[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Du hast aber mitbekommen, dass dies inzwischen geht?
Zitat:
„Ein großer Vorteil ist nun allerdings, dass Framelimits, Ingame-Bildratenbegrenzungen und V-Sync zusammen mit DLSS 3.0 funktionieren, ein Umstand, der zum Launch der RTX 4090 noch nicht gegeben war.“
Ja wurde ja schon 2x erwähnt gerade. Warum es bei mir nicht funktioniert hat muss ich am WE prüfen.
Wenn du das wie in meinem Video nicht reproduzieren kannst, dann muss es ja an irgendeiner Einstellung liegen. Vermutlich im BIOS oder so.
Hab noch Windows 10 mit CSM also ohne resize bar. Weis nicht ob das ein Unterschied macht.
Ist das Logo beleuchtet?
Zeig doch bitte mal ein paar Eindrücke im angeschalteten System.
Ja die ADA Karten lassen sich trotz der bis zu 450 Watt sehr gut kühlen. Warum auch immer.....
Auf dem Bild ist der Rechner an. RGB gibt es bei mir nicht und leider war auch das RGB Kabel direkt abgerissen, bevor ich den Kühler überhaupt nur ausgepackt habe. Für mich nicht schlimm, schreibe ich aber definitiv an Alphacool, da hat auch einiges mit den Schrauben nicht gestimmt.
Ich denke aber, dass das Logo nicht leuchtet.
Es befindet sich lediglich ein billiger LED Streifen an der Seite zum Mainboard, bis zu den Anschlüssen konnte ich keine Stromleitung feststellen.
ZMT 15,9/9,5mm oder 16,1/11,1mm?
bitte entschuldige, ich habe überhaupt keine Ahnung, was das bedeutet. Schlauchdurchmesser?
Da ich auch erst darüber gestolpert bin (Framelimit CP 2077): Beim Ingame-Framelimit in CP2077 muss man bedenken die Hälfte seiner Ziel-fps einzustellen. Dort wird FG nämlich nicht einbezogen. Ein "altes" Limit von bspw. 80 fps vor dem FG-Patch müsste nun also auf 40 fps eingestellt werden, damit effektiv 80 fps Begrenzung mit FG entsteht. Anderfalls wäre hier in dem Beispiel eine 160 fps Begrenzung aktiv, die natürlich je nach Einstellungen gar nicht zum Tragen kommt.
Die treiberseitige Begrenzung berücksichtigt FG korrekt, d. h. die dort eingestellten fps gelten dann ingame. Von einer Begrenzung mit RTSS ist bei Einsatz von FG derzeit abzusehen, das funktioniert nicht ordentlich.
Edit: Hier wird es gut zusammengefasst:
Beitrag im Thema "Cyberpunk 2077: Update reicht DLSS 3 und Nvidia Reflex auf dem PC nach" https://www.computerbase.de/forum/t...-reflex-auf-dem-pc-nach.2128395/post-27838341
Bei 2 360'er Radiatoren für die 4090 und CPU sind das ja traumhafte Temperaturen............
Lass uns noch ein paar Grad drauflegen, habe gestern noch eine Stunde Belastungstests gemacht, aber über 50 Grad komme ich nicht. Meine Karte läuft aber auch mit wesentlich weniger Spannung und mit ca 150 Watt weniger, alles darüber wurde mir zu ineffizient, die Benchmark-Punkte sind sogar höher... Absolut keine Ahnung, was sich Nvidia mit diesen 450 Watt gedacht hatte. Die Vergleichswerte sind aber bei den exakt gleichen Einstellungen. Habe einen 360 gtx und einen 360 gts im Define S. Die Arctic Lüfter drehen maximal mit 800rpm, meistens aber mit ca 400.
Mit dem 20% Gutschein bei Aquatuning.de auf Alphacool GPU Kühler bekommt man die aktuellen 4090er Blöcke relativ günstig.
Bye the way, gilt dieser Gutschein auch für Lüfter?
Wie wärs, wenn Du die Lüfter einfach in den Warenkorb packst und schaust, ob der Code da gilt?
Bei vielen Deiner Posts frage ich mich, ob Dur nur trollst oder ob Du die ernst meinst.:unsure:
Und wieder Frane Generation stuttering, diesmal bei Cyberpunk:
Hat hier jemand mit einer Ryzen CPU die gleiche Erfahrung gemacht?
Kein Stuttering, weder mit 5800x3d noch 5950x + 4090. 3840x1600 sowie 3840x2160 Auflösungen.
Richtig, Schlauchdurchmesser. Gibt ja "verschiedene Ausführungen" die als 16/10 verkauft werden.
Das wusste ich nicht, ist meine erste Wasserkühlung. Habe zwei verschiedene Schläuche verbaut. Der eine ist von Alphacool, ein EPDM Schlauch, ziemlich hart und rigide, die Fittings ließen sich fast gar nicht zu drehen. Der andere ist ein Heatkiller EPDM Schlauch, wesentlich leichter zu verbauen und weicher und flexibler.
Wieso fragst du nach den genauen Maßen? Eventuell kriege ich den Loop ja doch noch dicht. Momentan kann ich mein Leakshield nicht mal benutzen, da es irgendwo irre viel Luft reinzieht, aber ich die Stelle partout nicht finde. Wasser tritt, selbst bei voller Drehzahl auf beiden Pumpen, nicht aus.
Ich hab nicht nach gefragt, das war @Dwayne_Johnson :d Aber wenn ich so lese dass du irgendwo Luft hast, dann kann es daran liegen dass du z.B. einen minimal größeren Schlauch für deine Fittinge nutzt. Die genaue Größe steht immer irgendwo auf der Verpackung! Ich habe nämlich von EK Schlauch, der als 16/10 verkauft wurde aber mehr oder weniger zu groß für handelsübliche 16/10 Fittings ist.
Jo. Der wird dann der ID 11,1 sein.
Wenn jemand eine ASUS TUF OC sucht zum Bestpreis. Bester Preis bisher war 2130 Euro.
[/URL]
1999 Euro inkl. Versand mit dem Gutscheincode "Vorteil223"
Das ist in der Tat ein sehr guter Preis für die TUF OC. Kurz vor Weihnachten (23.12.) gab es diese Karte allerdings schon einmal für 2.089 Euro bei Computeruniverse.
Jetzt müsste nur noch die Strix mal günstiger werden...
In der Tat. Gleich mal eine bestellt. Wenn die nicht fiept, dann behalt ich natürlich die. Auch noch die OC Version. War auch nicht bei Geizhals bisher. Danke @SH.
Komm schon Asus, schickt mir nicht nochmal so ne Zirporgie! :-[
Edit: Etwas fiepen darf sie, macht meine 3080 auch. Aber eben nicht so dieses krasse Modem mäßige Zirpen wie bei der Strix White.
Edit2: Wenn das aber n Rückläufer ist, geht die direkt ungeöffnet zurück. Hoffe auf Neuware trotz des Preises.
Passend dazu für 20% weniger heute mit dem Code "ALPHA20"
2130 Euro für eine ASUS 4090 unter Wasser ist denke ich völlig in Ordnung
Ohne Scheiss, hätte ich vielleicht machen sollen. Aber egal. Wenn es die nicht ist, dann eben nicht.
Krass, schon die VB erhalten.
Der Versand bei CU geht immer recht schnell. Vermutlich kommt deine Tuffy schon morgen bei dir an. Bin mit meiner (zweiten) TUF OC bisher sehr zufrieden.
Nicht unken teurer Forenkollege, nicht unken. :fresse:
Woran erkennst du ob es ein Rückläufer ist?
Meistens sieht man es am antistatischen Beutel, wenn sie keinen neuen nehmen. Total zerknickt, also nicht so wie bei einer neuen, wo es fast keine Knicke gibt. Zudem sieht man es manchmal auch am Zubehör, wenn die kleinen Laschen der Verpackungen aufgebogen sind. Hab auch schon eine Karte bekommen, wo die Kappen für die DP/HDMI Anschlüsse nicht mehr da waren usw.. Auf solche Sachen kontrolliere ich solch teure Produkte immer als erstes. Kratzer oder Schäden auf den Karten selber wie etwa verbogene Kühlerfinnen oder so hatte ich aber noch nie.
Irgendwelche besonderen BIOS Einstellungen vorgenommen? Wäre nett, wenn du mal einen Screenshot von deinen NVCP Settings machen könntest.
Ich schreibe jetzt nur übers Hauptsystem, da hier mehr oder weniger alles "versaut" ist..
BIOS ist bei mir aktuell extrem versaut (Dark Hero), sodass mein 5950x nur auf 4.7 GHz boostet, keinerlei 5GHz Single Core oder so (ich bin zu faul es zu fixxen, da ich aktuell mehr oder weniger nur mitm 3D Drucker + Fusion 360 herumspiele)
Ich lade mal Screenshots vom NVCP bei imgur oder imgbb hoch, gib mir ein paar Minuten :)
An der jeweiligen EAN-Nummer erfährt man die exakten Innen-Maße
K.A. warum manche Shops das nicht, wie EK machen. Meist ist (sollte) "16/10" real 15,9/9,5mm und "16/12" 16,1/11,1mm sein
Die "Non-available-Edition" dient nur als Teaser, um uns in den ASUS-Shop zu locken und diesen dann mit der Strix OC im Warenkorb zu verlassen :d
Schon krass, wie die Preise jetzt fallen :-)
Die nicht verfügbare TUF non OC kennen wir ja schon. Da der Preis jetzt nicht niedriger ist als bei Computeruniverse hab ich da keine Kopfschmerzen. Und Binning gibt's bei mir nicht. Die TUF hatte ich noch nicht, daher ist es einen Test wert. Aber wenn die solche Geräusche macht wie die Strix werde ich keine zweite TUF testen.
Hätte aber natürlich lieber bei Amazon bestellt. Aber egal, meine Karte wurde schon verschickt. :)
Und die Preise der Strix wurden auch angeglichen. Endlich.
Tja, nur verfügbar müssten sie sein. ;)
Hab mich bei der White Strix aber nochmal auf benachrichtigen setzen lassen. Hat bei der 3090 zwar auch schon nicht geklappt, aber kostet ja nix. :fresse:
Viel Erfolg, meine TUF non-OC hat ordentlich geträllert :d
Aber der Kühler bzw. die Lüfter waren leise..
Hatte auch vorhin bei CU die TUF OC bestellt, aber in den Bestelldetails stand dann "Wareneingang in Kürze erwartet" und beim Aktionspreis stand "Nicht mehr lieferbar" hab wieder storniert, muss stark bleiben, hab eigentlich auch keine Lust mehr enttäuscht zu werden :d
Im Asus Webshop auf Amazon ist sie verfügbar für denselben Preis. Viel Glück. :)
Ähnliche Themen
