[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
wo hast dann Deine überhaupt gekauft? Beim genügsamen Scalper von nebenan? :d
So ist es in der Tat gewesen. Er hat sie von mir zum Einkaufspreis bekommen. Hatte @****** per PN angeschrieben, nachdem ich gesehen hatte, wie frustriert er war, beim Drop schon wieder keine FE abbekommen zu haben. Dass ich ihn ausgewählt habe, war Zufall. Es hätte auch jeden anderen treffen können, der am 03.01.2023 leer ausgegangen war.
Und jetzt bitte keine Diskussion darüber, warum ich die Karte dann überhaupt gekauft habe, wenn ich sie nicht brauche. Ich sag nur soviel: Drops machen süchtig! Und andere glücklich zu machen auch! :)
Ich habe gestern meine GigaByte 4090 OC verbaut! Lüfter drehen sich erst ab 50 Grad. Die Spulen fangen bei +100 FPS an mit pfeifen. Geht aber voll in Ordnung da dass Seitenteil vom Tower noch ab ist. Luftkühlung ist mir eindeutig zu laut zum Glück ist EK Vector Block heute gekommen. Die Leistung ist beeindruckend, da ich oben im EG am TV (PC steht im Keller) zock mit FPS lock 80 braucht die Karte bei Marvel Midnight Suns mit DSSL 4k und Max Out nur 190 Watt. Meine 3080 hat über 300 gezogen bei ca 45~70 Fps plus der Umstand das der VRAM aus ging. Die FPS mit 4090 sind einfach bei 80 und zucken überhaupt nicht.
Habe heute meine Gigabyte 4090 OC verbaut. Ab über 50 Grad drehen die Lüfter erst und random anlaufen der Lüfter im idle habe ich bisher nicht. ( Mit Youtube und Twitch getestet)
Benutze das Silent Bios! Werde auf die random anlaufenden Lüfter nochmal die Tage genau drauf achten und berichten. Leichtes rasseln und fiepen bei 300 Fps (Gehäusewand offen) , geht für mich klar!
Lüfter der Karte finde ich nicht zu laut obwohl das Gehäuse offen ist wegen der scheiss Kabelschlange mit den vier Köpfen :fresse: Time Spy Stock 35.200 Punkte.
Das jetzt erstmal! Kann leider die Karte erst Freitag bisschen quälen, weil ich gerade durch die Arbeit in der Woche kaum Zeit habe.
Also Samstagabend kommt noch mal ein update und dann auch ein Post im Rassel Thread.
Amazon hat zwar 3 Anläufe gebraucht heute bis mal ein Platz im Locker frei war, aber jetzt kam das Fasgear Kabel an. Gerade eingebaut und bin von der Qualität positiv überrascht.
Der Stecker hat ein deutliches klicken beim einrasten, und es lässt sich gut biegen ohne dass man Angst haben muss alles kaputt zu machen (y) Ich denke damit werde ich erstmal zufrieden sein.
Hat wer ein Tipp für UV? Über PT oder Curve? Komme ja vom AMD muss mich erstmal wieder reinfuchsen. Nvidia Systemsteuerung ist ja echt eine Katastrophe, da bin ich von AMD ganz schön verwöhnt.
Edit: Hab was gefunden zum UV. Auf Computerbase ist es ganz gut beschrieben.
Ne das sollte eigentlich noch reichen (ohne OC)
Warum das Netzteil tauschen? Für 450 Watt PT reicht es locker. Die 4090 kannst du auch problemlos begrenzen, ohne nennenswert einzubüßen
Das war ne Frage, mehr nicht. Da WaKü mit 2x Mo-Ra wäre OC denkbar aber nicht zwingend erforderlich derzeit. NT kann dann später ja noch getauscht werden.
In Verbindung mit dem X3D sollte das noch passen.
Würde das PL auf 450 Watt belassen. Kannst ja trotzdem den Speicher etwas hochdrehen und auch paar MHZ auf dem Core geben.
Bei der 4090 passt das noch mit 450 Watt . Klar zum Benchen mal 600 Watt geben kann man mal machen und sollte auch noch gehen.
Gut ist bei der 4090 , dass diese nicht diese krassen Peaks hat wie es bei Ampere der Fall war.
Wenn du mal sowas wie CP 2077 mit RT allem drum und dran zockst und bei dem Game wird auch etwas mehr die CPU gefordert solltest mit allem drum und dran bei
600 Watt AVG Leistungsaufnahme max. liegen. Theoretisch würde ich sogar sagen das ein gutes 750 Watt NT sogar reichen würde im Gaming.
Damit das Teil garnicht so viel Saft braucht in anderen Games ist es immer Sinnvoll ein FPS Limit zu setzen.
Teilweise in Bf 2042 in 4K und 138 FPS Limit @ Ultra DLSS Qualität 220-250 Watt ist schon nice .
Dying Light 2 oder CP 2077 mit RT allem drum und dran natürlich wesentlich mehr bzw. 400-440 Watt.
Das mit den random anspringen der Lüfter bei der gaming oc im idle hab ich auch
Wie muss man sich das vorstellen? Laufen die Lüfter dann kurz mit 1400 Umdrehungen an oder gleich auf 100%?
Habe ein ähnliches Problem mit der Gaming OC aber ich glaube der Schuldige in der Sache ist das Cablemod Kabel. Hab unregelmässig Blackscreens und die Lüfter drehen dann auf 100% hoch. PC muss dann über den Power Button ausgeschaltet werden. Manchmal hab ich es zwei mal am Tag und dann wieder ne Woche gar nicht. Man findet dazu einige Einträge bei Reddit. Hab jetz mal das Cablemod gegen den original Nvidia Vierzack getauscht und werde das ganze beobachten. Glaube das Cablemod Kabel hat ein Problem mit den Sensepins (Wackelkontakt), da mir das ganze auch zweimal passiert ist, als ich beim Onlinezocken etwas impulsiv geworden bin und mit der 👊 auf den Tisch geschlagen hab :ROFLMAO:. Also irgendwas muss dann einen Wackelkontakt haben.
wenn das noch möglich ist, Karte zurücksenden, Wiederruf oder RMA!
War damals bei meiner Gigabyte Karte genauso mit kurzen Black screens und 100% Lüfter. Irgendwann geht Garnichts mehr...... wurde dann auch als defekt bestätigt und gab Geld zurück!
Scheint bei den Gigabyte Karten öfters vorzukommen. Also ich meine man liest vermehrt von diesem Fehlerbild, ka woran es letztendlich liegt. Aber mein Tipp, niemals abwarten obs von alleine aufhört.
War halt viel zu teuer dafür :fresse2:
Also bei mir sind nur die Lüfter die hin und wieder mal aufheulen (definitiv über 2k Umdrehungen) selbst ohne aber irgendwie trakt hwinfo eh nicht so richtig weil da manchmal ganz merkwürdige Zahlen stehen.
Feiner Zug von Dir (y)
Ich hatte selbst schon überlegt, ob ich ihm eine anbiete.
Bei mir ist aber noch nicht ganz klar, welche Karte jetzt letztendlich bleibt.
Hallo zusammen,
gerne würde ich beim nächsten Drop eine neue FE ergattern, allerdings hatte ich noch ein paar Fragen dazu:
1. Stimmt es, dass NVIDIA für die FEs aggressives Binning betreiben?
2. Für die neue Grafikkarte wird mein 750W-Netzteil wohl nicht mehr reichen. Ist für einen 13900K non-OC und eine 4090 (evtl. mit etwas OC) bei einem 1000W-Netzteil genug Luft?
3. Wo kann ich mich am besten eintragen, um eine Benachrichtigung/Email bei Drop zu bekommen?
Vielen Dank euch schon mal und eine schöne Restwoche :)
Hallo zusammen,
1. Nein
2. 1000W reicht auf jeden Fall. Denke aber 750W wird auch funktionieren, wenn es ein gutes ist. Bei mir mit UV und 5800X3D braucht mein Gesamtsystem unter Vollast keine 500W.
3. Ich habe hier im Forum den Verfügbarkeitsbot abboniert und darüber eine FE bekommen. Kann man aber glaube auch über Telegram machen, da geht es wohl noch schneller.
Warum wollen denn alle eine FE und nicht die Custom Modelle?
1. Schön
2. "Günstig"
3. Gibt eh kein Binning für hochpreisige Customs
2. Laut Geizhals sind einige Custom Modelle günstiger als FE. Günstigster Geizhals Preis für die FE seit Aufzeichnung: 2.099€
Die FE gibt es auch nur bei Notebooksbilliger, alles andere sind Re-Seller und Scalperangebote.
Man muss natürlich auf einen Drop hoffen, bzw. dass man diesen mitbekommt.
Das erklärt natürlich den "hohen Preis" bei Geizhals.
Danke für die Erklärung.
Hier habe ich kurz beschrieben, wie das mit der Kurve geht. Und hier gibt's ein paar Benchmarks von mir. Das ist eine Auswertung Powertarget vs. curve. Das für die Auswertung benutzte Tool ist CapFrameX.
Ähnliche Themen
