• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Noch 1 Grad C. vom Throttling entfernt, ab 110 Grad Hotspot wird hart runtergetaktet 😃.
Sieht ungefähr so aus wie nach meinem Umbau auf Wasserblock kürzlich, da durfte ich eine Ehrenrunde drehen. War aber meine eigene Schuld durch Schlampigkeit, von daher "das übt".
Wir hatten hier ja schon mehrere Frostbite die gut liefen, inkl. die im der8auer Review. Ich denke mal der Anpressdruck passt nicht. Ob das jetzt an falschen Pad (finde ich unwahrscheinlich) liegt oder nicht richtig angezogen oder zuwenig Paste?
MSI Kombustor mit etwa 400 Watt bei mir (TUF und ALC Block) und 3DC Foristen. Wassertemperatur ist bei ihm etwa 30°C.
Anhang anzeigen 843076 Anhang anzeigen 843075
Bleibt dem User eh nichts anderes übrig als die Karte einzusenden.
Selber darfst eh nicht schauen sonst ist die Garantie futsch.
Kleben die immer noch ein Siegel über die Backplate oder versehen Schrauben mit Aufklebern? Ich besaß mal eine Frostbite 2070 Super, da war ein fragiles Siegel mit der Backplate verbunden. Sehr lästig.
Da ist ein Aufkleber.
Gerade im WaKü Bastelthread gestöbert, und da ist mir - zum Glück - aufgefallen, dass ich etwas sehr wichtiges vergessen habe...
Wärmeleitpaste für den GraKa umbau.
Was empfiehlt man da dieser Tage?
Mein letzter PC Bau war 2019, gab es neue Errungenschaften?
Achso, und wie ist es mit den Wärmeleitpads?
Kann man die von EKWB nutzen, oder sollte ich besser neue bestellen?
Nach der großen Freude, die leider nur von Samstag bis zur Stornierung am Dienstag gehalten hat, hab ich mir nun dies hier bestellt:
Mir scheißegal, ob die noch billiger wird, ich hab hier so viel gelesen, dass ich schon das Sabbern anfange, wenn ich nur an die Karte denke :fresse:
Wird halt nun ein etwas größerer Akt, da ich die Karte zunächst mit LuKü verbaue, um zu sehen, ob sie funktioniert, und somit den Kühlkreislauf ändern muss, aber was solls - 4090 ist nur einmal alle paar Jahre :d
Edit:
Aber wie ich mich kenne, gehe ich "all in", und hau gleich den Wasserkühler drauf, was soll schon sein?
Bist du so nett und schreibst uns wie der EKWB Block verarbeitet ist? Meine Karte von CU wurde storniert! :motz:
Hab die Noctua NT-H2 und abgesehen von der absolut grottigen Verarbeitung bringt die WLP sehr gute Temps.
Was die Haltbarkeit einer angebrochenen Spritze angeht, kann ich leider nicht helfen. Hab bislang immer direkt ne neue Spritze bestellt, wenn ich mal was an der Hardware geändert habe.
Ok, dann werd ich mir besser auch einfach die Kyronaut neu bestellen - man soll ja nicht am falschen Ende sparen :d
Wie ist es mit den Pads?
Und was empfiehlt ihr zum reinigen der GPU?
Abwarten, die machens am Ende wie Intel. Man nehme eine RTX4090, takte sie 100-200Mhz hoch und vermarkte sie als RTX4090Ti für 2499€ UVP :fresse:
Wunderbar, vielen Dank Euch.
Ich habe mir gerade ein Video zu dem EKWB Kühler angeschaut - wenn der Stock Kühler runter ist, bleibt ja fast nichts übrig :d
Bin am Überlegen, ob ich mir nicht noch ein Riser Kabel mitbestelle - brauch keine Disco, aber bei mir ist alles in sehr dezentem gelb beleuchtet, das würde schon sehr gut aussehen :)
Isopropanol, aber 99,9%!
Wo kauft man das?
Apotheke nehme ich mal an?
Für die 4090 habe ich die 16 Subzero Paste verwendet die Alphacool dabei gelegt hat. https://www.alphacool.com/shop/waer...e/27583/alphacool-subzero-thermal-grease-3-5g
Für den 5800x3D habe ich mal MX-6 getestet und bin auch zufrieden. Dabei gab es auch ein handvoll Putztücher die ich ganz praktisch fand. Habe ich auch für den GPU Umbau genutzt: https://www.arctic.de/MX-6/ACTCP00084A
Ich glaube bei Alternate hat jemand Mist gebaut.
Um 13.25 Uhr habe ich eine Auftragsbestätigung bekommen, mit meinen Artikeln, und der Info, das die Sendung an die Spedition übergeben wurde.
Unten drunter ein DHL Link zur Sendungsverfolgung.
Um 15 bekam ich dann noch mal eine Auftragsbestätigung, diesmal mit der Info, dass die Sendung an DHL übergeben wurde...
In meiner DHL App bekomme ich nun 2 Pakete von Alternate angezeigt, eines mit Zustellung am Freitag, beim anderen steht noch "wurde elektronisch angekündigt".
In der zweiten Mail von 15 Uhr sind dann auch 2 Paketnummern angegeben, aber laut der ersten Mail wurde meine Bestellung nicht gesplittet:
Da bin ich ja mal gespannt.
2 Karten zum Preis von einer?
Das hätte sich gelohnt :fresse:
Aber gut, da ich ein ehrlicher Mensch bin, würde ich das natürlich sofort Alternate melden.
Dennoch sehr verwirrend.
ich nehme eine :fresse:
Der Meinung bin ich auch.
Aber dazu passt dann eben nicht, dass ich 2 Auftragsbestätigungen bekommen habe, jeweils für Karte & Kühler.
Aber gut, das erste Paket ist schon in Obertshausen, das kommt vielleicht morgen schon an - ich werde berichten :)
Und selbst wenn das wirklich so wäre, spätestens bei der Inventur würde das auffallen.
Edit:
Wenn du hier mitgelesen hättest hättest du eine kfa2 bestellt und keine gigaschrott ^^
Ähnliche Themen
