie viel Watt die VRM ausgelegt ist um da etwas Luft nach oben zu halten in der Hoffnung die Teile halten was auf .
Aber Superposition macht der Karte richtig Betrieb:
Dann mach doch hier mal mit :
Krass, immer noch verfügbar. Wo sind denn die ganzen White-Built-Guys?
Ist nicht mehr verfügbar. Click mal auf kaufen, da kommt nix im Warenkorb an.
Hab meine AB bekommen, also Montag / Dienstag sollte die da sein. Wird endlich ein stimmiger White Build. Das ärgerte mich schon seit meiner 3080 TUF. :d
Jetzt müssen nur noch diese Seasonic Honks ihr weißes 12vhpwr Kabel in den Verkauf bringen. Ende Q1, wenn überhaupt. :coffee2:
Nachricht gelöscht
Ich bin mit meiner 4090 Zotac Trinity (non OC) extrem zufrieden. Heute kam mein 5800X3D an und alles läuft perfekt selbst mit meinem 750W Seasonic Netzteil. Freue mich auf die neuen Unreal 5 Spiele.
Bin zwar auch ein White Build Guy aber mit meiner kfa2 4090 dermaßen zufrieden, dass es mich diese Gen nicht interessiert die Karte nochmal gegen eine andere 4090 zu tauschen, vorallem habe ich die für 1999 Euro bekommen und sehe keinerlei Grund warum ich für eine fiepende Strix 300 Euro Aufpreis zahlen soll. Ich hab für diese Gen meine perfekte Karte gefunden
Die KFA2 für unter 2000 Euro würde ich auch nehmen. Leider nicht mehr dafür zu haben.
Sei dir gegönnt :) . Ampere war sofern ich mich noch richtig erinner ein steiniger Weg für dich ^^ .
Von all den 4090-ern, die ich bei mir liegen hatte, war die Box der KFA² die größte. Da bekommt man echt noch etwas für sein Geld mit dem ganzen Zubehör. Es hatte mich allerdings schon ziemlich in den Fingern gejuckt, die mal zu testen. Aber das Ding ging ungeöffnet zurück, weil ich kurz zuvor ne leise TUF OC abbekommen hatte. Man muss nicht unnötigerweise alles ausprobieren. Irgendwann muss Schluss sein... *Therapieball-Drückgeräusche* :stupid:🤪
Armoury Crate hat ein Update für die Karte und andere Sachen gezogen (war im Auslands Urlaub die letzten 2 Wochen) und nun komme ich tatsächlich schon wieder nicht mehr ins Mainboard Bios rein,
da dass Bild wieder erst mit starten von Windows angezeigt wird, vorher: kein Signal.
Danke :), ja Ampere war eine Ausnahmesituation für mich, drum bin ich froh dass es diese Gen direkt mit der ersten Karte geklappt hat
Ich bin jedenfalls dankbar, dass ich noch in die Phase Deines Kaufrausches gefallen bin. :banana:
Das waren die letzten Ausläufer des Kaufrauschs. Ab jetzt nur noch Auftragsarbeiten... ;)
Viel Freude mit deiner neuen FE! :)
Ähnliche Themen
