[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Immerhin bietet CM direkt nen Austausch an :)
Nach der großen Freude, die leider nur von Samstag bis zur Stornierung am Dienstag gehalten hat, hab ich mir nun dies hier bestellt:
Mir scheißegal, ob die noch billiger wird, ich hab hier so viel gelesen, dass ich schon das Sabbern anfange, wenn ich nur an die Karte denke :fresse:
Wird halt nun ein etwas größerer Akt, da ich die Karte zunächst mit LuKü verbaue, um zu sehen, ob sie funktioniert, und somit den Kühlkreislauf ändern muss, aber was solls - 4090 ist nur einmal alle paar Jahre :d
Edit:
Aber wie ich mich kenne, gehe ich "all in", und hau gleich den Wasserkühler drauf, was soll schon sein?
Viel Glück mit den Spulen :wink:
Ich würde auch eine Karte bei zu lauten Spulen retournieren.
Genau, deshalb zunächst Testlauf.
Ich hab mich aber einfach mal hier orientiert:
Und da stehen die eigentlich schon gut da.
Bei Alternate hat es 18 Produktbewertungen, da hat sich auch keiner beschwert.
Wir werden sehen, oder besser gesagt, hören :d
Computeruniverse ist auch gut - Standardversand sind 6,99 und DHL kostet 8,99. Habe da bestellt und dachte noch so, was ich nehme. Habe dann Standard genommen und Paket geht nun dennoch mit DHL raus. :d
Langsam braucht man Markettiming um ne Karte zu kaufen :d
meine IChill 4 Frostbite von Galaxus wurde heute vom DHL boten gebracht und wartet zuhause auf mich.
Die Karte hat 2069€ gekostet.....keine Versandkosten und über Shoop habe ich noch 104€ cashback +10€ Gutschein bekommen.........
Im 3DCenter haben wir einen Foristen der seine Frostbite aus aktuelle Charge erhalten hat. Sehr leise bzw. lautlose Spulen wie bei den meisten dieser Karten. Allerdings hat er ein Problem mit der Hotspot Temperatur die teilweise an die 100°C geht. Was bei einer ordentlichen Wasserkühlung eigentlich nicht so sein sollte. Grundsätzlich funktioniert der Block ja prima.
Mach mir keine Angst.....der Bauer hatte die doch gestestet und sehr gute Temperaturen erwähnt.
Ich werde die Frostbite bezüglich Temperatur genau prüfen. Ansonsten hab ich mit der FE noch eine Option.
Spulenfiepen/-rasseln nervt mich auch. wird sich zeigen, ob mein Glück anhält.
Die einzige 4090, die bisher defekt ging, war doch die Frostbite von @Dana_X :fresse:
Die lief ca. 200 Std und dann Tschau Kakao.
Caseking hat eine quasi neue Karte an den Hersteller geschickt, statt diese direkt zu tauschen.
Premium Kundensupport 🫠
Easy 2-3 Monate keine Graka. Man wird echt bestraft nicht alles bei Amazon zu kaufen.
Hi
Wollte mal wissen wie die FE so boosted im Stock und mit Powerlimit . Wie merke ich das ich einen guten Silizium habe plus RAM? Hier gibt es bestimmt ein paar die eine haben.Ein paar Infos wäre nicht schlecht . Was ist angebrachter ? UV oder Powerlimit runter ? Wo kann ich ansetzen, damit ich einen Anhaltspunkt habe.
Bedanke mich im Voraus .
Lg
Hi
Lg
Einfach machen und testen. Durch das Nachmachen lernt man nichts.
Wahrscheinlich zu dicke Pads drauf .
Meine ist nicht das erste mal bei Inno3d .
Die können nicht mal einen wakü Block auf einer Karte verbauen . Würde einen teufel tuen von denen jemals eine Karte zu kaufen .
Schlechteste Boardpartner von Nvidia in allen Belangen .
Das hatten viele mit ihrer XFX6900XT Speedster Zero mit EKWB Block auch.........
@MS1988
Wenn die Karte schlechte temps liefert, geht sie zurück. Ich werde an der frostbite, die ich hoffentlich am Wochenende verbauen kann, nicht rumbasteln.
Hoffe für dich die Karte läuft wie sie soll und hast niemals einen Garantiefall.
Wir hatten hier ja schon mehrere Frostbite die gut liefen, inkl. die im der8auer Review. Ich denke mal der Anpressdruck passt nicht. Ob das jetzt an falschen Pad (finde ich unwahrscheinlich) liegt oder nicht richtig angezogen oder zuwenig Paste?
MSI Kombustor mit etwa 400 Watt bei mir (TUF und ALC Block) und 3DC Foristen. Wassertemperatur ist bei ihm etwa 30°C.
Ähnliche Themen
