[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Stuttering in Dead Space wurde mit einem 200mb Patch behoben.
Ebenfalls der DLSS Bug (nach Neustart von Quality auf Balanced).
OC Stabilitätstest Deluxe:
Dead Space in 6K (4K DLDSR 2.25) + DLSS Quality und alles auf Anschlag.
Die Auflösung ist hier entscheidend. 4K oder 5K via DLDSR 1.78 reichen nicht aus.
Man muss mit CRU die 4096er Auflösung killen.
Verrückt, es war bei mir das selbe. Nach dem Patch Null Unterschied, weiterhin Ruckler des Todes. Dann habe ich die von dir vorgeschlagenen 2.25 direkt im Nvidia Controllcenter eingestellt, jetzt läuft es Butterweich. Was macht das bitte für einen Sinn, dass die Bude stabiler läuft wenn die DLSS Skalierung hochstellt? Müsste es da nicht theoretisch schlechter laufen oder check ich's gerade einfach nicht.
Gibt es jetzt noch irgend eine Alternative zum Power Kabel für das be quiet Straight Power 11? Ich befürchte das es zu kurz sein wird. Habe noch nicht angefangen den Rechner zusammen zu bauen aber ich ahne böses.
Mir war langweilig :)
Die KFA GTX4090 click OC Bestellt.
Habe gestern knapp 4000€ ausgegeben für alle Komponenten.
Ich schätzte nächste Woche kann ich alles zusammen bauen.
Hauptkomponenten
NZXT H9 Flow schwarz mit Glasfenster
AMD Ryzen 9 7950X (16x 4.5GHz / 5.7GHz Turbo)
Corsair H150i RGB Elite schwarz
Gigabyte X670 Aorus Elite AX
64GB (4x16GB) DDR5 AM5 PC6000 Kingston Fury Beast RGB
1TB SAMSUNG 980 PRO M.2 PCIe 4.0 x4 NVME (L 7000MB/s ; S 5000MB/s)
24GB NVIDIA RTX4090
1000W be quiet! Straight Power 11
Ich werde meine CPU dann updaten sobald die neuen CPUs von AMD zukaufen sind.
Hauptkomponenten
24GB NVIDIA RTX4090
Und was hat das jetzt alles mit der 4090 zu tun 🤔
Hauptkomponenten
24GB NVIDIA RTX4090
Dann hättest du noch 1 Monat auf die X3D Modelle warten können …
Das ist kein Problem die CPU kann ich immer noch gebrauchen. Für mein Workstation.
Sobald ich alles zusammen gebaut habe stell ich ein paar Bilder dann lass ich euch in ruhe.
Was von der IChill Black zu halten Mom 2100 Euro statt 2400 die Frostbite
Und wieder Frane Generation stuttering, diesmal bei Cyberpunk:
Hat hier jemand mit einer Ryzen CPU die gleiche Erfahrung gemacht?
Das ist der Alphacool Core auf der 4090 FE. Habe jetzt fast eine Stunde den Kreislauf entlüftet, jetzt wird gebootet, wünscht mir Glück!
Schick!
Wie schauen die Temps aus?
Hauptkomponenten
24GB NVIDIA RTX4090
Also bei 4000 euro nur 1TB ssd is aber auch schwach, da hätte ich gleich ne 4TB 850SNX gekauft
Hab zwar nun kein Ryzen sondern nen alten Intel 9900K mit 5 Ghz Allcore + 4,7 ghz CPU Cache Ratio und die Asus 4090 Strix und DDR 4100mhz CL17 nebst Manuellen Timings
aber generell mal zu Frame Generation meine Erfahrungen
Mit Frame Generation bisher gezockt
1. Spiderman ( mit Frame Gen durchgezockt )
2. Spiderman Miles Morales ( mit Frame Gen durchgezockt )
3. Portal RTX ( 1 std angetestet )
4. Witcher 3 ( 2 std angetestet )
5. Cyberpunk ( 1 std angetestet )
Ich bin nun nich mehr der Jüngste und auch kein E-Sportler sondern Singleplayer Gamer aber bei allen 5 Titeln die ich bisher mit Frame Gen getestet bzw durchgezockt hab
hatte ich kein Stuttering oder sowas sondern einfach nur nen haufen mehr FPS als vorher was ne feine Sache is kann da zumindest bisher nur Positiv drüber berichten.
Nur dürfen halt die Grund FPS also ohne Frame Gen nich zu tief sein aber wenn ich Nativ so 60 FPS hab und dann Frame Gen anmache verspühre ich nur Positive Effekte
erst wenn ich Nativ im niedrigen FPS Bereich bin mit so um die 30 FPS oder so und dann Frame Gen anmache dann hat das Game zwar 60 FPS aber es es ruckelt dennoch aber das is ja bekannt
Aber wenn ich "hohe" ( also zb so ab 60 FPS ) Nativ FPS hab läuft wenn ich Frame Gen dazu schalte hinterher alles flüssiger und hab auch nich mehr stutter als vorher und auch nich mehr Lag als vorher
aber wie gesagt ich bin halt auch nich mehr der Jüngste.
Schick!
Wesentlich besser als gedacht. Vorallem ist der Rechner jetzt absolut still. Wollte eigentlich irgendwie einen dritten Radiator mit einbauen, aber das habe ich sofort ad acta gelegt.
Core ist von 68 auf 44, Hotspot von 76 auf 49, VRAM von 82 auf 46. Meine Ohren von "geht so" auf "ist die Kiste an?"
Jetzt muss sich nur noch Leakshield mit dem Loop anfreunden. Angeblich ist der Loop komplett undicht.
Ist das Logo beleuchtet?
Zeig doch bitte mal ein paar Eindrücke im angeschalteten System.
Ja die ADA Karten lassen sich trotz der bis zu 450 Watt sehr gut kühlen. Warum auch immer.....
Ich habe Vsync im Treiber an und bei mir werden die FPS automatisch auf 115 gecapped in Cyberpunk mit FG. (LG C9)
Läuft sehr gut, Latenz ist in Ordnung bei über 100FPS und großartig Artefakte kann ich auch nicht feststellen beim spielen.
Habe das Game noch nicht mit 50% Geschwindigkeit abgespielt und mit einer Lupe danach gesucht, habe ich auch nicht vor. :bigok:
Bei mir ist es so wenn ich FG aktviere bei den Games wird automatisch Nvidia Reflex zugeschaltet und die FPS werden -6 @ max. HZ limitiert.(Egal bei allen Games auch ohne FG , wenn Reflex aktiv ist)
Habe auch Global Vsync ansonsten immer aktiv.
Ansonsten habe ich meine persönlichen Erfahrung mit FG hier nochmal zitiert.
So also Frame Generation in CP 2077 läuft echt super .
Bei Dying Light 2 bisschen stutter bemerkt und läuft nicht so Rund damit.
Teils Grafikfehler oder Texturen laden nach . Nvidia Reflex macht bei dem Game unter anderem Probleme und muss ja dann aktiv sein.
FG habe ich da deaktiviert , weil es läuft so auch gut und Nvidia Reflex muss ich bei dem Game deaktivieren , weil das zu ruckler führt.
Erstes Game wo ich negative Erfahrung mit Nvidia Reflex habe. Bei Hitman ist FG auch nicht so toll. Teilweise werden Bereiche im Dartmoor Benchmark
zu dunkel angezeigt und manche Texturen laden nach. Bisher mit FG in Darktide und CP 2077 gute Erfahrung . Bei Dying Light 2 und Hitman optisch ne Verschlechterung gemerkt.
Hitman 3 spiele ich aber Nativ ohne DLSS und für mich sehen da die Texturen am besten so aus. Da verzichte ich sogar auf RT , weil dann habe ich meine 144 FPS.
Bei 2 360'er Radiatoren für die 4090 und CPU sind das ja traumhafte Temperaturen............
Nur Vsync und Framelock gehen nicht mehr und ab 120fps kommt dann logischerweise tearing
Du hast aber mitbekommen, dass dies inzwischen geht?
Zitat:
„Ein großer Vorteil ist nun allerdings, dass Framelimits, Ingame-Bildratenbegrenzungen und V-Sync zusammen mit DLSS 3.0 funktionieren, ein Umstand, der zum Launch der RTX 4090 noch nicht gegeben war.“
Ähnliche Themen
Antworten
6K
Aufrufe
381K
