[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
EKL, Forum, Bekannte... keine Ahnung
Zweitrechner, Drittrechner, in OVP... :d
Edith: @Bunker00 @SaiBot62 Der Kollege war nicht so begeistert: Edith2: Ok der hat die iChill Version.. sorry :d
Haut ganz schön rein das Game :)
Is gekauft für 1799€. Kurz testen ob sie ruhig und einigermaßen potent ist, Block drauf und Ruhe. 😁✌️
Ich habe heute mein EK Waterblock verbaut. Mein erster Block von EK. Ich muss zugeben von der Verarbeitung und Haptik spielen Aquacomputer und Watercool eine Liga weiter oben. Der EK Block wirkt jetzt nicht billig aber wer schon einmal ein Block von AC oder WC verbaut hat weiß was ich meine.
Neuer 4k Monitor ist heute gekommen, und ich bin hin und weg - hätte nicht gedacht, dass das doch soviel ausmacht.
Die Karte ist der Wahnsinn, ich hab auf WQHD bei zb. Far Cry 5 FPS zwischen 100 - 160 gehabt, ab und an sogar darüber.
Jetzt in 4k dasselbe, das heißt, zuvor hat sich die Karte eher gelangweilt :d
Alles in allem bin ich froh, dass ich den Schritt gegangen bin, nun sollte mal wieder für ein paar Jahre Ruhe sein :)
Ich weiß was du meinst, aber ehrlich gesagt, niemand hat mir mehr mit Macken behaftete Produkte geliefert als Aquacomputer. Ich würde da nur Watercool und (vom Hörensagen) Optimus "eine Liga höher" sehen.
Tja, jeder der einmal am süßen 4k Nektar genippt hat will danach nichts anderes mehr. Ging mir genau so.
Jetzt brauche ich auch nur noch die 4090, die nicht zirpt und leise Lüfter hat. :fresse:
Ich hatte bis jetzt 2x AC und 1 von WC hatte nie Probleme.
Bitte zeige mal Ergebnisse in Bezug auf Kühlung und Leistung.
Mache ich! Gibt heute Abend noch ein kleines update.
Trotzdem 1 Stern auf deiner Kackskala. Darf man nicht vergessen.
Die Kackskala kann man nicht ernst nehmen, die kfa2 in eine kackskala aufzunehmen ist nur lächerlich, eine extrem leise Karte die einfach perfekt ist
Wie muss man sich das vorstellen? Laufen die Lüfter dann kurz mit 1400 Umdrehungen an oder gleich auf 100%?
Habe ein ähnliches Problem mit der Gaming OC aber ich glaube der Schuldige in der Sache ist das Cablemod Kabel. Hab unregelmässig Blackscreens und die Lüfter drehen dann auf 100% hoch. PC muss dann über den Power Button ausgeschaltet werden. Manchmal hab ich es zwei mal am Tag und dann wieder ne Woche gar nicht. Man findet dazu einige Einträge bei Reddit. Hab jetz mal das Cablemod gegen den original Nvidia Vierzack getauscht und werde das ganze beobachten. Glaube das Cablemod Kabel hat ein Problem mit den Sensepins (Wackelkontakt), da mir das ganze auch zweimal passiert ist, als ich beim Onlinezocken etwas impulsiv geworden bin und mit der 👊 auf den Tisch geschlagen hab :ROFLMAO:. Also irgendwas muss dann einen Wackelkontakt haben.
Hatte ich bei meiner 4090 Gaming OC bis sie gar nicht mehr ging.
Dank Mediamarkt sehr unkomplizierte Rückgabe und Erstattung am gleichen Tag.
Jetzt ists eine Palit Gamerock OC geworden. Viel kühler und leiser als die Gigabyte.
Habe kein Problem mit der Lüftersteuerung der Gaming OC.
Die hat doch aber so ein Sägegeräusch bei den Lüftermotoren^^
Freue mich riesig auf den 27.1 Dead Space wird Mega mit der 4090 in 4K auf dem OLED .
ich glaube man kann das eh in dem ea Abo für 15€ zocken? Hol ich mir das halt mal wieder.
Bild 1. BL3 max out 4k -> 4090@OC -> siehe Bild Afterburner
Bild 2. BL3 max out 4k -> 4090@stock
Bild 3. Marvel MS max out 4k DLSS Qualität & 80 FPS lock
So auf die schnelle sollte das passen, nur das Delta Wasser -> GPU ist echt hoch. :unsure:
Feintuning kommt später. :)
Gibt es eigentlich schon Bilder der beiden Versionen für die 4090FE von Watercool?
Alphacool find ich jetzt nicht so wertig und Watercool.. ist jetzt auch noch DER Hersteller wenns um Qualität geht. Nehmen sich alle nichts.
Naja wie gesagt es gibt auch genügend Einträge bei Reddit mit anderen Karten wo das gleiche Problem besteht. Viele davon nutzen das Cablemod Kabel. Ich versuch es jetzt mal noch mit dem original Vierzack, wenn es mit dem auch wieder vorkommt, muss ich mir was überlegen.
Hatte davor die Gainward Phantom und die ist baugleich mit der Gamerock, die hatte aber das Lüftersägen, da sind die Gigabyte Lüfter (mit Custom Curve) einfach unhörbar. Auch von den Temps ist die Gigabyte schon nochmal ne Ecke besser. Bis auf die Lüfter war die Gainward allerdings ne super Karte. Spulenfiepen und Rasseln bei beiden Karten nur sehr leise ausgeprägt. Kein Vergleich zur Asus Tuf die ich auch zum testen hatte, da sind mir die Ohren abgeflogen.
Habt ihr das den original vierzack Adapter genutzt als die Blackscreens bei euch waren?
Ähnliche Themen
Antworten
6K
Aufrufe
369K
