[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Kurze Frage noch: läuft die 4090 mit meinem doch schon älteren AX1500i noch ohne Probleme oder braucht es ein moderneres NT (atx3.0)?
Viele Nt´s sind aktuell auch nur "ATX 3.0 ready" was eigentlich nur heißt die Technik vom 2.xx drinne verbaut ist , aber dafür ein oder zwei native Kabel von 12VHPWR auf 12VHPWR dabei ist.
Im prinzip tuen es auch die älteren wo man halt via Adapter oder halt von 2x 8 Pin auf 12VHPWR gehen kann .
Wenn bei deinem NT PSU Cable Type 4 unterstützt wird dann kannst auch das Kabel von Corsair nutzen
Wüsste auch nicht, inwiefern es da Probleme geben könnte.
Nun, gerade ältere Netzteiltechnik kann Probleme mit den schnellen Lastwechsel moderner Hardware bekommen, wie sich das ältere AX1500 dort verhält kann ich aber nicht sagen, Igor hatte das bei Zeiten ausführlich analysiert mit verschieden Netzteiltypen, Fazit war, dass man besser keine ganz neuen GPUs mit alten Netzteilen kombinieren sollte, im Einzelfall mag es aber auch kein Problem sein, was eine generelle Aussage zu dem Thema eh sehr schwierig macht.
Sicher ist aber, dass man auf ein Netzteil nach dem 3.0 Standard verzichten kann.
Vielleicht kennt sich da jmd sehr gut aus und weiß, ob sowas wie "Powercaps" auch im heimischen PC funktionieren würden *duckundwegrenn*
Das NT würde die extremen Stromspitzen nicht mitbekommen, wenn der Pufferkondensator zw. GPU und NT hängt
Unfassbar :shot:
Leider unspielbar mit ner 4090 mangels Videospeicher :fresse2:
Mein AX1200i ist 10 Jahre alt. Was für Probleme erwartest Du?
Hatte nur was von ATX3.0 gelesen, neuen Steckern und das ältere Netzteile mit Lastwechsel Spitzen Probleme haben. Da dachte ich nachfragen kann nicht schaden. :)
bekomme ich einen grey screen und muss reseten.
Wenn es wirklich bei mehr als einem Spiel auf tritt ist ein Hardware Fehler wahrscheinlicher als ein Softwarefehler.
Was man versuchen sollte, ist den Treiber mal komplett mit der neusten Version von DDU runter machen und dann noch mal probieren ....
Hogwarts Legacy.. Verursacht sogar Bluescreens. Schon 3 Bluescreens gehabt beim Probieren, das Spiel irgendwie zum laufen zu bekommen. Irgendwann musste ich mir ja mal die Finger mit ner Vorbestellung verbrennen :d
Wir ham's Dir doch gesacht! Oder warst das nicht Du? Na jedenfalls ham's wir jemandem gesacht. :d
Ja, das war ich. :d Absoluter Witz, einen Tripple A Titel so zu releasen.
Ich mach den Scheiss schon lange nicht mehr mit...
Wenn ich kaufe, sind die Titel zu 99% durchgefixt und für nen 10er oder 20er zu haben
So eine halbfertige Rotze abzuliefern ist eine Frechheit!!! :mad:
Mit 60 Mäusen hast du 100% bezahlt und bekommst dann sowas... :rolleyes:
Hab ja so gesehen kein Geld bezahlt. War halt der 80€ Gamesplanet Gutschein von meinem Mainboard, welchen ich genutzt habe. Trotzdem doof. Neuinstallation ist meine letzte Hoffnung, ansonsten muss ich aufn Patch oder den neuen Grafiktreiber warten.
Wenn die titan raus ist läuft auch das game flüssig. keine sorge.
Ok, aber kannst du bei Gutscheinen das Game nicht wieder abgeben?
(80€ sind fett!!! Sonder-Edition? Kostet bei Steam "normal" 60)
Ne, war ein 80€ Gutschein, das Spiel in der Deluxe Edition hat 62,99€ gekostet :d
Kann es nicht mehr zurückgeben. Will ich auch gar nicht. Nach wie vor total gehypt.
Bluescreen gibts noch?
Jup. Gerade wieder nach der Neuinstallation direkt n BSOD gehabt.
Da hätte ich schiss, dass Steam das Spiel einfach wieder aus der Bibliothek entfernt. Ist schon öfters passiert bei Kumpels.
Mache ich schon seit bestimmt 15 Jahren so und meine Brüder auch, da wurde noch nie was gelöscht aus der Bibliothek.
(Mache das nicht bei jedem Spiel, aber bei sehr vielen)
PS: Aber ohne Cojones gibt’s wie so oft keine Belohnung im Leben 😏
Kaputte Spiele hole ich mir nur noch so günstig wie möglich, Hogwarts Legacy:
20€ über Steam Ukraine:
Calisto Protocol hatte ich mir über den argentinischen Steam Store geholt für 19€:
Ukraine - WTF!!! :d
Über ARG hatte ich schon mal was gekauft :)
Und krass, dass Dead Space fast das Doppelte knapp 39€ kostet
Ok, der Preis von Hogwarts Legacy passt zur derzeitigen "Leistung" :fresse:
Angenommen man wohnt für mehrere Monate in ARG (oder Urlaub). Da kann Steam ja nicht erwarten, dass man das Game über DE kauft, obwohl man noch längere Zeit im Ausland lebt/wohnt
Keine Ahnung was ihr habt, bei mir läuft Hogwarts Legacy Nativ in 4k ohne DLSS und Raytracing zwischen 120 und 144 FPS meist näher der 144 FPS und eigentlich oftmals auch mehr aber habe auf 144 begrenzt hin und wieder mal ein kleiner Ruckler im Frametimegraph zu sehen, aber sonst keine Probs
Habs zum Laufen bekommen. Läuft butterweich :d
So ist das, manche Games akzeptieren manche OC's extrem schlecht :d
Monster Hunter World ist ein Paradebeispiel.
Ähnliche Themen
