• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ist die VRAM Temperatur vielleicht einfach niedriger, weil es wieder kälter wurde? Gibt ja schon einige, die bei höheren VRAM Temps mehr Takt erreicht haben.
Die VRAM Temp is aktuell niedrig hab genau deswegen vorhin auch schonmal im Warmen getestet bei 21 Grad Zimmer Temp aber lüfter auf 100 % brachte kein unterschied
aber es lief vorhin schon +2000 durch mit nur Speicher Junction 36 Grad ... ich lass meine Lüfter grad auch langsamer laufen um die Wasser Temp wieder höher zu bekommen
und dann teste ich nochmal und achte dann auch nochmal auf die Temp .. aber ich hatte vor einigen Tagen auch schon mit 18 Grad Wasser getestet ( Mein Superposition Run ) und da liefen die
+2000 ja auch durch .. meine Aktuelle Wassertemp is grad 19 grad und auch da hatte ich grad wieder 1 run dabei der durch lief ... aber lasse nun mein wasser wieder wärmer werden und schaue dann
nochmal wie die Speicher Junction Temp dann is.
Hatte aber schon mitbekommen das zu kalter VRAM Kontraproduktiv is bei dieser Gen aber hatte in den letzten 5 Wochen dahin gehend keine Probs und da hatte ich schon Runs wo es hier kälter im Zimmer war
als Heute undd dennoch liefen die Runs 1A durch erst seit Heute gibts die Probs und Heute isses wärmer bei mir im Zimmer als bei meinen Besten RUns
Sagt mal gibt es eigentlich sowas wie VRAM Takt degeneration ?
Ich konnte Wochenlang fürs Benchen den VRAM auf +2000 stellen aber seit Heute muss ich auf +1900 oder +1800 runter um bei Port Royal nen lauf durchzubekommen
kann es sein das der VRAM Max Takt darunter leidet wen man ihn zu oft am Limit betreibt und man dann nich mehr so hochkommt wie zuvor beim VRAM Takt ? ... ( ECC hab ich aus )
Hmm nun konnte ich grad wieder 2 Runs mit +2000 machen seltsam .. und dann wars wieder vorbei ... manchmal gehts manchmal nich obwohls vorher wochenlang jedes mal ging.
Also 4 Wochen liefen +2000mhz ohne Probleme bei meinen Bench Sessions und nun seit Heute muss ich auf so +1800 runter und schaffe die +2000 nur noch ganz selten mal
Ya das ist möglich. Ich hatte direkt nach auspacken der Graka keine Probleme mit +2000, 21 loops miot speedway, alles qool. Heute: +1600MHz game- und memtest_vulkan stable. (y) Allerdings hat das keine 5 Wochen bei mir gedauert, vielleicht 1 Woche max. Dann gingen +1900MHz kurze Zeit, dann +1800 usw... bis +1600 aktuell.
Can aber auch sein, dass die +1700-2000 tatsächlich einfach nie stable waren.
Betroffen vom cold memory bug bin ich aber auch noch. Musste die temp um ca +10°C erhöhen, einfach pad-Folie am pad liegen gelassen.
Sollte einer von euch eine ZOTAC GAMING GeForce RTX 4090 AMP Extreme AIRO besitzen und gerade einen Gliedermaßstab oder anderes Messinstrument haben. Ich bräuchte mal die Breite das PCBs ohne die PCIe Steckleiste um abzuschätze wie vie Platz ich zwischen Stromanschluss und Gehäusewand habe.
Der cold bug tritt wohl nur bei VRAM-OC auf.
Und genau darum gehts ja grad bei dem Thema ... das Problem is das er Heute bei mir das erste mal wohl auftritt und 5 Wochen vorher alles ok war trotz niedrige Temps.
Ja gut möglich das ich den Cold Bug hab .. hab nun den VRAM von 36 grad mal auf 47 Grad erwärmen lassen und da liefen dann 2 Runs mit +2000 mhz VRAM durch.
Seltsam das ich das in den letzten 5 Wochen nicht hatte obwohl ich da Bench Sessions hatte wo ich auch +2000 VRAM gefahren hab und es in meinem Zimmer noch kälter war als Heute
Aber vielleicht war das auch grad nur zufall das nun 2 Runs durchliefen .. ich teste mal weiter
Mit 42 Grad VRAM gabs nun wieder crashes ... seltsam das es vorher im 30ger Bereich durchlief und ich nun wohl so zumindest 40 Grad VRAM brauch damit er durchläuft aber da muss ich nochmal weitere Tests fahren
Wenn dir die Maße von einer Trinity reichen, kann ich dir das gerne morgen messen. Da zu der Airo nur das RGB anders ist, sollte das ja passen.
Halleluja hast du immer eine kurze Zündschnur :oops:
Du pampst hier echt so viele user an oder ziehst alles ins Lächerliche. Muss doch nicht sein. Entspann dich doch bitte mal etwas.......
Grad für 1899 bei alternate im tagesdeal (y)
Nehme ich mal mit, eigentlich habe ich die 4090 Master im Auge gehabt, aber beim Umbau auf Wasser mit UV scheint es wohl egal zu sein welche Karte man nimmt... Edit: Bis auf Asus wegen Spulenfiepen :ROFLMAO:
Aktuell sind doch einige hier KS am Testen .
Guckst mal im MP und vielleicht kriegst dann ne durchschnittliche Sp 100 und kannst die bisschen undervolten . Beim 13700K musst schon Glück haben einen brauchbaren zu erwischen.
Mit VRAM OC lauf ich seit Monaten mit +1000 ohne Probleme. Kann mir nicht vorstellen das er degeneriert. Wenn jetzt bei euch schneller Fehler auftreten war er vorher auch nicht 100% stabil da sich jetzt durch andere Temperaturen/Treiber/Störfaktoren einfach ein paar Parameter geändert haben. Vermutlich läuft er in 2 Monaten besser wenn die Magnetischen Stürme der Sonne nachlassen :d
Es ist halt als hätte ich seit Heute eine komplett andere Karte als die 5 Wochen davor
Ich habs nun hinbekommen das ich zumindest bei Superposition die +2000mhz VRAM wieder hinbekommen hab .. dafür muss ich erstmal ein oder zwei läufe machen mit weniger VRAM Takt um die Karte bzw das Wasser aufzuwärmen ... durch das wärmere Wasser muss ich aber mit dem Core Takt runter da die dann Wärmere Karte als üblich die Taktraten die ich sonst gefahren hab als die Karte kälter war nun nich mehr schafft und wenn dann der Core Takt so 30 - 60 mhz unter dem Takt is den ich sonst hatte und der VRAm sich aufgewärmt hat auf so 44 Grad erst dann schaffe ich es mehrmals hintereinander +2000 mhz VRAM Runs bei SuperPosition zu machen
Vorher ging das alles aus dem Stand herraus .. core hoch und VRAM hoch und gib ihm aber jetzt is die Karte sehr Pingelich geworden
Ganz seltsam .. das is echt als hätte ich seit heute ne komplett andere Karte als noch die letzten 5 Wochen
@Stagefire Hast du vll den neuen Nvidia Treiber installiert?
jepp den vom 5.1 und den hab ich auch seit dem 5.1 schon drauf ... aber daran dürfte es nich liegen da ich seit dem schon einige erfolgreiche Bench Sessions gemacht hatte ohne Probs
auch sonst hab ich nichts installiert oder an meinem OC geändert was das verursachen könnte... alles is so geblieben es ist nur etwas Zeit vergangen
Bei Superposi hatte ich die +2000 ja wieder hinbekommen auf umständliche Art aber Port Royal is weiterhin zickig da hab ich in den letzten stunden nur ne Handvoll Runs mit +2000 geschafft
aber halt auch dort dann nur mit weniger Core als vorherwo noch alles ok war
Ich bleib dabei, die +2000 warn einfach nie stabil. Ich habe auch schon unzählige Benches gemacht bei der 4080 mit +1800, Port Royal, Memtest, Superpostion etc. pp. lief alles und spielen konnte ich auch stundenlang. Dann aber mal die Reflections Demo laufen lassen und schwupp, war nach 5 min abgeschmiert.
Wie gesagt warum war das in den letzten 5 Wochen nie ein Problem aber von Heute auf Morgen schon ? Währe dem so hätte ich diese Probleme doch hin und wieder schon in den letzten 5 Wochen
mal haben müssen aber das is Heute so als hätte ich grad ne komplett andere Karte im Rechner als noch Gestern bzw die letzten 5 Wochen
Und mir gehts hier wie gesagt ja auch nich um 24/7 Stable sondern nur um so 30 min Stable für ein paar Bench Runs. .. für 24/7 fahr ich beim VRAM ja nur +500 statt +2000
Die +2000 müssen also nur Bench Stable sein ( und das waren sie 5 Wochen lang ) aber eben nich Gamestable sein da ich fürs Gaming wie gesagt nur die +500 nutze
Ich mein ich halte es nich für unmglich aber die Leichtigkeit mit dennen ich in den letzten 5 Wochen die +2000 ( und sogar etwas mehr ) nutzen konnte im gegensatz zu Heute is halt seltsam
Aber nunja .... dann is das halt nun so .... betrifft ja zum Glück nur den Bench Bereich und damit war ich eh im Grunde durch
Von Caseking halte ich überhaupt nichts, dass bestätigt auch Dana_Xs Garantiefall. Scalperpreis und dann mieser Support.
Und dazu kommt noch, dass sie Frauen für Marketing negativ instrumentalisieren: Bikini Models und Pornoamateure um Kunden anzuziehen. Minderjährige Boys auf der GamesCom werden magnetisch angezogen und was weiß ich.
Klasse Laden :)
Nananana. Nix gegen Bikini Models! :d
Klasse Laden :)
Hey auf der Gamescom war ich, falls du Micaela Schäfer 2010 für Caseking auf der Gamescom meinst? :d
Aber schon etwas alt die "Kamelle" oder? :d
Kann es sein, das eine Founders Edition Fe 4090 schneller ist als eine MSI surpreme X. Wenn man gutes Silizium erwischt hat.
Lg
Kann sein, ja
Der Boosttakt ist bis 2860mhz volles Power Limit + 1,1 v.
Das hat die MSI nicht gemacht, ich denke mal, das ist akzeptabel, oder?
Lg
Die MSI hat 520W Powerlimit, die FE 600W kann da schon eine gewisse Rolle spielen wenn man die Spannung einfach nur hochzieht :d
Damit hätte ich jetzt aber nicht gerechnet, dass das Potenzial bei der FE besser ist 🤪 denke mal, ich hab ein guten Silizium erwischt. 👌🏽
Lg
Ähnliche Themen
