• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Damit hätte ich jetzt aber nicht gerechnet, dass das Potenzial bei der FE besser ist 🤪 denke mal, ich hab ein guten Silizium erwischt. 👌🏽
Sie benutzt aber nicht die kompletten 600 W sondern um die 460watt. sie ist auch effizienter in allem, was ich jetzt ausprobiert habe als die MSI.
Lg
Plague Tale Requiem hat übrigens jetzt wohl endlich Raytracing bekommen. Aber nur Schatten, so wie es aussieht und es deaktiviert Ambient Occlusion komplett, was das Spiel schlechter aussehen lässt. LOL
Lg
Ist reines GPU-Glücksspiel.
Man kann auf einem TOP-PCB eine GPU-Gurke haben und man kann auf einen Gurgen-PCB eine TOP-GPU haben.
Interessanter wäre, was die jeweilige Karte an Max-Takt macht.
<3000Mhz = Gurke
3000 - 3100Mhz = mittel bis gut
>3100MHz = gut bis sehr gut
Also, die Karte ist Flüsterleise, ich höre bis jetzt nichts.
Hab mal Furmark kurz getestet, in WQHD, 470 FPS, nichts zu hören.
Was sollte man denn testen?
Benchmarks?
Ich installiert gerade Metro Exodus Enhanced, weiterhin werd ich Far Cry 5 & 6 spielen.
Was die Installation angeht, hatte ich wirklich Glück, die Karte hätte um ein Haar nicht reingepasst - da fehlen 5mm bis zum AGB :d
Ich hab sie mal mit Lego Steinen vom Junio gestützt, bleibt ja nicht lange so :)
<3000Mhz = Gurke
Damit kann ich leben 👍🏽
Lg
<3000Mhz = Gurke
Wenn wir über absolut stabil und fehlerfrei im geschlossenen Gehäuse ohne Sonderkühlung reden, würde ich sagen bei 1.1V kommt das in etwa hin, evtl. noch 15-30 Mhz weniger. Ab 3060 defintiv schon gut, ab 3105 exzellent. Von 4 Karten die ich hatte ging keine über 3045 bei 1.1V wenn man vernünftig testet. Zwei haben keine 3 Ghz geschafft.
Wenn wir über absolut stabil und fehlerfrei im geschlossenen Gehäuse ohne Sonderkühlung reden, würde ich sagen bei 1.1V kommt das in etwa hin, evtl. noch 15-30 Mhz weniger. Ab 3060 defintiv schon gut, ab 3005 exzellent. Von 4 Karten die ich hatte ging keine über 3045 bei 1.1V wenn man vernünftig testet. Zwei haben keine 3 Ghz geschafft.
Ich hatte sie sofort bestellt, als sie dort verfügbar wurde. Sie ist heute geliefert worden. Deswegen kann ich mir kaum vorstellen, dass es Retouren waren. Eventuell Stornierungen.
Hat wer Erfahrung mit Rückgaben im Mediamarkt? Wollte da eine 4090 bestellen und im Markt abholen. Zicken die rum wenn man die Karte im Markt zurückgeben möchte?
Oder lieber liefern lassen?
Also ich hatte da keine Probleme mit das war aber in der Zeit der 3090.
Lg
Hi allerseits,
ich habe Gestern, nachdem ich gesehen habe das der User INNO3DStephan aktiv im Forum unterwegs war, meinen Beleg per PN zur Verfügung gestellt :
Er bot Hilfe an und kam Heute mit der Info durch das die Karte dort erst in den nächsten Tagen erwartet würde !?.
Was soll ich sagen, das Drama geht weiter.
Bin enttäuscht, bald ist schon ein Monat rum.
Wollte euch auf dem Laufenden halten.
Beste Grüße
Sascha
PS.: Bin mittlerweile soweit, das ich glaube das ich die Karte vermutlich erst in 12 Wochen wieder hab, das ist mir eigentlich zu lang. Sollte jemand eine wassergekühlte Version übrig haben, nehme ich gerne eine PN. Komme aus Nähe Dortmund.
PPS.: Sollte ich mit PS gegen Regeln verstoßen gerne kurzen Hinweis, dann lösche ich es sofort wieder.
Ich werde meine Erfahrung auch im entsprechenden Thread schreiben, hier schon mal zur Info:
Die Karte, Gigabyte RTX 4090 Gaming OC läuft aktuell perfekt.
Ich höre keinerlei Geräusch, was da nicht sein soll, und mein Gehäuse ist aktuell offen.
Im Furmark wird die Karte voll ausgelastet, mit 448 Watt, max. Temp sind 72 Grad, da arbeiten die Lüfter, aber zu hören ist sonst nichts.
Ebenso in Spielen, oder zb. dem Far Cry 5 Benchmark - da kommt die Karte immerhin auf knappe 350 Watt :d
Frames habe ich da AVG 104, Max 130 glaube ich, da merkt man eben, das mein 8700k limitiert.
Achso, Cyberpunk habe ich noch nicht gespielt, werde ich aber heute Abend noch machen.
Bin gerade sehr zufrieden :)
Im Furmark hat meine Strix nicht gefiept, obwohl sie 400+W zu bewältigen hatte und ordentlich FPS angezeigt wurden. In allen anderen Benchmarks sowie Games zirpte sie rum wie ne Grille auf Drogen.
Also lieber mit Superposition und eben Games testen. Aber wenn's gut läuft auch mal zufrieden sein. :)
Wenn ihr eine Karte zum fiepen bringen wollt, kann ich shadow of the romb raider empfehlen :d
Kann die Karte über 450 Watt ziehen oder das gesperrt über das VGA Bios?
Kann es sein, das eine Founders Edition Fe 4090 schneller ist als eine MSI surpreme X. Wenn man gutes Silizium erwischt hat.
Lg
Das kann mit jeder GPU passieren.
Hi allerseits,
Beste Grüße
Sascha
Scheiße man, ich druck dir die Daumen dass du nicht so viel länger warten musst.. ist doch echt scheiße sowas -.-
Ähnliche Themen
